Set point change not actioned
Posted: Wed Jun 22, 2016 1:19 pm
Hi
Installed the Nest plugin some time ago and all good.
Some time later I noticed that when I changed the set point on the device panel the temp would change but then flip back to the original value on the next status update.
From the nets phone app and device itself all was fine an f it was changed on the device the update came through to the plugin and Indigo.
I took a flyer and regenerated the API key and all was well.
However it has happened again and changing the key and several roads/restarts later no joy.
Any thoughts anyone??
I am running Indigo 6.1.9 and Nest plugin v2.0.32
Thanks in advance.
Neil
Below is log example. The set point was 16.5 to start with you see the change request and then on the next update the temp changes back.
2 Jun 2016, 20:16:46
NEST Home sent "Lounge Thermostat (Downstairs)" decrease heat setpoint to 15.5
NEST Home sent "Lounge Thermostat (Downstairs)" decrease heat setpoint to 14.5
UPS and Battery Monitor Power Status - AC Power
UPS and Battery Monitor UPS Model - -Value800ELCD (id=9895936)
UPS and Battery Monitor Charging Status - True
UPS and Battery Monitor Battery Charge - 100
UPS and Battery Monitor Refreshing in 5 Minutes
NEST Home Lounge Thermostat (Downstairs) target_temperature_c updated to 16.5
NEST Home Lounge Thermostat (Downstairs) ambient_temperature_c updated to 20.0
22 Jun 2016, 20:17:22
Z-Wave received "023 - Lounge Radiator Thermostat (LC-13)" status update battery level 69%
Z-Wave received "Lounge Radiator Thermostat (LC-13)" heat setpoint is 21.00 °C
NEST Home sent "Lounge Thermostat (Downstairs)" decrease heat setpoint to 13.5
22 Jun 2016, 20:18:09
Thanks in advance.
Neil
