Variable Images for Nest on control pages
Mon Jan 11, 2016 6:42 am
bosstdh offline
I am looking to have an image represent the current temperature and heat set point. As the current temperature changes and the set point the image should change - Is this possible?
Please let me know how to name the files if so.
heat set point = 18 degrees celcius
Current temperature = 16 degrees celcius
how would i name the file so that the image would appear on the Control Page? nest+heatsetpoint18.png?
Tue Jan 12, 2016 1:11 am
marketability offline
Re: Variable Images for Nest on control pages
you would name the images something like...
assuming the value is an integer
... etc
copy the image files to the "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/images/controls/devices" folder if the value is a device state
or "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/images/controls/variables" if the value is stored in a variable
Thu Jan 14, 2016 9:58 pm
bosstdh offline
thank you for your reply yes i tested that and it worked.
How would i display an image for the current temperature?
Could i display an image with a combination of the heat point and the current temperature at the same time?
how would i display that on the control page as i can select only one variable at a time?
