NEST Home plugin - Error with Generate NEST API Key
Tue May 16, 2017 8:50 pm
foolio offline
Hi Mike,
I have installed the latest version of your plugin and am trying to set up the NEST API Key from the Configure NEST Home window.
I click the Get NEST PIN button and go through the steps to generate the PIN.
Then I paste the PIN into the enter your PIN field and then I click the Generate NEST API Key but every time I do, I get the following error:
NEST Home Error Error in plugin execution UiAction:
File "plugin.py", line 4186, in getNestAPI
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ast.py", line 49, in literal_eval
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ast.py", line 37, in parse
SyntaxError: ('unexpected EOF while parsing', ('<unknown>', 0, 0, ''))
Is this something you can help with?
Justin
Mon May 22, 2017 9:09 am
foolio offline
Re: NEST Home plugin - Error with Generate NEST API Key
Well, I tried it again the other day and was able to generate the Nest API key from the plugin. Nothing had changed and I didn't do anything different so I don't know why it wasn't working before.
Justin
