Print all States of all Variables and Devices to log file
Posted: Sun Dec 07, 2014 11:18 am
This plugin will print all states(and current values) of all variables and devices to the log file. It is a utility that might come handy when you are looking for detailed information about devices etc.
after install go to Menu/Plugins/DevciesAndVariables/ and select "Print States of all devices and variables to the INDIGO log" to create the output
The plugin is essentially in sleep mode and only wakes up to print the list.
here the download link
https://www.dropbox.com/s/xlwx8bwad7aneft/devicesAndVariables-v-1-1.zip?dl=0?dl=0
It will create a list like this (but MUCH longer)
- Code: Select all
DevicesAndVariables variables --------------------------------- Value
DevicesAndVariables abc: 0
DevicesAndVariables alarmVariable: false
DevicesAndVariables alarm_any: 1
DevicesAndVariables alarm_BackW_1: 0
DevicesAndVariables testVariable: #x;y1;y2;y3;y4;y5;y6|2;1;0;0;0;0;0|3;0;1;0;0;0;0|4;0;0;
DevicesAndVariables time_20_minutes_over: false
DevicesAndVariables vacation: home
DevicesAndVariables xxx: 0
DevicesAndVariables Yahoo_tomorrow_forecast: Cloudy
DevicesAndVariables Yahoo_tomorrow_max_temp: 27
DevicesAndVariables Yahoo_tomorrow_min_temp: 25
DevicesAndVariables youGotmail: false
DevicesAndVariables Zone_Minutes: 2
DevicesAndVariables Zone_Number: 4
DevicesAndVariables zzzz: one device is up again
DevicesAndVariables devices ------------------------------------- State(Value), State(Value), ...
DevicesAndVariables Alarm-arduino: MACNumber("DE:AD:BE:EF:FE:EE"), WiFi(""), deviceInfo(""), hardwareVendor(""), ipNumber("192.168.1.152"),
DevicesAndVariables : nickName("Alarm-arduino"), noOfChanges("657"), status("up"), statusDisplay("up 2014-12-0"), timeOfLastChange("2014-12-04 18:20:14"),
DevicesAndVariables ThermostatDownstairs: hvacCoolerIsOn("False"), hvacDehumidifierIsOn("False"), hvacFanIsOn("True"), hvacFanMode("0"), hvacFanMode.ui("auto on"),
DevicesAndVariables : hvacFanModeIsAlwaysOn("False"), hvacFanModeIsAuto("True"), hvacHeaterIsOn("False"), hvacHumidifierIsOn("False"), hvacOperationMode("3"),
DevicesAndVariables : hvacOperationMode.ui("auto on"), hvacOperationModeIsAuto("True"), hvacOperationModeIsCool("False"), hvacOperationModeIsHeat("False"), hvacOperationModeIsOff("False"),
DevicesAndVariables : hvacOperationModeIsProgramAuto("False"), hvacOperationModeIsProgramCool("False"), hvacOperationModeIsProgramHeat("False"), setpointCool("77.0"), setpointCool.ui("77 °F"),
DevicesAndVariables : setpointHeat("73.0"), setpointHeat.ui("73 °F"), temperatureInput1("73.0"), temperatureInput1.ui("73 °F"), temperatureInputsAll("73"),
DevicesAndVariables DiningRoomCeilingLights: brightnessLevel("0"), onOffState("False"),
DevicesAndVariables doorMorningLinc: onOffState("False"),
DevicesAndVariables Excercise room TV switch: accumEnergyTimeDelta("0"), accumEnergyTimeDelta.ui("0 seconds"), accumEnergyTotal("34.621"), accumEnergyTotal.ui("34.621 kWh"), curEnergyLevel("0.0"),
DevicesAndVariables : curEnergyLevel.ui("0.000 W"), onOffState("False"),
DevicesAndVariables ExerciseRoomHallwayLights: brightnessLevel("0"), onOffState("False"),
DevicesAndVariables Meter-LeftBoxClamp1: accumEnergyTimeDelta("482798"), accumEnergyTimeDelta.ui("482798 seconds"), accumEnergyTotal("9325.304"), accumEnergyTotal.ui("9325.304 kWh"), curEnergyLevel("193.678"),
DevicesAndVariables : curEnergyLevel.ui("193.678 W"),
DevicesAndVariables Meter-LeftBoxClamp2: accumEnergyTimeDelta("9543750"), accumEnergyTimeDelta.ui("9543750 seconds"), accumEnergyTotal("11902.069"), accumEnergyTotal.ui("11902.069 kWh"), curEnergyLevel("636.905"),
DevicesAndVariables : curEnergyLevel.ui("636.905 W"),
DevicesAndVariables MeterTotalLeftBox: accumEnergyTimeDelta("10402580"), accumEnergyTimeDelta.ui("10402580 seconds"), accumEnergyTotal("21227.398"), accumEnergyTotal.ui("21227.398 kWh"), curEnergyLevel("830.583"),
DevicesAndVariables : curEnergyLevel.ui("830.583 W"),
DevicesAndVariables NoaLoveField: currentCondition("Overcast"), currentConditionIcon("ovc"), dewPointC("7.8"), dewPointF("46.0"), dewPointString("46.0 F (7.8 C)"),
DevicesAndVariables : heatIndexC("- data unavailable -"), heatIndexF("- data unavailable -"), heatIndexString("- data unavailable -"), humidity("86"), latitude("32.86"),
DevicesAndVariables : location("Dallas Love Field, T"), longitude("-96.85"), observationDate("Sun, 07 Dec 2014 09:"), pressureInches("30.42"), pressureMillibars("1030.1"),
DevicesAndVariables : temperatureC("10.0"), temperatureF("50.0"), temperatureString("50.0 F (10.0 C)"), visibility("10.00"), windDegrees("120"),
DevicesAndVariables : windDirection("Southeast"), windKnots("6"), windMPH("6.9"), windString("Southeast at 6.9 MPH"),
