Error in v 2022.36.87
Thu Sep 15, 2022 6:00 pm
Bleasel offline
Hi
Thanks for the plugin.
Getting the following error with the latest version
fingscan Error
File "plugin.py", line 3728, in createDev
if len(vInfo)> 3:
TypeError: object of type 'NoneType' has no len()
Sat Sep 17, 2022 1:23 pm
Re: Error in v 2022.36.87
I am out of town. Back Sunday evening Will fix then.
Sat Sep 17, 2022 5:34 pm
Bleasel offline
Thanks for the update
error has moved to next line
fingscan getting vendor info..
fingscan Error
File "plugin.py", line 3729, in createDev
if len(vInfo)> 3:
Sun Sep 18, 2022 6:57 am
SHOULD be fixed in v ...89 posted in the plugin store and on GitHub.
it was an implicit return with no return value, like
def xxx()
if abc: return mac
if not abc then it returned nothing (None)
missing was
return ""
at the end.
That condition only happens when no mac - vendor file is present. And that should fix itself after some time when a mac-vendor file was downloaded successfully
Sun Sep 18, 2022 11:55 pm
Bleasel offline
Thanks Karl
That fixed all the errors.
Cheers
Marcus
