READ if fing sucks for you!
Wed Sep 07, 2022 10:13 am
new2me07 offline
Parallels created some network bridging for the VM my Mac was hosting.... The commands fing uses throws an error before any scanning gets started because it doesn't know which network interface to use.
To complicate matters further, when I'd delete fingscan, I would never clear the tables from the SQL logger, so everything would re-populate even after I deleted absolutely everything associated with fing.
Just venting / hoping someone will read a the lightbulb click, as fing and fingscan are F...ing awesome, thanks Karl
Tue Oct 11, 2022 1:54 am
thumpinc offline
Re: READ if fing sucks for you!
How would I "clear the tables from the SQL logger"? Ive run into this same problem and have completely deleted and reinstalled FING with no luck. The plugin crashes, phantom networks appear in the FING app, etc.
Thanks in advance
Wed Oct 12, 2022 4:03 am
tables get " deleted"
A) from SQLite: only if
1. delete devices or variables in indigo
2. shutdown indigo
3. run vacuum in sqlite
if not vacuumed the space of tables are still present, but not used
B) from postgres: if
2. run vacuum or cluster on the postgres DB
if not vacuumed I believe the empty space will be used over time by postgres
C) could you be more specific on "The plugin crashes"
And fingscan should have no connection to the FING app on a phone it does not know about it and I don't know how it should communicate with it
Wed Oct 12, 2022 11:45 am
thumpinc offline
Thanks Karl -
I've been having a problem with the plugin since upgrading to indigo 2022. I posted the crash logs for the plugin in a separate thread a few weeks ago but it received no replies so I will repost it below.
https://forums.indigodomo.com/viewtopic.php?f=166&t=26565
The plugin reloads over and over again.
Log is below. Thanks for taking a look.
Error in v2022.36.91
fingscan Initializing .. FING created new data waiting ~ 1 minute for stable operation
fingscan .. (re)started FING, initialized
fingscan
fingscan
EVENT defs:::::::::::::::::: Start :::::::::::::::: -- all
EVENT defs:::::::::::::::::: END ::::::::::::::::::
fingscan getting vendor info..
fingscan --> while loop break stopping ... quitNOW was: Indigo variable error 8
Reloading plugin "fingscan 2022.37.91" using API v3.0.0
Stopping plugin "fingscan 2022.37.91" (pid 3292)
fingscan Warning stopConcurrentThread called 2
fingscan runConcurrentThread stopping plugin due to: ::::: no :::::
Plugin restart request ignored (plugin is currently stopping or starting)
fingscan killing 2
Stopped plugin "fingscan 2022.37.91"
Starting plugin "fingscan 2022.37.91" (pid 3530)
fingscan initializing ...
fingscan path To files: =================
fingscan detailed logging /Library/Application Support/Perceptive Automation/Indigo 2022.1/Logs/com.karlwachs.fingscan/plugin.log
fingscan testing logging levels, for info only:
fingscan logger enabled for INFO ==> TEST ONLY
fingscan Warning logger enabled for WARNING ==> TEST ONLY
fingscan Error logger enabled for ERROR ==> TEST ONLY
fingscan Error logger enabled for CRITICAL ==> TEST ONLY
fingscan using '/Library/Frameworks/Python.framework/Versions/Current/bin/python3' for utily programs
Started plugin "fingscan 2022.37.91"
fingscan testing if variable enableTimeTracking_fing is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
fingscan debug settings :['all']
fingscan FINGSCAN-- initializing will take ~ 2 minutes..
fingscan indigo variables initialized
fingscan network info: {'netMask': '255.255.255.0', 'netWorkId': '192.168.86.1', 'broadcast': '192.168.86.255', 'hostRange': '192.168.86.1 - 192.168.86.254', 'maxHosts': 254}, netwType:24
fingscan getting password
fingscan get password done; checking if FING is installed
fingscan Warning new dev#: newIPDevNumber:A52<< devV[ipDevice]:03<<
fingscan loaded indigo data
fingscan Warning getting data from indigo: bad variable ipDevice03 does not have a valid IP number>>192.168.86.237-changed<<\ deleting and letting the program recreate it
fingscan Initializing parameters for FING
fingscan Waiting for first data from FING
fingscan
fingscan
Stopping plugin "fingscan 2022.37.91" (pid 3530)
fingscan killing 2
Starting plugin "fingscan 2022.37.91" (pid 3777)
Sun Oct 16, 2022 3:23 pm
should be fixed v version .92 just posted.
Sun Oct 23, 2022 12:03 am
thumpinc offline
That totally fixed it. Thank you so very much! Is there a way I can buy some donuts and coffee or something?
