Error with v7.33.72
Tue May 17, 2022 10:59 am
Monstergerm offline
Error with v7.33.72
I upgraded fingscan and now get this error. The MAC address is for the Wifi of a new laptop. I masked the ID for privacy with xx
fingscan Error ''xx:xx:xx:xx:xx:xx''
getfingData @line 3174: 'if self.fingStatus[kk] == "up" and self.allDeviceInfo[theMAC][u"status"] != u"up":'
Wed May 18, 2022 12:20 pm
Re: Error with v7.33.72
I need a little more info:
1. which mac os
2. mac hardware apple or intel
3. the mac number (you xx:xx:xx..ed) : does the indigo device exist?
Wed May 18, 2022 4:01 pm
Monstergerm offline
Indigo 2022.1 is running on Mac mini macOS 10.14.6
your plugin is v. 7.33.72
I installed the latest Fing-5.5.2-osX package from the fingscan website.
The device that causes an error is a M1 MacBook Pro, running macOS 12.3.1
TheIndigo fingscan device for the Mac number causing problems does not exist.
Mon May 23, 2022 2:51 pm
should be fixed w v .74
Tue May 24, 2022 11:41 am
Monstergerm offline
Great, I don't get the error anymore with this version.
Are you working on a Python 3 version?
There still are a number of odd things:
First, the log shows at startup this. Since my debug settings are Info, I should see the first line only.
fingscan !!!!INFO ONLY!!!! logger enabled for INFO !!!!INFO ONLY!!!!
fingscan Warning !!!!INFO ONLY!!!! logger enabled for WARNING !!!!INFO ONLY!!!!
fingscan Error !!!!INFO ONLY!!!! logger enabled for ERROR !!!!INFO ONLY!!!!
fingscan Error !!!!INFO ONLY!!!! logger enabled for CRITICAL !!!!INFO ONLY!!!!
Second, several devices show up as "Up" with a date of "0".
Third, a few typos in the Config Window:
(2**(32-x)
inbetween
debuuging
Tue May 24, 2022 12:35 pm
>>I should see the first line only.<<
you see info and above in the indigo log. in plugin .log you see thread debug and up
that should go away after a minute
>>(2**(32-x)
added the missing )
this version is working under py 2 and py3 (at least on my mac)
you can try to switch to py3:
edit info.plist
change api version from 2.0 to 3.0
and restart
Screen Shot 2022-05-24 at 20.34.03.png (20.73 KiB) Viewed 1855 times
Tue May 24, 2022 1:34 pm
Monstergerm offline
thanks for the quick response
I switched plugin over to Python 3.
Regarding the '0' for timeOfLastChange, this has been at 0 for more than a day when I installed latest version. It only happens with two devices.
And when does a device switch over to "expired". I have a few devices that have e.g. expired Wifi but they are running.
Mon Jun 06, 2022 10:14 am
Monstergerm offline
Hi Karl,
1) I still have two weeks later several devices showing up as UP with a date of "0".
2) Also, still have several devices showing "expired". The devices are up and running and are still using the IP address that Fingscan shows as expired.
3) And last, whenever I restart the plugin it shows one particular device in the log (I did hide the MAC address).
Any idea what is going on?
EVENT defs:::::::::::::::::: Start :::::::::::::::::
EVENT:------------- 1 --------------------------------------------------------------------------------------------------
dev#: 1 -- devName: iPhone 7 -- MAC#:XX:XX:XX:XX:XX:XX -- ip#:10.0.1.14 -- status:expired -- WiFi:
currentStatusHome: # 1 :0
currentStatusAway: # 1 :0
time WhenLast DOWN: # 1 :0
time WhenLast UP: # 1 :0
seconds WhenLast UP: # 1 :133083027
seconds WhenLast DOWN:# 1 :133083027
Time right now: : 18:32:41
ALL Devices Home :0 -- reacts after minTimeNotHome
AtLeast ONE Device Home :0 -- reacts after minTimeNotHome
n Devices Home :0 -- reacts after minTimeNotHome
ALL Devices Away :0 -- reacts minTimeAway bf Trig
AtLeast ONE Device Away :0 -- reacts minTimeAway bf Trig
n Devices Away :0 -- reacts minTimeAway bf Trig
minTimeAway bf Trig : 300
minTimeNotHome bf re-Trig: 60
Event enabled :0
dataFormat :3.0
EVENT defs:::::::::::::::::: END ::::::::::::::::::
Mon Jun 06, 2022 1:23 pm
I am out for 2 weeks. At lake Como with the whole family, first time in 3 years - for my 65 bd
back on the 19th. Will check then.
Mon Jun 06, 2022 1:35 pm
Monstergerm offline
Wow, I wish I could be there. What a beautiful area. No rush with the plugin and Happy Birthday!
