Help needed on re-configuration
Thu Aug 12, 2021 5:41 pm
Runyan50 offline
I have been using Fingscan for several months. It has been stable and reliable. However, my home wifi was not strong enough for my cell phones to log on until I was already in the house. My main goal is to have Fingscan detect the phone before I enter the house and allow an indigo trigger to turn on garage lights and open the door. I extended my wifi with a Netgrear Nighthawk, and ensured the extended network recognized the cell phones I need to follow.
The problem I am having is that when I try to reconfigure the Fingscan plugin, it tells me that Fing is not running. I have made sure I have both the desktop app running and I am logged into my Fing account. Any advice you can give would be greatly appreciated. Here is the event log:
Starting plugin "fingscan 7.32.65" (pid 35035)
fingscan ========================= initializing ==============================================
fingscan path To files: ==================
fingscan indigo /Library/Application Support/Perceptive Automation/
fingscan installFolder /Library/Application Support/Perceptive Automation/Indigo 2021.1/
fingscan plugin.py /Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/
fingscan Plugin params /Library/Application Support/Perceptive Automation/Indigo 2021.1/Preferences/Plugins/com.karlwachs.fingscan/
fingscan !!!!INFO ONLY!!!! logger enabled for INFO !!!!INFO ONLY!!!!
fingscan Warning !!!!INFO ONLY!!!! logger enabled for WARNING !!!!INFO ONLY!!!!
fingscan Error !!!!INFO ONLY!!!! logger enabled for ERROR !!!!INFO ONLY!!!!
fingscan Error !!!!INFO ONLY!!!! logger enabled for CRITICAL !!!!INFO ONLY!!!!
fingscan check /Library/Application Support/Perceptive Automation/Indigo 2021.1/Logs/com.karlwachs.fingscan/plugin.log <<<< for detailed logging
fingscan Plugin short Name fing
fingscan my PID 35035
fingscan set params for indigo V 2021.1
Started plugin "fingscan 7.32.65"
fingscan testing if variable enableTimeTracking_fing is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
fingscan myLogSet setting parameters -- logFileActive= standard; logFile= ; debug plugin:[]
fingscan FINGSCAN-- initializing will take ~ 2 minutes...; sending logs to
Trigger UpdatedCurrentTemp
fingscan Warning leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
fingscan getting password
fingscan get password done; checking if FING is installed
fingscan mk fing dir: Password:Sorry, try again.
Password:
sudo: no password was provided
sudo: 1 incorrect password attempt
fingscan Warning please corrrect password in config and reload plugin , skipping fing install
fingscan loaded indigo data
fingscan Warning network info: {'netWorkId': '192.168.1.0', 'broadcast': '192.168.1.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '192.168.1.1 - 192.168.1.254'}
fingscan ifind plugin: com.corporatechameleon.iFindplugBeta
fingscan MAP2Vendor initializing
fingscan Initializing parameters for FING
fingscan Error FING not running... quit
fingscan
fingscan switching off SQL logging for variables
:ipDevsLastDevChangedIndigoName; ipDevsLastUpdate; ipDevsNewDeviceNo; ipDevsNewIPNumber;
fingscan switching off SQL logging for variables END
fingscan Error --> setup config, save, then a manual reload of plugin
fingscan --> while loop break stopping ... quitNOW was: please setup config , waiting
fingscan Error --> you have 2 minutes to fix config, before restart
Thu Aug 12, 2021 7:37 pm
Re: Help needed on re-configuration
Can you try to renter the password on config
Fri Aug 13, 2021 9:49 am
Runyan50 offline
Yes, I have entered both the password for the main router, and the password for the extended wifi. Which should I use?
Fri Aug 13, 2021 12:03 pm
Can you switch on all debug areas
Restart plugin
And send me
Plugin.log
File
That’s in the logs sub directory Fingscan
Not the indigo log
Email
Karlwachs at me com
The logfile will have your password in plain text. !!
Fri Aug 13, 2021 4:40 pm
Runyan50 offline
Will do. But I will need to do it tomorrow. Thanks.
Fri Aug 13, 2021 5:22 pm
No problem
I am delayed returning from Europe today - 9 hours sitting in Chicago.
And to Europe it was 28 hours delay in Houston
Don’t remember it being that bad from before COVID.
