Error on MAC Address that isn't on my network
Fri Jan 03, 2020 2:51 pm
ryanbuckner offline
I get the following error. Strangely this MAC is not on my network according to FINGSCAN or my router:
Jan 3, 2020 at 3:35:41 PM
   fingscan Error                  error in  Line '2074' ;  error='u'24:24:0E:AC:89:04''
Tue Jan 07, 2020 8:25 pm
Re: Error on MAC Address that isn't on my network
ryan,
could you check the variables in folder ip devices listing if MAC number "24:24:0E:AC:89:04" is listed there?
and please check fingscan menu / setup events
if there is that device included, if yes please delete
published v .41 that should print a warning if bad MAC# is defined in events
Wed Jan 08, 2020 6:35 pm
ryanbuckner offline
I have confirmed that there are no IP devices in variables that include "24:24:0E:AC:89:04" and there are no events or IP devices with that MAC.
I'll install your update and check. Thanks!
Thu Jan 09, 2020 7:07 pm
could you try v .41.
it should tell in which EVENT the devices with the n on existing MAC number is used.
then go to menu event setup and remove the device there
Sun Jan 12, 2020 9:00 am
ryanbuckner offline
Still monitoring. Error isn't present with this version so far.
Sun Jan 12, 2020 10:04 am
it will not show up as error but as a line in event print:
xxx is not defined, please remove from event# yyy
check plugin.log
