Plugin FINGSCAN not working after Catalina update. Error
Tue Oct 27, 2020 2:12 pm
BillC offline
Re: Plugin FINGSCAN not working after Catalina update. Error
Thanks, Karl
ran sudo /usr/local/fing, saw output, ctrl-c
confirmed that '.../paramsForStart' file exists
ran the py in terminal, resulted in same error message as above (missing fing.data" etc.).
EDIT: Just noticed 3 new files in ../Preferences/Plugins/com.karlwachs.fingscan/ named "setup", "while", "you" all zero bytes.
Tue Oct 27, 2020 3:18 pm
kw123 online
good new is fig seems to work, so it is config.
please down load v .62 (only new debug log options)
in config set debug fingsstart true (9)
restart plugin
post /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.fingscan/plugin.log
only from start to error
and blank the passwords
paramsForStart should look like:
{"macUser": "YOUR ID", "logLevel": 20, "theNetwork": "192.168.1.0", "fingEXEpath": "/usr/local/bin/fing", "yourPassword": your password scrambled ", "netwType": "24"}
and could you delete the files : "setup", "while", "you"
and restart, check if they re-appear.
Tue Oct 27, 2020 3:55 pm
BillC offline
EDIT just noticed that the ip range in the log (and therefore config) was wrong...corrected it and that seems to have fixed the issue.
greatly regret wasting your time :oops:
Log:
2020-10-27 17:38:36 =========================   initializing   ==============================================
2020-10-27 17:38:36 !!!!INFO ONLY!!!!  logger  enabled for   THREADDEBUG   !!!!INFO ONLY!!!!
2020-10-27 17:38:36 !!!!INFO ONLY!!!!  logger  enabled for   DEBUG         !!!!INFO ONLY!!!!
2020-10-27 17:38:36 !!!!INFO ONLY!!!!  logger  enabled for   INFO          !!!!INFO ONLY!!!!
2020-10-27 17:38:36 !!!!INFO ONLY!!!!  logger  enabled for   WARNING       !!!!INFO ONLY!!!!
2020-10-27 17:38:36.668   ERROR          Plugin.__init__                  !!!!INFO ONLY!!!!  logger  enabled for   ERROR         !!!!INFO ONLY!!!!
2020-10-27 17:38:36.668   CRITICAL       Plugin.__init__                  !!!!INFO ONLY!!!!  logger  enabled for   CRITICAL      !!!!INFO ONLY!!!!
2020-10-27 17:38:36 leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
2020-10-27 17:38:36 indigo variables initialized
2020-10-27 17:38:36 getting password
2020-10-27 17:38:36 get password done;  checking if FING is installed
2020-10-27 17:38:37 fing install check done
2020-10-27 17:38:38 loaded indigo data
2020-10-27 17:38:38 network info: {'netWorkId': '10.12.1.0', 'broadcast': '10.12.1.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '10.12.1.1 - 10.12.1.254'}
2020-10-27 17:38:38 ifind plugin: com.corporatechameleon.iFindplugBeta
2020-10-27 17:38:38 MAP2Vendor initializing
2020-10-27 17:38:38 Initializing parameters for FING
startfing               L:234 Lv:20 ========= start   @ 2020-10-27 17:38:39.972550   ===========
startfing               L:248 Lv:40 echo '###########' | sudo -S /bin/rm '/Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.fingscan/fing.data'
startfing               L:251 Lv:40 echo '###########' | sudo -S /bin/rm '/Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.fingscan/fing.log'
startfing               L: 57 Lv:20 chk versions.opsys: 10.14;   fingVersion:2.2 from cmd:echo '###########' | sudo -S /usr/local/bin/fing -v;
startfing               L: 34 Lv:20 fing.bin launched, version: 2.2,  opsys: 10.14
startfing               L:256 Lv:20 ========= stopped @ 2020-10-27 17:38:40.984167   ===========
2020-10-27 17:38:41 Waiting for first data from FING
2020-10-27 17:39:01.996   ERROR          Plugin.initFing                  error in  Line# 2956 ;  error=[Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.fingscan/fing.data'
2020-10-27 17:39:01.996   ERROR          Plugin.initConfig                 FING not running... quit
paramsForStart looks like your example
deleted 3 files and restarted plugin
they did not reappear however as plugin started watched fing.data be created, fing.data and fing.log deleted, fing.log (only) re-created.
Appreciate the help....
Bill
Tue Oct 27, 2020 5:13 pm
kw123 online
please try v.64 have added a try except around the date time check for the file.
Tue Oct 27, 2020 5:24 pm
BillC offline
Will do but did you see my edit above where the problem seems to have been a bad (ie, wouldn't be found) ip range in config?
Tue Oct 27, 2020 5:29 pm
kw123 online
Ok. But I should have added that time. Check anyway.
Tue Oct 27, 2020 7:14 pm
BillC offline
64 looks ok at first load...let me know if there's anything you want me to bang it against.
Tue Oct 27, 2020 9:13 pm
kw123 online
u don't need to do anything if it works fine
