New Error after updating plugin
Sat Nov 30, 2019 1:35 pm
dnomode offline
Hello Karl,
My system has been running for months without me doing anything. Well last week I decided to update all my plugins and now I'm getting the following errors from FingScan.
   Enabling plugin "fingscan 7.30.37"
   Starting plugin "fingscan 7.30.37" (pid 73149)
   fingscan                        initializing    ...
   fingscan                        path To files:          =================
   fingscan                        indigo                  /Library/Application Support/Perceptive Automation/
   fingscan                        installFolder           /Library/Application Support/Perceptive Automation/Indigo 7.4/
   fingscan                        plugin.py               /Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/
   fingscan                        Plugin params           /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.fingscan/
   fingscan                        !!!!INFO ONLY!!!!  logger  enabled for   INFO          !!!!INFO ONLY!!!!
   fingscan Warning                !!!!INFO ONLY!!!!  logger  enabled for   WARNING       !!!!INFO ONLY!!!!
   fingscan Error                  !!!!INFO ONLY!!!!  logger  enabled for   ERROR         !!!!INFO ONLY!!!!
   fingscan Critical Error         !!!!INFO ONLY!!!!  logger  enabled for   CRITICAL      !!!!INFO ONLY!!!!
   fingscan                        check                   /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.fingscan/plugin.log  <<<<    for detailed logging
   fingscan                        Plugin short Name       fing
   fingscan                        my PID                  73149
   fingscan                        set params for indigo V 7.4
   Started plugin "fingscan 7.30.37"
   fingscan                        testing if variable enableTimeTracking_fing is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
   fingscan                        myLogSet setting parameters -- logFileActive= standard; logFile= ;  debug plugin:[]
   fingscan                        FINGSCAN--   initializing     will take ~ 2 minutes...; sending logs to
   fingscan Warning                leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
   fingscan                        getting password
   fingscan                        get password done;  checking if FING is installed
   fingscan                        fing install check done
   fingscan                        loaded indigo data
   fingscan Error                  error in  Line '552' ;  error='local variable 'ok' referenced before assignment'
Nov 30, 2019 at 2:15:19 PM
   fingscan Error                  error in  Line '4339' ;  error=''Plugin' object has no attribute 'enableMACtoVENDORlookup''
   fingscan                        FINGSCAN initialized
   fingscan Error                  error in  Line '895' ;  error=''Plugin' object has no attribute 'piBeaconDevices''
   fingscan Error                  error in  Line '1338' ;  error=''Plugin' object has no attribute 'piBeaconDevices''
   fingscan Error                  error in  Line '917' ;  error=''Plugin' object has no attribute 'unifiDevices''
   fingscan Error                  error in  Line '1381' ;  error=''Plugin' object has no attribute 'unifiDevices''
Nov 30, 2019 at 2:19:59 PM
   fingscan Error                  seems that FING is not active - no change in data, restarting fing, seconds since last change: 280.411128044
Nov 30, 2019 at 2:20:23 PM
   fingscan                        FING initializing checking if output created, old date:1574117200.0; new date:1574117200.0
Nov 30, 2019 at 2:20:43 PM
Nov 30, 2019 at 2:21:03 PM
   fingscan                        FING initializing checking if output created, old date:1574117200.0; new date:1575141647.0
   fingscan                        FING initialized ..  created new data   waiting ~ 1 minute for stable operation
   fingscan Warning                  FING pids 3= ['74273']
   fingscan Warning                   (re)started FING
   fingscan Warning                FING initialized
   fingscan                        fing restarted successfully
The option for "use piBeacon and use Unifi devices" is disabled, so I'm not sure what attributes it's looking for. FYI: I am using your Unifi plugin, however Im not sure why I never enabled it here in FingScan.
You can see my setting at the bellow link
https://www.dropbox.com/s/ysh2k4lk76o9qxg/Screenshot%202019-11-30%2014.29.42.png?dl=0
Any ideas?
Thanks for your help.
Edmond
Sat Nov 30, 2019 2:00 pm
Re: New Error after updating plugin
I am out of town. Can check may be at night or next Monday.
Did you upgrade your os?
Sat Nov 30, 2019 2:15 pm
dnomode offline
No worries, Whenever you get a chance is great.
No I did not upgrade the OS.
I also posted about the Unifi plugin.
Edmond
Wed Dec 04, 2019 1:51 pm
siclark offline
I have a similar issue. Mine keeps restarting but complains about a password not being set, and also times out accessing the config. I have deleted the plugin and prefs, restarted the server and downloaded a new version and still get the same problem.
I also run unifi and pibeacon.
Any ideas, I would like to get back to using this to track network devices as unifi doesnt give me a trigger on new devices on network.
Wed Dec 04, 2019 3:01 pm
Could you post / send the plugin.log file
Wed Dec 04, 2019 3:13 pm
just FYI: Unifi populates a variable- Unifi_new_Device:
Screen Shot 2019-12-04 at 15.14.06.png (16.77 KiB) Viewed 3543 times
it shows any new device-name/mac#/ip#
as well as which device has ip number changed and status changed
Wed Dec 04, 2019 3:19 pm
siclark offline
Here you go... my network is 192.168.0.0 not 1.0 but I cannot change that as can't access the config.
2019-12-04 09:35:34 !!!!INFO ONLY!!!!  logger  enabled for   THREADDEBUG   !!!!INFO ONLY!!!!
2019-12-04 09:35:34 !!!!INFO ONLY!!!!  logger  enabled for   DEBUG         !!!!INFO ONLY!!!!
2019-12-04 09:35:34 !!!!INFO ONLY!!!!  logger  enabled for   INFO          !!!!INFO ONLY!!!!
2019-12-04 09:35:34 !!!!INFO ONLY!!!!  logger  enabled for   WARNING       !!!!INFO ONLY!!!!
2019-12-04 09:35:34.689   ERROR          Plugin.__init__                  !!!!INFO ONLY!!!!  logger  enabled for   ERROR         !!!!INFO ONLY!!!!
2019-12-04 09:35:34.689   CRITICAL       Plugin.__init__                  !!!!INFO ONLY!!!!  logger  enabled for   CRITICAL      !!!!INFO ONLY!!!!
2019-12-04 09:35:34 indigo variables initialized
2019-12-04 09:35:34 getting password
2019-12-04 09:35:34.804   ERROR          Plugin.startup                   password error please enter password in configuration menue, otherwise FING can not be started
2019-12-04 09:35:34 get password done;  checking if FING is installed
2019-12-04 09:35:36 fing install check done
2019-12-04 09:35:37 loaded indigo data
2019-12-04 09:35:37 network info: {'netWorkId': '192.168.1.0', 'broadcast': '192.168.1.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '192.168.1.1 - 192.168.1.254'}
2019-12-04 09:35:37 ifind plugin: com.corporatechameleon.iFindplugBeta
2019-12-04 09:35:37 MAP2Vendor initializing
2019-12-04 09:35:38 FING initializing parameters
2019-12-04 09:36:00 FING initializing checking if output created, old date:1574553746.07; new date:1574553746.07
2019-12-04 09:36:20 FING initializing checking if output created, old date:1574553746.07; new date:1574553746.07
2019-12-04 09:36:40 FING initializing checking if output created, old date:1574553746.07; new date:1574553746.07
2019-12-04 09:37:00 FING initializing checking if output created, old date:1574553746.07; new date:1574553746.07
2019-12-04 09:37:20 FING initializing checking if output created, old date:1574553746.07; new date:1574553746.07
2019-12-04 09:37:20.373   ERROR          Plugin.startup                    fing not running... quit
2019-12-04 09:37:20 settings:  iDevicesEnabled              False
2019-12-04 09:37:20 settings:  inbetweenPingType            0
2019-12-04 09:37:20 settings:  wifiRouter                   0
2019-12-04 09:37:20 settings:  wait seconds between cycles  1
2019-12-04 09:37:20 settings:  password entered             False
2019-12-04 09:37:20 settings:  debugLevel                   []
2019-12-04 09:37:20 settings:  FINGSCAN will scan Network   192.168.1....  # fixed bits in ip range:24
2019-12-04 09:37:20
2019-12-04 09:37:20
EVENT defs::::::::::::::::::
2019-12-04 09:37:20
===      piBeacon devices  available  to fingscan    ===        START
--Device Name------        indigoID--    --Status  lastUpdate  used
Pi 0 - Server              997932718           up    09:35:37     0
Pi 1 - Study wired         722488179           up    09:35:37     0
Pi 2 - Living Room         1582644556          up    09:35:37     0
Pi 3 - Kitchen             787354666           up    09:35:37     0
Pi 4 - Dining Room         11158563            up    09:35:37     0
Pi 5 - Twins room          1765320499          up    09:35:37     0
piBeacon - Car             1852840837          up    09:35:37     0
piBeacon - Cat iPhone      138578287            0    09:35:37     0
piBeacon - Green tag       1681525503           0    09:35:37     0
piBeacon - Simon iPhone    607891826           up    09:35:37     0
===      piBeacon devices  available  to fingscan    ===        END
2019-12-04 09:37:20
===      Unifi   devices  available  to fingscan    ===        START
AP_78:8a:20:b3:cc:4f       485256108           up    09:35:37     0
AP_f0:9f:c2:a9:d8:71       1090346603          up    09:35:37     0
AP_f0:9f:c2:f3:2c:27       1577176180          up    09:35:37     0
all my unify devices...
rPi Dining Room Unifi      1511612824          up    09:35:37     0
rPi Kitchen Unifi          1694369651           0    09:35:37     0
rPi Study Unifi            341523966           up    09:35:37     0
rPi Twins room Unifi       80433793            up    09:35:37     0
rPiZero Unifi              1522574034          up    09:35:37     0
===      unifi devices  available  to fingscan    ===        END
2019-12-04 09:37:20 getting vendor info
2019-12-04 09:37:25 --> while loop break  stopping ...  quitNOW was:fing not running
2019-12-04 09:37:25 stopConcurrentThread called 2
2019-12-04 09:37:28 !!!!INFO ONLY!!!!  logger  enabled for   THREADDEBUG   !!!!INFO ONLY!!!!
2019-12-04 09:37:28 !!!!INFO ONLY!!!!  logger  enabled for   DEBUG         !!!!INFO ONLY!!!!
2019-12-04 09:37:28 !!!!INFO ONLY!!!!  logger  enabled for   INFO          !!!!INFO ONLY!!!!
2019-12-04 09:37:28 !!!!INFO ONLY!!!!  logger  enabled for   WARNING       !!!!INFO ONLY!!!!
2019-12-04 09:37:28.611   ERROR          Plugin.__init__                  !!!!INFO ONLY!!!!  logger  enabled for   ERROR         !!!!INFO ONLY!!!!
2019-12-04 09:37:28.611   CRITICAL       Plugin.__init__                  !!!!INFO ONLY!!!!  logger  enabled for   CRITICAL      !!!!INFO ONLY!!!!
2019-12-04 09:37:28 indigo variables initialized
2019-12-04 09:37:28 getting password
2019-12-04 09:37:28.735   ERROR          Plugin.startup                   password error please enter password in configuration menue, otherwise FING can not be started
2019-12-04 09:37:28 get password done;  checking if FING is installed
2019-12-04 09:37:30 fing install check done
2019-12-04 09:37:31 loaded indigo data
2019-12-04 09:37:31 network info: {'netWorkId': '192.168.1.0', 'broadcast': '192.168.1.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '192.168.1.1 - 192.168.1.254'}
2019-12-04 09:37:31 ifind plugin: com.corporatechameleon.iFindplugBeta
2019-12-04 09:37:31 MAP2Vendor initializing
2019-12-04 09:37:31 FING initializing parameters
2019-12-04 09:37:54 FING initializing checking if output created, old date:1574553746.07; new date:1574553746.07
2019-12-04 09:38:14 FING initializing checking if output created, old date:1574553746.07; new date:1574553746.07
2019-12-04 09:38:34 FING initializing checking if output created, old date:1574553746.07; new date:1574553746.07
2019-12-04 09:38:54 FING initializing checking if output created, old date:1574553746.07; new date:1574553746.07
2019-12-04 09:39:14 FING initializing checking if output created, old date:1574553746.07; new date:1574553746.07
2019-12-04 09:39:14.124   ERROR          Plugin.startup                    fing not running... quit
2019-12-04 09:39:14 settings:  iDevicesEnabled              False
2019-12-04 09:39:14 settings:  inbetweenPingType            0
2019-12-04 09:39:14 settings:  wifiRouter                   0
2019-12-04 09:39:14 settings:  wait seconds between cycles  1
2019-12-04 09:39:14 settings:  password entered             False
2019-12-04 09:39:14 settings:  debugLevel                   []
2019-12-04 09:39:14 settings:  FINGSCAN will scan Network   192.168.1....  # fixed bits in ip range:24
2019-12-04 09:39:14
2019-12-04 09:39:14
Wed Dec 04, 2019 4:30 pm
that's a catch 22..
can't find password,
then fing is not starting,
then restart
I can put some time.sleep(120) in to give you 2 minutes to edit config
later tonight
Wed Dec 04, 2019 6:50 pm
please checkout v .39 posted on the plugin store.
you need to:
- download .. (make sure name is not ....-2 in the download folder)
-(re)- load,
-wait 10 secs
-then edit config
-and save
-manual reload of plugin
that should do it.
Thu Dec 05, 2019 7:28 am
ryanbuckner offline
I just updated and see errors too:
   Indigo Cocoa client authenticated (192.168.1.1)
   fingscan                        FING initializing checking if output created, old date:1575552386.0; new date:1575552396.0
   fingscan Warning                  FING pids 3= ['435']
   fingscan Error                  error in  Line '2074' ;  error='u'24:24:0E:AC:89:04''
Thu Dec 05, 2019 9:26 am
@ ryanbuckner:
do you see any other errors?
it looks as if you can enter password ..
and could you share the plugin.log file, it gives more details..
and always post the version and the first line from the plugin in the logs
I assume its v 7.30.39?
Thu Dec 05, 2019 4:01 pm
siclark offline
Thanks, its working now.
Sat Dec 07, 2019 2:06 pm
ryanbuckner offline
That's the only error:
Dec 7, 2019 at 3:05:08 PM
   Reloading plugin "fingscan 7.30.39"
   Stopping plugin "fingscan 7.30.39" (pid 46503)
   fingscan Warning                stopConcurrentThread called 1
   fingscan                        exception StopThread triggered ... stopped,  quitNOW was:no
   fingscan Warning                stopConcurrentThread called 2
   fingscan Warning                shutdown called
   Stopped plugin "fingscan 7.30.39"
   Starting plugin "fingscan 7.30.39" (pid 74278)
   fingscan                        my PID                  74278
   Started plugin "fingscan 7.30.39"
   SQL Logger                      deleting table variable_history_1907862106
   SQL Logger                      creating table variable_history_804861814 for "ipDevsLastUpdate"
   SQL Logger                      deleting table variable_history_973553153
   SQL Logger                      creating table variable_history_1815307860 for "ipDevsLastDevChangedIndigoName"
   SQL Logger                      deleting table variable_history_831027968
   SQL Logger                      creating table variable_history_1507122301 for "ipDevsNewDeviceNo"
   SQL Logger                      deleting table variable_history_1648915879
   SQL Logger                      creating table variable_history_625123570 for "ipDevsNewIPNumber"
   SQL Logger                      deleting table variable_history_1664098314
   SQL Logger                      creating table variable_history_1865468818 for "ipDevsNoOfDevices"
   fingscan                        network info: {'netWorkId': '192.168.1.0', 'broadcast': '192.168.1.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '192.168.1.1 - 192.168.1.254'}
   fingscan                        ifind plugin: com.corporatechameleon.iFindplugBeta
   fingscan                        MAP2Vendor initializing
   fingscan                        FING initializing parameters
   SQL Logger                      deleting table variable_history_69319642
   SQL Logger                      creating table variable_history_1125853831 for "FingEventDevChangedIndigoId"
Dec 7, 2019 at 3:05:38 PM
   fingscan                        FING initializing checking if output created, old date:1575749056.0; new date:1575749120.0
   fingscan Warning                  FING pids 3= ['74334']
Sat Dec 07, 2019 2:32 pm
That means that device was not available.
If it happens just once you can ignore.
