- Posted on
Thu Nov 07, 2019 3:13 pm
racarter
offline
Got a bunch of errors...
- Code: Select all
Starting plugin "fingscan 7.30.36" (pid 88778)
fingscan initializing ...
fingscan path To files: =================
fingscan indigo /Library/Application Support/Perceptive Automation/
fingscan installFolder /Library/Application Support/Perceptive Automation/Indigo 7.4/
fingscan plugin.py /Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/
fingscan Plugin params /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.fingscan/
fingscan !!!!INFO ONLY!!!! logger enabled for INFO !!!!INFO ONLY!!!!
fingscan Warning !!!!INFO ONLY!!!! logger enabled for WARNING !!!!INFO ONLY!!!!
fingscan Error !!!!INFO ONLY!!!! logger enabled for ERROR !!!!INFO ONLY!!!!
fingscan Critical Error !!!!INFO ONLY!!!! logger enabled for CRITICAL !!!!INFO ONLY!!!!
fingscan check /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.fingscan/plugin.log <<<< for detailed logging
fingscan Plugin short Name fing
fingscan my PID 88778
fingscan set params for indigo V 7.4
Trigger Error in Event Log
Started plugin "fingscan 7.30.36"
fingscan testing if variable enableTimeTracking_fing is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
fingscan myLogSet setting parameters -- logFileActive= standard; logFile= ; debug plugin:[]
fingscan FINGSCAN-- initializing will take ~ 2 minutes...; sending logs to
fingscan Warning leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
fingscan getting password
fingscan get password done; checking if FING is installed
fingscan fing install check done
SQL Logger creating table variable_history_1464613259 for "ipDevsLastUpdate"
SQL Logger creating table variable_history_1365220624 for "ipDevsLastDevChangedIndigoName"
SQL Logger creating table variable_history_1882811222 for "ipDevsNewDeviceNo"
SQL Logger creating table variable_history_1437099763 for "ipDevsNewIPNumber"
SQL Logger creating table variable_history_231475993 for "ipDevsNoOfDevices"
fingscan Error getting data from indigo: bad variable ipDevice54
MAC number does not seem to be real MAC number
please check if it has bad data, in doubt delete and let the program recreate
stopping fingscan
fingscan Error updateIndigoIpVariableFromDeviceData indigoEmpty not initialized[]
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# 68:FE:F7:44:84:82
fingscan Error updateIndigoIpVariableFromDeviceData indigoIpVariableData{'status': 'down', 'suppressChangeMSG': 'show', 'index': 0, 'nickName': 'iphonexyz', 'WiFi': '', 'deviceInfo': '', 'noOfChanges': 0, 'ipDevice': '00', 'WiFiSignal': '0', 'hardwareVendor': '', 'timeOfLastChange': '0', 'usePing': '', 'ipNumber': '0.0.0.0', 'variableName': ''}
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# 4C:56:9D:7A:AA:AC
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# C0:A6:00:BB:D2:58
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# F0:81:73:93:C8:87
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# 00:11:32:96:1D:F7
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# CC:F7:35:DB:1E:0F
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# 50:7A:C5:56:49:9B
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# 78:28:CA:1E:B0:4A
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# 00:15:99:8C:F8:73
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# B4:E6:2A:D2:92:5E
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# 34:7E:5C:00:26:B2
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# 3C:15:C2:BC:26:54
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# 74:DA:38:26:9D:05
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# B8:27:EB:8D:E3:A5
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# B8:27:EB:02:26:B7
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# 20:F1:9E:04:4B:AE
fingscan Error updateIndigoIpVariableFromDeviceData theMAC# 70:EE:50:2C:AC:B2
fingscan loaded indigo data
fingscan network info: {'netWorkId': '192.168.0.0', 'broadcast': '192.168.0.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '192.168.0.1 - 192.168.0.254'}
fingscan ifind plugin: com.corporatechameleon.iFindplugBeta
fingscan MAP2Vendor initializing
stopping fingscan
SQL Logger creating table variable_history_1785203357 for "FingEventDevChangedIndigoId"
fingscan FING initializing parameters
Schedule Error in Event Log (delayed action)
- Posted on
Thu Nov 07, 2019 3:25 pm
offline
could we do an online session, this is to complex to fix in batch mode ..
teamviewer? .. send me an email to karl wachs me com with the login info ..
- Posted on
Thu Nov 07, 2019 3:44 pm
offline
... could you post variable: ipDevice54
if empty, delete and restart fingscan
- Posted on
Thu Nov 07, 2019 3:47 pm
racarter
offline
IpDevice54 value is currently
- Code: Select all
; 192.168.0.2 ; 2019-09-20 15:54:32 ;up; 260 ; new-0- ; ; ; ; ; usePingUP-0;
- Posted on
Thu Nov 07, 2019 3:48 pm
racarter
offline
I'm installing Teamviewer...
- Posted on
Thu Nov 07, 2019 3:51 pm
offline
the variable should start w the mac # that's empty, just delete it and restart fingscan.. is that the last # or is it in the middle of the variables?
- Posted on
Thu Nov 07, 2019 3:57 pm
racarter
offline
Email bounced (?) - PMed you instead.
- Posted on
Thu Nov 07, 2019 4:01 pm
offline
posted a version ... .37 that does that automatically.
- Posted on
Thu Nov 07, 2019 4:07 pm
racarter
offline
Looks good so far. Thanks Karl - I'll keep an eye and drop you a line if I see any problems.
- Posted on
Thu Nov 07, 2019 4:18 pm
offline
Thanks for testing
Q why was the variable bad?
If you have not done it manually there is a problem somewhere.
- Posted on
Thu Nov 07, 2019 4:36 pm
racarter
offline
No idea. I certainly didn’t enter anything manually.
