Fing.bin not verified?
Tue Oct 15, 2019 8:28 am
steplad86 offline
Yesterday I upgraded from Mojave to Catalina. As soon as I started indigo, I began getting the message ' "fing.bin" cannot be opened because the developer cannot be verified.' I have found the file 'fing.bin' but do not know how to verify the file. Fingscan was working fine before I did the upgrade. Any help you can give me will be appreciated.
Tue Oct 15, 2019 9:39 am
Re: Fing.bin not verified?
Try this:
Is it safe...to upgrade to Catalina?
https://r.tapatalk.com/shareLink?share_ ... are_type=t
Tue Oct 15, 2019 12:19 pm
racarter offline
Accept the error message in System Preferences > Security and Privacy. You'll need to do this 5 or 6 times, restarting the plugin after each acceptance.
Tue Oct 15, 2019 12:49 pm
I believe I can add that command to the plugin which would do it before fing is called. But I am out until nov 4
Karl.
Thu Oct 17, 2019 9:29 am
racarter ,
could you create an indigo action group/ execute script and paste:
yourPassword ="xxxxx"
ret = subprocess.Popen("echo '"+yourPassword+ "' | sudo -S  sudo xattr -rd com.apple.quarantine /usr/local/bin/fing ",shell=True,stdout=subprocess.PIPE,stderr=subprocess.PIPE).communicate()
indigo.server.log(unicode(ret))
put you password in and execute /run
check if that creates any error messages, or better post the log file output.
if that does the trick I can put it into the fingscan plugin -- and some others too that call other included programs
Thu Oct 17, 2019 9:40 am
racarter offline
Hi Karl
The script produces an error message:
embedded script: global name 'subprocess' is not defined
Regards
Alan
Thu Oct 17, 2019 9:42 am
this should do it...
import subprocess
Thu Oct 17, 2019 9:44 am
racarter offline
Haha - I realised just after I'd sent the message! Added the import and got:
Script ('', 'Password:sudo: sudo: command not found\n')
Thu Oct 17, 2019 10:26 am
replace
sudo
with
/usr/bin/sudo
import subprocess
ret = subprocess.Popen("echo '"+yourPassword+ "' | /usr/bin/sudo -S  /usr/bin/sudo xattr -rd com.apple.quarantine /usr/local/bin/fing ",shell=True,stdout=subprocess.PIPE,stderr=subprocess.PIPE).communicate()
Thu Oct 17, 2019 10:48 am
racarter offline
Result:
 Script                          ('', 'Password:')
Thu Oct 17, 2019 10:53 am
That seems to be ok I believe.
Will add that to the plugin
Thu Oct 17, 2019 10:54 am
racarter offline
Sun Nov 03, 2019 8:30 am
Rjay offline
hey there, did this end up getting put into the plugin?
There didn't seem to be updates indicated in Indigo but the code fix above does seem to have worked to resolve the issue.
thanks
Sun Nov 03, 2019 8:31 am
Back home tomorrow evening. Should have something ready 2 days later.
Thu Nov 07, 2019 2:41 pm
racanter, Rjay:
could you please be so kind and check the new version just posted. I should work under catalina
