Fing.bin not verified?
Thu Nov 07, 2019 3:13 pm
racarter offline
Re: Fing.bin not verified?
Got a bunch of errors...
   Starting plugin "fingscan 7.30.36" (pid 88778)
   fingscan                        initializing    ...
   fingscan                        path To files:          =================
   fingscan                        indigo                  /Library/Application Support/Perceptive Automation/
   fingscan                        installFolder           /Library/Application Support/Perceptive Automation/Indigo 7.4/
   fingscan                        plugin.py               /Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/
   fingscan                        Plugin params           /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.fingscan/
   fingscan                        !!!!INFO ONLY!!!!  logger  enabled for   INFO          !!!!INFO ONLY!!!!
   fingscan Warning                !!!!INFO ONLY!!!!  logger  enabled for   WARNING       !!!!INFO ONLY!!!!
   fingscan Error                  !!!!INFO ONLY!!!!  logger  enabled for   ERROR         !!!!INFO ONLY!!!!
   fingscan Critical Error         !!!!INFO ONLY!!!!  logger  enabled for   CRITICAL      !!!!INFO ONLY!!!!
   fingscan                        check                   /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.fingscan/plugin.log  <<<<    for detailed logging
   fingscan                        Plugin short Name       fing
   fingscan                        my PID                  88778
   fingscan                        set params for indigo V 7.4
   Trigger                         Error in Event Log
   Started plugin "fingscan 7.30.36"
   fingscan                        testing if variable enableTimeTracking_fing is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
   fingscan                        myLogSet setting parameters -- logFileActive= standard; logFile= ;  debug plugin:[]
   fingscan                        FINGSCAN--   initializing     will take ~ 2 minutes...; sending logs to
   fingscan Warning                leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
   fingscan                        getting password
   fingscan                        get password done;  checking if FING is installed
   fingscan                        fing install check done
   SQL Logger                      creating table variable_history_1464613259 for "ipDevsLastUpdate"
   SQL Logger                      creating table variable_history_1365220624 for "ipDevsLastDevChangedIndigoName"
   SQL Logger                      creating table variable_history_1882811222 for "ipDevsNewDeviceNo"
   SQL Logger                      creating table variable_history_1437099763 for "ipDevsNewIPNumber"
   SQL Logger                      creating table variable_history_231475993 for "ipDevsNoOfDevices"
   fingscan Error                  getting data from indigo: bad variable ipDevice54
  MAC number does not seem to be real MAC number
   please check if it has bad data, in doubt delete and let the program recreate
  stopping fingscan
   fingscan Error                  updateIndigoIpVariableFromDeviceData indigoEmpty not initialized[]
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# 68:FE:F7:44:84:82
   fingscan Error                  updateIndigoIpVariableFromDeviceData indigoIpVariableData{'status': 'down', 'suppressChangeMSG': 'show', 'index': 0, 'nickName': 'iphonexyz', 'WiFi': '', 'deviceInfo': '', 'noOfChanges': 0, 'ipDevice': '00', 'WiFiSignal': '0', 'hardwareVendor': '', 'timeOfLastChange': '0', 'usePing': '', 'ipNumber': '0.0.0.0', 'variableName': ''}
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# 4C:56:9D:7A:AA:AC
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# C0:A6:00:BB:D2:58
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# F0:81:73:93:C8:87
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# 00:11:32:96:1D:F7
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# CC:F7:35:DB:1E:0F
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# 50:7A:C5:56:49:9B
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# 78:28:CA:1E:B0:4A
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# 00:15:99:8C:F8:73
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# B4:E6:2A:D2:92:5E
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# 34:7E:5C:00:26:B2
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# 3C:15:C2:BC:26:54
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# 74:DA:38:26:9D:05
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# B8:27:EB:8D:E3:A5
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# B8:27:EB:02:26:B7
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# 20:F1:9E:04:4B:AE
   fingscan Error                  updateIndigoIpVariableFromDeviceData theMAC# 70:EE:50:2C:AC:B2
   fingscan                        loaded indigo data
   fingscan                        network info: {'netWorkId': '192.168.0.0', 'broadcast': '192.168.0.255', 'netMask': '255.255.255.0', 'maxHosts': 254, 'hostRange': '192.168.0.1 - 192.168.0.254'}
   fingscan                        ifind plugin: com.corporatechameleon.iFindplugBeta
   fingscan                        MAP2Vendor initializing
  stopping fingscan
   SQL Logger                      creating table variable_history_1785203357 for "FingEventDevChangedIndigoId"
   fingscan                        FING initializing parameters
   Schedule                        Error in Event Log (delayed action)
Thu Nov 07, 2019 3:25 pm
could we do an online session, this is to complex to fix in batch mode ..
teamviewer? .. send me an email to karl wachs me com with the login info ..
Thu Nov 07, 2019 3:44 pm
... could you post variable: ipDevice54
if empty, delete and restart fingscan
Thu Nov 07, 2019 3:47 pm
racarter offline
IpDevice54 value is currently
        ;   192.168.0.2       ;   2019-09-20 15:54:32   ;up;           260           ;   new-0-                        ;                           ;                           ;     ;          ;  usePingUP-0;
Thu Nov 07, 2019 3:48 pm
racarter offline
I'm installing Teamviewer...
Thu Nov 07, 2019 3:51 pm
the variable should start w the mac # that's empty, just delete it and restart fingscan.. is that the last # or is it in the middle of the variables?
Thu Nov 07, 2019 3:57 pm
racarter offline
Email bounced (?) - PMed you instead.
Thu Nov 07, 2019 4:01 pm
posted a version ... .37 that does that automatically.
Thu Nov 07, 2019 4:07 pm
racarter offline
Looks good so far. Thanks Karl - I'll keep an eye and drop you a line if I see any problems.
Thu Nov 07, 2019 4:18 pm
Thanks for testing
Q why was the variable bad?
If you have not done it manually there is a problem somewhere.
Thu Nov 07, 2019 4:36 pm
racarter offline
No idea. I certainly didn’t enter anything manually.
