I've only just finally started setting up fingscan. I'm getting a recurring issue where it keeps thinking an IP address is changing:
- Code: Select all
fingscan IPNumber changed, old: 192.168.1.001 ; new: 192.168.1.117 for device MAC#: 70:56:81:C5:AB:47 to switch off changed message: edit this device and select no msg
fingscan MAC#:70:56:81:C5:AB:47 -- old IP: 192.168.1.117 ; new IP number: 192.168.1.001 to switch off changed message: edit this device and select no msg
fingscan MAC#:70:56:81:C5:AB:47 -- old IP: 192.168.1.001 ; new IP number: 192.168.1.117 to switch off changed message: edit this device and select no msg
It does this for 20-30 entries in the log over the space of half an hour or so, then stops. Then at some random time later it starts again. Now 70:56:81:C5:AB:47 is the MAC address of my Airport base station and has a fixed IP of 192.168.1.001. 192.168.1.117 is that of my MacBook Pro. I’m at a loss as to why it keeps thinking this is happening. It’s not like 70:56:81:C5:AB:47 is listed in the DHCP reservation table twice, and even if it was the base station is still set to a fixed IP of .001. Any ideas?
