FINGSCAN plug-in hanging?
Mon Feb 26, 2018 10:18 pm
AlaskaDave offline
I've noticed lately that when viewing the Mac OS application it indicates "Stopping plug-in" in the status area with fingscan apparently the culprit.
When it becomes running, again usually when I access the server using the iOS application it then suddenly updates the Event Log with what has occurred since stopping.
Is this a behavior that others are seeing?
Tue Feb 27, 2018 12:09 am
Re: FINGSCAN plug-in hanging?
could you post versions (fingscan, osx, indigo ..) and the exact log entries?
Tue Feb 27, 2018 12:23 am
AlaskaDave offline
Thank you. Below is what you requested:
fingscan plugin: 7.24.21
osx: 10.9.5
Indigo Version: 7.1.1
Log at time of stall:
Feb 26, 2018, 12:19:00 AM
fingscan --> while loop beaking stooping ... quitNow was: reboot after midnight
Reloading plugin "fingscan 7.24.21"
Stopping plugin "fingscan 7.24.21" (pid 2716)
fingscan stopConcurrentThread called 2
fingscan stopConcurrentThread called 3
fingscan shutdown called
Tue Feb 27, 2018 12:42 am
That is a normal message. Auto restart at Midnight.
What happens then?
Tue Feb 27, 2018 11:38 am
AlaskaDave offline
The MacOS desktop application for Indigo becomes unresponsive. The status indicates "stopping plug-in" and the event log shows this shutdown process as being the last item. I can "click around" in the Indigo interface and it takes several seconds to minutes for it to unfreeze. Sometimes hitting the server with the iOS application seems to get it un-constipated. :?
Tue Feb 27, 2018 6:00 pm
No clue how to diagnose this or fix. Have to think about.
Essentially the plugin stops and waits for indigo to restart it.
Tue Feb 27, 2018 6:02 pm
AlaskaDave offline
It's been awhile since behavior and was fine this morning. I had a network extender that seemed to be causing issues elsewhere so have removed, perhaps that was the culprit. Will post here after a few days or if it happens again. Thanks.
Tue Feb 27, 2018 6:36 pm
https://www.dropbox.com/s/i1bmjg53yo7ofrm/fingscan-v-7.22.22.zip?dl=1
Could you try this one. It has:
1. version check enabled ( once day at~ 14:40, not important for this)
2. "soft restart" menu item. This does the same as the midnight restart. Could you click on the menu / last item. it should then do the same as at midnight. just for testing. so we can try to trigger the issue manually.
Wed Feb 28, 2018 1:49 pm
AlaskaDave offline
Karl, would downgrading cause any issues elsewhere? Would you suggest installing and performing those steps to see if I can repeat the issue then reinstall 7.24.21?
Wed Feb 28, 2018 5:19 pm
that should read: 7.24.22
just the name is wrong
will fix download
use the latest , v # fixed
https://www.indigodomo.com/pluginstore/72/
Sun Mar 11, 2018 5:05 pm
jheddings offline
I ran into a similar issue on a fresh instal of fingscan today... The application hung until fingscan error out. Just posting in case it helps troubleshoot issues.
This is on a development laptop (not my primary Indigo server).
OS: 10.13.3
Indigo: 7.1.1
Here is what was posted in the event log:
   Starting plugin "fingscan 7.24.23" (pid 8294)
   Started plugin "fingscan 7.24.23"
   Error (client)                  timeout waiting for plugin response from com.karlwachs.fingscan for request UiGetValues1
   Error (client)                  timeout waiting for plugin response from com.karlwachs.fingscan for request CallPluginFunc
   Error (client)                  runConfigDialog() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
   fingscan                        FINGSCAN--V 7.24.21   initializing     will take ~ 2 minutes...; sending logs to /Users/USERNAME/indigo/fing/fingPlugin.log
Sun Mar 11, 2018 7:20 pm
what is the name of the plugin in the indigo path
if it has something like -2 in there thats the problem..
