Long device list
Mon Jan 22, 2018 3:34 pm
vtmikel offline
Long device list
Hi-
Today I wanted to add a 6th device to one of my events. When I enabled the checkbox to see more devices, selected the device, and confirmed changes, it does not save. Exiting the dialog box and returning, or simply changing the event to another event then back to the original, the plugin dialog does not load the 6th device.
I also tried reseting the event and saving it again, same result.
Any thoughts?
Thanks.
Mike
Tue Jan 23, 2018 8:19 am
Re: Long device list
Will check
Tue Jan 23, 2018 11:18 am
i could reproduce the error ONCE, but then not anymore... still looking. it works right now for me . then it is difficult to find it
Tue Jan 23, 2018 11:22 am
vtmikel offline
Just a thought - could it be specific to Event 1? This is the device I was trying to edit. I previously had a problem with this event firing. In fact I think I switched my trigger to watch the variable rather than the event that comes from your plugin.
I just tried it again. Reproduces every time. Let me know if I can help debug.
Tue Jan 23, 2018 12:13 pm
could you try this one.. it works for me and I can NOT reproduce the error any more .. (changed 2 if's)
https://www.dropbox.com/s/g9oa33ndjv1ttiv/fingscan-v-7.24.20.zip?dl=1
Tue Jan 23, 2018 12:54 pm
vtmikel offline
That seems to have fixed it. Thank you! Also, great plugin.
