FINGSCAN events not firing
Mon Dec 11, 2017 9:09 am
Hackencrash offline
Recently, in the last 2 weeks, I've noticed that my Fingscan events have stopped firing.
I have a trigger set-up as follows:
Type: fingscan Event
Event: EVENT_1_oneHome ...
This no longer appears to work.
Indeed, if I go Indigo > Plugins > fingscan > trigger an event NOW >EVENT_1_oneHome > Execute, my trigger does fire as expected, but it does not fire when one device associated with EVENT_1 becomes online (and the others have been off for a while).
I think I've updated Fingscan twice over the last couple of weeks, so I'm unsure which version broke it.
Mon Dec 11, 2017 9:40 am
Re: FINGSCAN events not firing
just tried mine,, seems to work.
could you send me the config of THAT event?
Mon Dec 11, 2017 11:28 am
Hackencrash offline
Hi Karl,
Before I ran this manually, it had a date of 1st December, similar to my other 7 events for other people's phones whom have been here on and off since then:
   fingscan                        EVENT:-------------  1  ---------------------------------------------------------------
   fingscan                        dev#:  1 -- deviceName:Rich iPhoneX WiFi      -- MAC#:40:98:AD:2B:2F:8D -- ip#:192.168.1.251   -- status:up       -- WiFi:
   fingscan                        dev#: 25 -- deviceName:Rich iPhoneX Bluetooth -- IND#:375114353         --                     -- status:up
   fingscan                        currentStatusHome:    # 1:           HOME  #25:           HOME
   fingscan                        currentStatusAway:    # 1:              0  #25:              0
   fingscan                        time WhenLast DOWN:   # 1:       15:58:23  #25:       15:35:23
   fingscan                        time WhenLast UP:     # 1:       17:18:24  #25:       17:18:24
   fingscan                        seconds WhenLast UP:  # 1:             63  #25:             63
   fingscan                        seconds WhenLast DOWN:# 1:           4864  #25:           6244
   fingscan                        Time right now:          :    17:19:25
   fingscan                        ALL Devices         Home :           1  -- reacts after minTimeNotHome
   fingscan                        AtLeast ONE Device  Home :           1  -- reacts after minTimeNotHome
   fingscan                        ALL Devices         Away :           0  -- reacts minTimeAway bf Trig
   fingscan                        AtLeast ONE Device  Away :           0  -- reacts minTimeAway bf Trig
   fingscan                        minTimeAway bf Trig      :        1800
   fingscan                        minTimeNotHome bf re-Trig:          -1
   fingscan                        Event enabled            :           1
   fingscan                        dataFormat               :         3.0
Mon Dec 11, 2017 11:58 am
i changed the event name (id)
11:42:43 EVENT -testing trigger id: 1107067286; eventId:EVENT-12-oneHome; EVENT_12_oneHome
did not change in the plugin at ONE point
Thu Dec 14, 2017 12:31 am
vtmikel offline
This also was happening for me. Specifically with Event 1. I changed my trigger to be based on the variable change rather than the event a while ago. This is working fine.
Thu Dec 14, 2017 7:40 am
Hackencrash offline
Latest Fingscan fixes this - thanks Karl
