Logging device presence
Tue Oct 03, 2017 11:29 am
zini offline
I have a little bit of a unique request and wanted to see if its possible to accomplish using the FINGSCAN plugin.
Is there a way that I could actually log (as in, build a record) of devices and how long they are present? For example, "X" device was present yesterday for 35 minutes and today for 15 minutes, etc. Would there be a way to do this using FINGSCAN in conjunction with Indigo's built-in timers and pesters? Perhaps it sends an email with the record?
Just wanted to throw this out there and see what your thoughts were. Any help/input would be appreciated!
Mark
Tue Oct 03, 2017 6:50 pm
Re: Logging device presence
I believe there is a plugin-- forgot the name -- that does that; something with uptime .. or seconds up
Or you could use the indigoplotD plugin that can calculate that value, but it makes a plot out of the info (use measurement = sum for 1 day.)
Tue Oct 10, 2017 9:15 am
zini offline
Thank you for the quick response. I am going to take a look at your indigoplotD plugin and give it a shot. Looks pretty slick!
Mark
Tue Oct 10, 2017 2:57 pm
try the event feature. you can place dots in the plots at the points when a beacon shows up or leaves..
If you need a walk though let me know.... and you should get sone sensors (e.g. light , temp distance .. they really work nicely on the RPI)
Wed Oct 11, 2017 12:04 am
zini offline
You know what - if you don’t mind, I’ll take you up on that. I would love a walkthrough. I’m just getting back into indigo after a few years so I’m a little rusty.
Thanks for offering!
Mark
