FINGSCAN Continuously Stopping and Re-Starting
Sun Apr 16, 2017 5:57 am
bobbyc176 offline
I haven't been able to get FINGSCAN to run successfully yet. It seems installed correctly but gets stuck in a log-filling loop.
Any insights?
Rob
Sample Log File shown below:
Apr 16, 2017, 7:12:38 AM
fingscan Error seems that FING is not active - no change in data, restart fing
fingscan FING initializing
fingscan Error ----------------------------------------------------------------------------------
fingscan Error (re)started FING 5 times, quiting ... reloading the plugin
fingscan Error ----------------------------------------------------------------------------------------------
fingscan Error fing not active, tried to restart fing, did not work, stopping fingscan, may be wrong password
fingscan Error in plugins/fingscan/configure: set password
fingscan Error --> while loop break <-- error in logic or variables mixed up ... stopping ... quitNOW was:yes
Reloading plugin "fingscan 3.2.1"
Stopping plugin "fingscan 3.2.1" (pid 14784)
fingscan stopConcurrentThread called 2
fingscan stopConcurrentThread called 3
fingscan Debug del Trigger: configured : True
description :
enabled : True
folderId : 220252207
pluginId : com.karlwachs.fingscan
pluginProps : com.karlwachs.fingscan : (dict)
pluginTypeId : IPNumberChanged
remoteDisplay : True
suppressLogging : False
upload : True
fingscan shutdown called
fingscan Debug ----------------------------------------------------------------------------------
fingscan Debug testing if FING is running
fingscan Debug killing FING Processes pids all []
Stopped plugin "fingscan 3.2.1"
Starting plugin "fingscan 3.2.1" (pid 15481)
Started plugin "fingscan 3.2.1"
fingscan FINGSCAN initializing ... will take more than one minute ...
fingscan Debug my pid: 15481
fingscan Debug indigo variables initialized
fingscan Debug password entered=password: "&a3eezteed#5B"
fingscan Debug get password done
fingscan Debug FING initializing
fingscan Debug FING cmd= echo 'deetzee' | sudo -S /usr/bin/fing -o table,csv,'/Users/RobCox/Documents/fing/fing.data' log,csv,'/Users/RobCox/Documents/fing/fing.log' >> '/Users/RobCox/Documents/fing/fingerror.log' 2>&1 &
fingscan Debug waiting for FING to start and produce output
fingscan Debug killing FING Processes pids onlyParents []
fingscan FING initialized .. created new data
fingscan Debug new Trigger: configured : True
description :
enabled : True
upload : True
Apr 16, 2017, 7:14:26 AM
fingscan Debug FING LOG data new 0 2
Apr 16, 2017, 7:14:47 AM
fingscan Error fing restarted successfully
Apr 16, 2017, 7:16:21 AM
Apr 16, 2017, 7:17:56 AM
Sun Apr 16, 2017 8:38 am
Re: FINGSCAN Continuously Stopping and Re-Starting
Will check later today.
Looks like fing is not running.
Sun Apr 16, 2017 9:30 am
where did you get that version? .. need to remove it
the most current is : 7.22.3 at http://forums.indigodomo.com/viewtopic.php?f=166&t=12787&start=30
could you try that one and see if it works
Mon Apr 17, 2017 7:44 am
bobbyc176 offline
Thank you Karl!
Working as expected now.
Thanks for creating such a great PlugIn.
rob
Mon Apr 17, 2017 3:26 pm
So where did you get the old version? Need to delete / change pointers
