Auto Company Modes for the Fingscan Plugin
Mon Dec 12, 2016 9:17 pm
Dewster35 offline
Re: Auto Company Modes for the Fingscan Plugin
Thank you Karl.
Running this gives me the following error message in my event log:
   Script Error                    CompanyCheck.Py: unexpected indent
   Script Error                    around line 13 - "anyUp=True"
Any ideas on how to fix?
Mon Dec 12, 2016 9:44 pm
convert every indent to 4-spaces OR 1-tab
probably while copying it went to 4-spaces, which I am using , you might be using tabs.. or the other way around
Tue Dec 13, 2016 4:38 am
Dewster35 offline
Thanks Karl! That did it and all seems to be working now. Thank you!
Sat Jun 24, 2017 7:41 pm
Dewster35 offline
This is related and I'm sure it is pretty trivial. How do I get a device name based on a device ID from indigo and place it into a variable?
Sat Jun 24, 2017 8:13 pm
So the contents of variable should be the device id ?
Sun Jun 25, 2017 4:36 am
Dewster35 offline
Nope. The device name.
Sun Jun 25, 2017 10:26 am
Dewster35 offline
I was able to get this far. I got the snippet to populate the device name into variable and then push that to an indigo variable, but I'm having trouble integrating it into the main script. Below is where I end up getting stuck.
folder_id = 1637326348  # the ID of your default folder
variable_id = 936521597  # the ID of your tracking variable
anyUp = False
# Loop through Indigo devices
for dev in indigo.devices.itervalues():
    # Is the device in the default folder?
    if dev.folderId == folder_id:
            if dev.states['status'].lower() =='up':
               #WhoComp = indigo.devices[lower()]
            #CName = WhoComp.name
            #indigo.variable.updateValue(117345824, CName)
                indigo.variable.updateValue(variable_id, 'true')
                anyUp=True
                break
        except:
                    pass
if not anyUp:
    indigo.variable.updateValue(variable_id, 'false')
Sun Jun 25, 2017 7:14 pm
Dewster35 offline
One more step forward... now my issue is string manipulation.
My devices follow a standard convention.
(Last name of person) (-) (Company) (# if last name has multiple devices)
So I"m trying to find the position of the dash, then slice the string of the device name 2 positions before that dash.... below is what I've got but it's giving me a syntax error...
anyUp = False
      whoIs = dev.name
      dComp = whoIs.index('-')
      firstCompany = whoIs(:dComp - 2)
      indigo.variable.updateValue(117345824, firstCompany)
      anyUp=True
           break
        except:
                    pass
if not anyUp:
Sun Jun 25, 2017 9:16 pm
whoIs[:dComp - 2]
it is not a function call but an index of a list, they go with [] not ()
this should also work
      whoIs = dev.name.split("-")[0][0:-2]
1. split into 2 elements
2. take first element
3 use everything from the beginning to end -2 characters
Sun Jul 02, 2017 12:16 pm
Dewster35 offline
Python newbie! This worked. Thank you the tips.
