Re: FINGSCAN - discussion
Posted: Mon Aug 07, 2017 7:03 am
Glad it works again. It should have not done anything .. but you never know
Software Support and Home Automation Forum
https://forums.indigodomo.com/
kw123 wrote:it tries to move
/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/ls /usr/local/share/fing/bin/*
to
/usr/local/bin
and
/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/fingEXE/lib/*
to
/usr/local/lib
and some more. This was implemented when Sierra started blocking the /usr/bin directories for sudo users. ( one higher than regular users) only SU user can do that now.
So we moved the fing exec modules to /usr/LOCAL/bin etc where regular users still have access.
it seems that that does not work on your MAC
are you sure that your password is correct?
could you check if the directories
/usr/local/bin/
/etc/fing/
/usr/local/lib/
/usr/local/lib/fing/
/var/data/fing/
exists?
type
to check if that directory exists
the fastest way to diagnose this would be an online scion with teamviewer. It would take me 10 minutes to find out why it does not copy the files.
EVENT# 1 Dev# HomeStat HomeTime HomeDist AwayStat AwayTime AwayDist oneHome allHome oneAway allAWay
EVENT# 1 1 True 61.0 False False 540.0 True True True False False
EVENT# 1 2 False 23138.0 False True 23138.0 True True False
Dec 11, 2017, 6:33:45 PM
EVENT# 1 1 False 180.0 False True 119.0 True False False False False
EVENT# 1 2 False 22717.0 False True 22717.0 True False False True False
EVENT# 1 oneHome:0; allHome:0; oneAway:1; allAway:0
Dec 11, 2017, 6:34:40 PM
EVENT# 1 1 True 235.0 False False 174.0 True True True False False
EVENT# 1 2 False 22772.0 False True 22772.0 True True False True False
EVENT triggerEvent: EVENT-1-oneHome
EVENT testing trigger id : 341102134 EVENT_1_oneHome
EVENT# 1 1 True 6.0 False False 180.0 True True True False False
EVENT# 1 2 False 22778.0 False True 22778.0 True True False True False
EVENT# 1 oneHome:1; allHome:0; oneAway:1; allAway:0
EVENT testing trigger id: 341102134; eventId:EVENT_1_oneHome; EVENT_1_oneHome
EVENT firing trigger id : 341102134
Trigger test
Action Collection My Event Has Triggered!
if "suppressChangeMSG" in dev.states:
if dev.states["suppressChangeMSG"] =="show":
self.myLog("all",u"MAC#:"+theMAC +" -- old IP: "+ str(props["address"])+ "; new IP number: "+ str(self.formatiPforAddress(devI["ipNumber"]))+" to switch off changed message: edit this device and select no msg")
