FINGSCAN - discussion
Sat Nov 12, 2016 5:56 am
Re: FINGSCAN - discussion
So it’d seem that it’ll keep working longer term then? Good.. just didn’t want to go to the hassle of setting it up only to find the project was dead :)
Sat Dec 10, 2016 1:33 pm
Tiny little feature request.. when finding new devices rather than creating a folder called ipDevices could it be set to use a folder with a indigo ID like 1899252660? Would just be nice to keep things tidier :)
Sat Dec 10, 2016 1:51 pm
What is the difference between a name and a number? We could add a config parameter where you can set the folder name.
Sat Dec 10, 2016 3:06 pm
I like to rename non room name folders to start • so either specify the number or a specific name, either would work! :)
Sat Dec 10, 2016 5:10 pm
Names can not start with a number
Hope the new option is ok.
Sat Dec 10, 2016 5:18 pm
Very cool! Thanks for feeding my OCD! :twisted:
Sat Dec 10, 2016 5:43 pm
Wed Dec 21, 2016 1:56 am
veritas offline
Hi Karl,
Thanks for Fingscan.
I have a question:
Every time when go to Plugin/fingscan/configure this command load very slowly.
When i open some ipDevice for settings and click to "Edit Device settings" to full configure, the Configuration window does not open.
If the window open and I make changes, then gives me this error.
fingscan v7.22.2
Screen Shot 2016-12-21 at 9.35.35 AM.png (464.67 KiB) Viewed 3770 times
Thu Dec 22, 2016 2:25 pm
Could you check if there is an error message in the log file when you get this error ?
Thu Dec 22, 2016 10:33 pm
veritas offline
Dec 23, 2016, 6:19:16 AM
Z-Wave received "Living room temp sensor" sensor update to 23.5 °C
Z-Wave received "Living room humidity sensor" sensor update to 20%
Z-Wave received "Living room luminance sensor" sensor update to 0 lux
Z-Wave received "Living room ultraviolet sensor" sensor update to 0
Error (client) timeout waiting for plugin response from com.karlwachs.fingscan for request CalcDeviceFunc
Error (client) timeout waiting for plugin response from com.karlwachs.fingscan for request UiGetValues2
Error (client) timeout waiting for plugin response from com.karlwachs.fingscan for request CallPluginFunc
Error (client) runDialogForDevice() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
Dec 23, 2016, 6:24:51 AM
Reloading plugin "fingscan 7.22.2"
Stopping plugin "fingscan 7.22.2" (pid 455)
Dec 23, 2016, 6:25:06 AM
Error process (pid 455) failed to quit after polite request -- forcing it to quit now
Stopped plugin "fingscan 7.22.2"
Starting plugin "fingscan 7.22.2" (pid 22820)
Started plugin "fingscan 7.22.2"
fingscan FINGSCAN--V 7-22-2 initializing will take ~ 2 minutes...
fingscan leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
fingscan indigo variables initialized
fingscan getting password
fingscan get password done
fingscan copy fing Password:
fingscan loaded indigo data
fingscan ifind plugin: com.corporatechameleon.iFindplugBeta
fingscan FING initializing
Error (client) timeout waiting for plugin response from com.karlwachs.fingscan for request UiGetValues1
Error (client) runConfigDialog() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
fingscan FING initialized .. created new data waiting ~ 1 minute for stable operation
fingscan settings: iDevicesEnabled False
fingscan settings: inbetweenPingType parallel
fingscan settings: wifiRouter 0
fingscan settings: wait seconds between cycles 1
fingscan settings: password entered True
fingscan settings: debugLevel
fingscan settings: FINGSCAN will scan Network 10.0.1.... # of bits:8
fingscan
fingscan
Dec 23, 2016, 6:25:45 AM
Disabling plugin "fingscan 7.22.2"
Stopping plugin "fingscan 7.22.2" (pid 22820)
fingscan FINGSCAN initialized
Error process (pid 22820) failed to quit after polite request -- forcing it to quit now
Enabling plugin "fingscan 7.22.2"
Starting plugin "fingscan 7.22.2" (pid 24104)
Error unable to execute action -- device plugin fingscan not running
fingscan
fingscan
Dec 23, 2016, 6:26:49 AM
Stopping plugin "fingscan 7.22.2" (pid 24104)
Error process (pid 24104) failed to quit after polite request -- forcing it to quit now
Starting plugin "fingscan 7.22.2" (pid 25177)
fingscan
fingscan
Dec 23, 2016, 6:27:57 AM
Thu Dec 22, 2016 10:38 pm
veritas offline
I stop and reload again the plugin, but failed to enter the settings.
Thu Jan 05, 2017 1:08 am
shrxman offline
Hey Karl,
I have a Tivo that uses their wireless-N adapter. The problem is, it manages to associate the same MAC address with 2 ip's. Don't ask me WHY that is, mind you, as I'm still trying to figure this out ( I think it has something to do with the way it access the wireless network via an access point and duplicates the MAC address):
a8-20-66-32-ae-96:fing shrxman$ arp -a | egrep "221|232"
tivo-746000190998b82 (192.168.2.221) at 0:11:d9:3a:80:5b on en0 ifscope [ethernet]
? (192.168.2.232) at 0:11:d9:3a:80:5b on en0 ifscope [ethernet]
Anyway, when I start up the fingscan plugin, I keep getting reports of the IP address 'flapping', and the following log entry:
fingscan MAC#:00:11:D9:3A:80:5B -- old IP: 192.168.2.232 ; new IP number: 192.168.2.221 to switch off changed message: edit this device and select no msg
I found the device in Indigo, but can't see where i can select "no msg". Is this a legacy message from old functionality, perhaps, or am I looking in the wrong location.
thanx again for all that you do out here in IndigoLand :-),
~ken
Thu Jan 05, 2017 2:14 am
It should be in device edit at the bottom
Sun Jan 08, 2017 2:31 pm
shrxman offline
Hey Karl,
Thanks for the reply.
Device edit from the Indigo Devices page? When I click on that, I get the standard device page, and I see "Edit Device Settings..." on the bottom. Clicking on that, though, gives me a custom window (yours), with three options.
Which Info to be used for status updates [ DHCP, WIFI, SWITCH] - DHCP Selected
Then two options for what info to use to determine if device is offline
this will use DHCP-AGE, if AGE GT xx device goes UP to DOWN: 'use regular expiration' is selected
set individual time for UP to DOWN to EXPIRED for THIS device: '90 seconds' is selected.
Am i looking in the wrong spot?
~ken
Sun Jan 08, 2017 8:03 pm
the last line should be the one that enables / disables messages for ip# changed ... this is for FINGSCAN
are you talking about FINGSCAN or UNIFI?
Screen Shot 2017-01-08 at 19.58.17.png (39.22 KiB) Viewed 3439 times
