- Posted on
Fri Aug 07, 2015 5:15 am
Sharek326
offline
Aug 7, 2015, 7:05:05 AM
Enabling plugin "fingscan 4.13.3"
Starting plugin "fingscan 4.13.3" (pid 12950)
Started plugin "fingscan 4.13.3"
fingscan FINGSCAN--V 4-13-3 initializing will take ~ 2 minutes...
fingscan leaving WiFi parameters at default, not configured in 'fingscan/Configure...'
fingscan indigo variables initialized
fingscan getting password
fingscan get password done
fingscan loaded indigo data
fingscan network info: inet 192.168.1.12 netmask 0xffff0000 broadcast 192.168.255.255
fingscan FING initializing
Aug 7, 2015, 7:05:55 AM
fingscan FING pids 3= ['12992']
fingscan (re)started FING
fingscan FING initialized
fingscan settings: iDevicesEnabled False
fingscan settings: inbetweenPingType 0
fingscan settings: wifiRouter 0
fingscan settings: wait seconds between cycles 1
fingscan settings: password entered True
fingscan settings: debugLevel 0
fingscan settings: FINGSCAN will scan Network 192.168.1.1-255
fingscan
fingscan printEvents: no EVENT defined
Aug 7, 2015, 7:06:31 AM
fingscan props check old192.168.81.001 new192.168.1.083
fingscan props check old192.168.1.083 new192.168.81.001
fingscan FINGSCAN initialized
Aug 7, 2015, 7:12:01 AM
fingscan Error ----------------------------------------------------------------------------------
fingscan Error seems that FING is not active - no change in data, restarting fing, seconds since last change: 280.226160049
Aug 7, 2015, 7:12:50 AM
fingscan FING pids 3= ['14076']
fingscan Error fing restarted successfully
Disabling plugin "fingscan 4.13.3"
Stopping plugin "fingscan 4.13.3" (pid 12950)
fingscan stopConcurrentThread called 1
fingscan exception StopThread triggered ... stopped, quitNOW was:no
fingscan stopConcurrentThread called 2
fingscan shutdown called
Stopped plugin "fingscan 4.13.3"
DATA
192.168.0.239;;up;;;04:A1:51:6B:6A:37;
192.168.1.1;;up;;;70:56:81:C4:F7:85;Apple
192.168.1.2;;up;;;A8:20:66:1C:75:FE;Apple
192.168.1.5;;up;2015/08/06 20:39:32;;10:93:E9:00:4F:72;Apple
192.168.1.12;;up;;server.j-lyons.com;3C:07:54:72:71:55;Apple
192.168.1.47;;up;;;28:10:7B:29:34:A6;D-Link
192.168.1.51;;up;;;00:17:88:12:48:10;Philips Lighting
192.168.1.53;;up;;;74:54:7D:01:5C:3C;
192.168.1.55;;up;;;00:11:22:33:44:55;CIMSYS
192.168.1.57;;up;;;1C:AB:A7:9C:C1:CA;Apple
192.168.1.59;;up;;;AC:3A:7A:18:4B:01;
192.168.1.68;;up;;;00:10:75:37:4A:30;Maxtor
192.168.1.83;;up;;;D4:21:22:A8:8B:05;
192.168.1.90;;up;;;C8:85:50:E6:C2:09;
192.168.1.93;;up;;;10:1C:0C:7F:8A:D4;
192.168.1.169;;up;;;AC:3A:7A:9E:B2:BB;
192.168.1.188;;up;;;F0:D1:A9:0B:A7:C8;
192.168.1.191;;up;;;30:0E:D5:C3:40:CB;Hon Hai Precision
192.168.1.192;;up;2015/08/06 20:57:21;;5C:96:9D:7A:43:7B;
192.168.1.207;;up;;;00:0C:1E:03:31:92;Global Cache
192.168.81.1;;up;;;D4:21:22:A8:8B:05;
Log
8/7/15 7:02:37.503 AM com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
8/7/15 7:02:37.663 AM com.apple.iCloudHelper[12567]: objc[12567]: Class FALogging is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle and /System/Library/PrivateFrameworks/FamilyNotification.framework/Versions/A/FamilyNotification. One of the two will be used. Which one is undefined.
8/7/15 7:02:37.679 AM com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
8/7/15 7:02:38.353 AM CalendarAgent[492]: [com.apple.calendar.store.log.caldav.coredav] [Refusing to parse response to PROPPATCH because of content-type: [text/plain; charset="utf-8"].]
8/7/15 7:02:38.459 AM CalendarAgent[492]: [com.apple.calendar.store.log.caldav.coredav] [Refusing to parse response to PROPPATCH because of content-type: [text/plain; charset="utf-8"].]
8/7/15 7:03:13.249 AM com.apple.xpc.launchd[1]: (com.apple.screensharing[12676]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.screensharing.server
8/7/15 7:03:13.532 AM screensharingd[12676]: Authentication: SUCCEEDED :: User Name: serveradmin :: Viewer Address: 192.168.1.2 :: Type: DH
8/7/15 7:03:13.784 AM screensharingd[12676]: not using LOWAT
8/7/15 7:04:36.844 AM IndigoPluginHost[8794]: Quiting Indigo Plugin Host - received quit signal
8/7/15 7:04:37.389 AM sudo[12945]: serveradmin : TTY=unknown ; PWD=/Library/Application Support/Perceptive Automation/Indigo 6/Plugins (Disabled)/fingscan.indigoPlugin/Contents/Server Plugin ; USER=root ; COMMAND=/bin/kill 11475
8/7/15 7:05:07.265 AM sudo[12979]: serveradmin : TTY=unknown ; PWD=/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/fingscan.indigoPlugin/Contents/Server Plugin ; USER=root ; COMMAND=/bin/kill
8/7/15 7:05:08.306 AM sudo[12990]: serveradmin : TTY=unknown ; PWD=/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/fingscan.indigoPlugin/Contents/Server Plugin ; USER=root ; COMMAND=/usr/bin/fing -o table,csv,/Users/serveradmin/Documents/fing/fing.data log,csv,/Users/serveradmin/Documents/fing/fing.log
8/7/15 7:05:08.000 AM kernel[0]: en0: promiscuous mode enable succeeded
8/7/15 7:05:08.000 AM kernel[0]: en0: promiscuous mode disable succeeded
8/7/15 7:05:08.000 AM kernel[0]: fw0: promiscuous mode enable succeeded
8/7/15 7:05:08.000 AM kernel[0]: fw0: promiscuous mode disable succeeded
8/7/15 7:05:08.000 AM kernel[0]: bridge0: promiscuous mode enable succeeded
8/7/15 7:05:08.000 AM kernel[0]: bridge0: promiscuous mode disable succeeded
8/7/15 7:05:08.000 AM kernel[0]: en1: promiscuous mode enable failed
8/7/15 7:05:08.000 AM kernel[0]: lo0: promiscuous mode enable succeeded
8/7/15 7:05:08.000 AM kernel[0]: lo0: promiscuous mode disable succeeded
8/7/15 7:05:09.350 AM sudo[13002]: serveradmin : TTY=unknown ; PWD=/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/fingscan.indigoPlugin/Contents/Server Plugin ; USER=root ; COMMAND=/bin/kill 12991
8/7/15 7:05:55.472 AM collabd[13018]: [main.m:292 7efe2300 +0ms] HTTP server listening at localhost:4444
8/7/15 7:05:55.473 AM collabd[13018]: [main.m:293 7efe2300 +0ms] HTTPS server listening at localhost:4443
8/7/15 7:05:55.474 AM collabd[13018]: [main.m:317 7efe2300 +0ms] Configured to exit after about 360 seconds idle
8/7/15 7:07:03.000 AM kernel[0]: process fing.bin[12992] caught causing excessive wakeups. EXC_RESOURCE supressed due to audio playback
8/7/15 7:08:32.204 AM com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
8/7/15 7:10:36.499 AM coreservicesd[111]: SFLEntryBase::ListHasChanged mach_msg returned 10000004d
8/7/15 7:10:36.594 AM com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
8/7/15 7:12:01.935 AM IndigoServer[584]: fingscan Error ----------------------------------------------------------------------------------
8/7/15 7:12:01.936 AM IndigoServer[584]: fingscan Error seems that FING is not active - no change in data, restarting fing, seconds since last change: 280.226160049
8/7/15 7:12:01.937 AM IndigoServer[584]: fingscan Error ----------------------------------------------------------------------------------
8/7/15 7:12:02.100 AM sudo[14063]: serveradmin : TTY=unknown ; PWD=/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/fingscan.indigoPlugin/Contents/Server Plugin ; USER=root ; COMMAND=/bin/kill 12992
8/7/15 7:12:03.037 AM sudo[14074]: serveradmin : TTY=unknown ; PWD=/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/fingscan.indigoPlugin/Contents/Server Plugin ; USER=root ; COMMAND=/usr/bin/fing -o table,csv,/Users/serveradmin/Documents/fing/fing.data log,csv,/Users/serveradmin/Documents/fing/fing.log
8/7/15 7:12:03.000 AM kernel[0]: en0: promiscuous mode enable succeeded
8/7/15 7:12:03.000 AM kernel[0]: en0: promiscuous mode disable succeeded
8/7/15 7:12:03.000 AM kernel[0]: fw0: promiscuous mode enable succeeded
8/7/15 7:12:03.000 AM kernel[0]: fw0: promiscuous mode disable succeeded
8/7/15 7:12:03.000 AM kernel[0]: bridge0: promiscuous mode enable succeeded
8/7/15 7:12:03.000 AM kernel[0]: bridge0: promiscuous mode disable succeeded
8/7/15 7:12:03.000 AM kernel[0]: en1: promiscuous mode enable failed
8/7/15 7:12:03.000 AM kernel[0]: lo0: promiscuous mode enable succeeded
8/7/15 7:12:03.000 AM kernel[0]: lo0: promiscuous mode disable succeeded
8/7/15 7:12:04.085 AM sudo[14086]: serveradmin : TTY=unknown ; PWD=/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/fingscan.indigoPlugin/Contents/Server Plugin ; USER=root ; COMMAND=/bin/kill 14075
8/7/15 7:12:50.174 AM IndigoServer[584]: fingscan Error ----------------------------------------------------------------------------------
8/7/15 7:12:50.175 AM IndigoServer[584]: fingscan Error fing restarted successfully
8/7/15 7:12:50.176 AM IndigoServer[584]: fingscan Error ----------------------------------------------------------------------------------
8/7/15 7:12:56.198 AM IndigoPluginHost[12950]: Quiting Indigo Plugin Host - received quit signal
8/7/15 7:12:56.483 AM sudo[14123]: serveradmin : TTY=unknown ; PWD=/Library/Application Support/Perceptive Automation/Indigo 6/Plugins (Disabled)/fingscan.indigoPlugin/Contents/Server Plugin ; USER=root ; COMMAND=/bin/kill 14076
8/7/15 7:14:00.467 AM com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
