posted v 7.23.12
added:will check
/usr/bin/curl
http://api.macvendors.com/11:22:33:44:55:66 (11:22: = mac number )
to get the vendor name for each existing devices.
it will go though ALL devices at start and if the length of the contents of hardwareVendor field is < 4 it will try to get it.
Also when a new device is added it will also check.
So if you run it the first time it might take a minute to start. the second time it starts it will go again, but only those that are blank .
Ps one thing missing. If you don’t have internet access during loading of the plugin it will take a looooong time as it will need to time out at each query. 10 sec times number of queries
Will add a check. In the next fix.
{EDIT] added check if no internet connection: no vendor checking
