Python version not available after 12.3 upgrade
Tue May 17, 2022 2:52 pm
Re: Python version not available after 12.3 upgrade
the plugin checks if any of these is installed:
/Library/Frameworks/Python.framework/Versions/Current/bin/python3
/usr/local/bin/python
/usr/bin/python2.7
When indigo 2022.1 gets installed
and
gets installed
So it should find the proper version.
the error message:
"none of python versions 2.5 ..2.8 is installed ==> stopping INDIGOplotD"
is from an older version
v7.21.73 should work.
.. but I missed to post that one to the plugin store.
will do tomorrow morning
Tue May 17, 2022 3:40 pm
I'm not sure why the plugin would be testing this, as it wouldn't be able to start up if python weren't installed...
But in any event: /usr/local/bin/python is python 2, not python 3. /usr/local/bin/python3 is the most correct way to start up python 3 (unless you want to actually point to the frame work install directory).
Wed May 18, 2022 9:13 am
posted v7.21.73
should work now.
Wed May 18, 2022 10:12 am
DVDDave offline
Thanks, Karl. Plots seem to be partially updating now but I get the following errors about once per sec:
   INDIGOplotD Error               'invalid literal for float(): 60.6.3'
getsqldataFromFile @line 11057: 'sqlData.append([sqlHistoryData[1],float(sqlHistoryData[-1])])# take date field and data field ignore other fields (0=id, 2...x = day/wek .. fields last one is data field'
   INDIGOplotD Error               sql produced file with bad data
Wed May 18, 2022 10:54 am
>> 60.6.3 << is not a valid number. that is correct ;)
could you do
1. indigoplotD menu Print FORMATTED ....
you should get something like (open file w textedit
/Library/Application Support/Perceptive Automation/Indigo 2022.1/Preferences/Plugins/com.karlwachs.INDIGOplotD/data/minute.dat.formatted
(for minute, hour, day)
20220511114000 2;2;0;0;0; 140; 23.300; 100.00;
20220511114500 2;2;0;0;0; 141; 23.300; 100.00;
20220511115000 2;2;0;0;0; 142; 23.300; 100.00;
20220511115500 2;2;0;0;0; 143; 23.300; 100.00;
20220511120000 2;2;0;0;0; 144; 23.100; 100.00;
20220511120500 2;2;0;0;0; 145; 23.300; 100.00;
check if you can find 60.6.3,
if yes
1. post that line and some around it
2. do Re-load complete sql data (indigoplotD menu), check if error persists
Wed May 18, 2022 4:42 pm
DVDDave offline
I was not able to find 60.6.3 in the files. Reloading all the SQL data did not correct the error, although sometimes a different incorrect number (eg 72.67.1) would also show up in the error messages.
Reloading 2 days of SQL data stops the error until the plugin is restarted.
Tue May 24, 2022 8:54 am
mbordas offline
I'm getting a similar error with v7.21.73 and Indigo 2022.1. Attaching the output from the "Print FORMATTED ...." command
INDIGOplotD Error               'invalid literal for float(): 33..0'
   INDIGOplotD Error               'could not convert string to float: '
minute.dat.formatted.txt
(1.89 KiB) Downloaded 72 times
hour.dat.formatted.txt
(1.89 KiB) Downloaded 69 times
day.dat.formatted.txt
(17.79 KiB) Downloaded 86 times
Tue May 24, 2022 9:24 am
it looks as if the sql query does not work, no data is read.
could you check the directory
/Library/Application Support/Perceptive Automation/Indigo 2022.1/Preferences/Plugins/com.karlwachs.INDIGOplotD/sql/
then open (eg text edit) a file like
131394313-temperatureC
where the first part is the device id and the 2.part is the state you like to plot. it should look like:
1;20220316084559;0.0
12;20220316084601;23.6
17;20220316085138;23.3
29;20220316093625;23.1
33;20220316094127;23.3
37;20220316094622;23.1
42;20220316095932;23.3
47;20220316100621;23.1
51;20220316101117;23.3
in format:
seq#;date-time; value
check if you find something like:
or any number that is not an integer or float like something with ..
the data flow is
sql query --> devID-devState --> minute.dat --> minute.dat.formatted
I guess the error is at the sql output
Tue May 24, 2022 9:33 am
mbordas offline
Yep, in
/Library/Application Support/Perceptive Automation/Indigo 2022.1/Preferences/Plugins/com.karlwachs.INDIGOplotD/sql/737987371-sensorValue
I found the line:
66254;20211104071004;33..0
There are also some lines that seem to be missing a column completely:
66096;20211103025519;39.0
66097;20210
66255;20211104074005;32.0
383497;20220524104331;80.3
;82.0
383477;20220524092011;81.7
Tue May 24, 2022 10:09 am
are you using sqlite or postures as your SQL db?
if it is postgres please open a terminal window and paste:
/Applications/Postgres.app/Contents/Versions/latest/bin/psql indigo_history -U postgres -t -A -F ';' -c " SELECT id,  to_char(ts,'YYYYmmddHH24MIss'),  \"sensorValue\" from device_history_737987371 WHERE \"sensorValue\" IS NOT NULL  AND  ID > 0 order by id  LIMIT 10000000;"
then check the output
it is sqlite i need a little time to recreate the command string
Tue May 24, 2022 10:56 am
mbordas offline
I'm using sqlite. Attaching the output from device_history_737987371
sql output.txt
(463.62 KiB) Downloaded 76 times
Tue May 24, 2022 11:42 am
ok I can reproduce the error.
when I reload the sql db I get the error, when I run the command in a terminal window I do not get it.
I guess this is a rights or buffer ... issue, it will take a little time to figure that one out.
Wed May 25, 2022 3:13 am
changes in v7.21.74 @ 2021-05-25
1. fixed:
this version is ready to run under py3, but still uses py2
to move to py3 (with indigo 2022.1) : edit file info.plist and change server api version to 3.0
hopefully this is the last bugfix for py2. would like to move on to py3 and py3 only (= no support for py2)
Wed May 25, 2022 8:39 am
DVDDave offline
Seems to be working now using py2 version. Thanks!
--Dave
