New path to SQL database after Indigo update
Thu Dec 31, 2020 2:52 am
McJohn offline
Karl, thanks again for all your work, also for IndigoplotD.
After each Indigo update we sometimes forgot to update the link to the SQL database and after a couple of days we saw very strange or no plots..
Is it possible for you to make a check at the load of IndigoPlotD plugin?
Or an info text with the selected database?
path To files:
Or at least an extra info line at the reload data commands:
INDIGOplotD command: reLoad data from SQL for last 2 days started
(with a path to the selected database)
All the best,
John
PS: the most nice solution is an automatic change to the new path after each Indigo update :D
Fri Jan 01, 2021 12:15 am
Re: New path to SQL database after Indigo update
The option to enter the path for the db was added because someone some years ago requested it as he had the dB somewhere else.
I can add: if field is empty - use default path which will point to the proper indigo x.y path
That should settle it I guess
Fri Jan 01, 2021 1:44 am
McJohn offline
Thanks for the fast answer. That would be perfect! :D
Fri Jan 01, 2021 4:03 pm
John,
check version 7.20.73,:
when you empty the path to the sqlite db it will use:
/Library/Application Support/Perceptive Automation/Indigo x.y/Logs/
as default
Sat Jan 02, 2021 9:40 am
McJohn offline
Thank you so much for the very quick update!
Works perfect!
Glad that the next Indigo update is a real automated update with no worries! :D
Sat Jan 02, 2021 12:27 pm
Actually it will not change the path. You need to empty it. Then it will use the default path.
Sat Jan 02, 2021 1:34 pm
McJohn offline
as default
Yes, your first message was loud and clear. :D
