[SOLVED] Upgrade from 4.16.21 to 4.16.25 Breaks everything..
Posted: Thu Dec 21, 2017 2:16 pm
Since my kid is asleep, I figured I would go through my Indigo.. I fixed a few things, then started to peak through the store. I wanted to fix a few things that had piled up.
I got to my IndigoPlotD and saw there was an update. So I updated it. Big Mistake. Now nothing plots, and I am not sure how to fix it. Making these plots the way I wanted them was at least a week's work with lots of tweaking after that. I am a bit nauseous thinking about "starting over".
Downgrading back didn't work either.
Any ideas?
I have posted relevant bits of the log file and plugin.py below. at least i think they may be relevant.
Kyle
2017-12-21 14:13:12.884 Application Stopping plugin INDIGOplotD (pid 449)
2017-12-21 14:13:12.983 INDIGOplotD main loop stopped
2017-12-21 14:13:14.139 Application Stopped plugin INDIGOplotD
2017-12-21 14:13:14.141 Application Upgrading plugin INDIGOplotD to newer version 4.16.25 (previous version moved to trash)
2017-12-21 14:13:14.157 Application Loading plugin "INDIGOplotD 4.16.25"
2017-12-21 14:13:14.169 Application Starting plugin "INDIGOplotD 4.16.25" (pid 53524)
2017-12-21 14:13:16.577 Application Started plugin "INDIGOplotD 4.16.25"
2017-12-21 14:13:16.580 INDIGOplotD Error --------------------------------------------------------------------------------------------------------------
2017-12-21 14:13:16.582 INDIGOplotD Error The pluginname is not correct, please reinstall or rename
2017-12-21 14:13:16.583 INDIGOplotD Error It should be /Libray/....../Plugins/INDIGOplotD.indigPlugin
2017-12-21 14:13:16.584 INDIGOplotD Error It is: /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/INDIGOplotD 3.indigoPlugin
2017-12-21 14:13:16.585 INDIGOplotD Error please check your download folder, delete old *.indigoPlugin files or this will happen again during next updates
2017-12-21 14:13:16.586 INDIGOplotD Error ---------------------------------------------------------------------------------------------------------------
2017-12-21 14:14:56.554 INDIGOplotD Error Error in plugin execution startup:
File "plugin.py", line 240, in startup
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site.py", line 362, in __call__
SystemExit: 1
2017-12-21 14:14:56.590 INDIGOplotD Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 8723, in runConcurrentThread
File "plugin.py", line 6391, in checkIfEventData
AttributeError: 'Plugin' object has no attribute 'DEVICE'
2017-12-21 14:14:56.592 INDIGOplotD Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-12-21 14:15:06.594 INDIGOplotD Error Error in plugin execution runConcurrentThread:
2017-12-21 14:15:06.601 INDIGOplotD Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-12-21 14:15:16.595 INDIGOplotD Error Error in plugin execution runConcurrentThread:
2017-12-21 14:15:16.598 INDIGOplotD Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-12-21 14:15:26.600 INDIGOplotD Error Error in plugin execution runConcurrentThread:
2017-12-21 14:15:26.603 INDIGOplotD Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-12-21 14:15:36.602 INDIGOplotD Error Error in plugin execution runConcurrentThread:
2017-12-21 14:15:36.604 INDIGOplotD Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-12-21 14:15:46.609 INDIGOplotD Error Error in plugin execution runConcurrentThread:
2017-12-21 14:15:46.613 INDIGOplotD Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-12-21 14:15:56.612 INDIGOplotD Error Error in plugin execution runConcurrentThread:
2017-12-21 14:15:56.617 INDIGOplotD Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-12-21 14:16:06.614 INDIGOplotD Error Error in plugin execution runConcurrentThread:
2017-12-21 14:16:06.617 INDIGOplotD Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-12-21 14:16:16.619 INDIGOplotD Error Error in plugin execution runConcurrentThread:
2017-12-21 14:16:16.622 INDIGOplotD Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-12-21 14:16:26.622 INDIGOplotD Error Error in plugin execution runConcurrentThread:
2017-12-21 14:16:26.626 INDIGOplotD Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-12-21 14:16:36.625 INDIGOplotD Error Error in plugin execution runConcurrentThread:
Any ideas?
Kyle
SystemExit: 1
