Plots no longer render in 7.1
Mon Oct 23, 2017 5:33 am
johnpolasek offline
Not sure if this one is yours or Matts, but I figured I'd start here; I upgraded to Indigo 7.1 and Pibeacon 69.155 last Friday, replacing the Indigo web server with the reduced version from that PiBeacon... and now any time I try to bring up a plot, in either touch or the Indigo clieant , I get
    Oct 23, 2017, 5:25:13 AM
    WebServer internal server error "http://192.168.10.101:8176/refreshingimage" from 192.168.10.190
    WebServer
    Request Headers:
    AUTHORIZATION: Digest username="XXXXXXXXX", realm="Indigo Control Server", nonce="ad824c6e2645d2546db3583916946602", uri="/refreshingimage?page=House%20Temp%20Plot&id=2", response="1b2ca423b150d9dedfb239feb5bb6504", algorithm="MD5", cnonce="9654b97e40bc2c35c85a13e65a270310", nc=00000003, qop="auth"
    REFERER: http://192.168.10.101:8176/controlpage? ... emp%20Plot
    HOST: 192.168.10.101:8176
    ACCEPT: image/png,image/svg+xml,image/*;q=0.8,*/*;q=0.5
    USER-AGENT: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_5) AppleWebKit/603.2.4 (KHTML, like Gecko) Version/10.1.1 Safari/603.2.4
    CONNECTION: keep-alive
    Remote-Addr: 192.168.10.190
    ACCEPT-LANGUAGE: en-us
    ACCEPT-ENCODING: gzip, deflate
    File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/cherrypy/_cprequest.py", line 609, in respond
    cherrypy.response.body = self.handler()
    File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/cherrypy/_cpdispatch.py", line 25, in __call__
    return self.callable(*self.args, **self.kwargs)
    File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/indigopy/indigoreqhandler.py", line 468, in refreshingimage
    if result_content_type != '' and result_content_type.find('image') != 0:
    UnboundLocalError: local variable 'result_content_type' referenced before assignment
    WebServer
    Request Headers:
    AUTHORIZATION: Digest username="XXXXXXXXX", realm="Indigo Control Server", nonce="ad824c6e2645d2546db3583916946602", uri="/refreshingimage?page=House%20Temp%20Plot&id=2&nocache=1508754312266", response="f18dca62ec9b6d1f8602e726cf5842be", algorithm="MD5", cnonce="9654b97e40bc2c35c85a13e65a270310", nc=00000005, qop="auth"
    WebServer
    Request Headers:
    AUTHORIZATION: Digest username="XXXXXXXX", realm="Indigo Control Server", nonce="ad824c6e2645d2546db3583916946602", uri="/refreshingimage?page=House%20Temp%20Plot&id=2&nocache=1508754312266", response="5ff76d975181f24815c383416a796b2b", algorithm="MD5", cnonce="9654b97e40bc2c35c85a13e65a270310", nc=00000006, qop="auth"
Jpgs snatched from the security camera plugin display fine, as do control pages with png backgrounds and control elements.
Mon Oct 23, 2017 7:24 am
Re: Plots no longer render in 7.1
You can switch to the pibeacon socket version and revert to the original indigo web server.
And the newest version is .159 I believe
There is also the issue of // vs /// in the url --- see other discussion thread:
http://forums.indigodomo.com/viewtopic.php?f=13&t=19290&p=147563&hilit=indigoplotd#p147563
Change the URL to this and it should work:
file:///Users/timm/Documents/INDIGOplotD/PowerUsage-minute-S2.png
The URL you have previously isn't correct, but Indigo was forgiving about it. 7.1 isn't as forgiving.
Mon Oct 23, 2017 1:57 pm
johnpolasek offline
I'll try that when I get home... I assume that's also been updated in the "dump to log for IndigoPlot? I haven't created or updated any new plots since last spring, and copied the refs directly from what was sent to the log at the time.
Mon Oct 23, 2017 3:09 pm
Have not changed that. Will
Post a new version next week with some improvements.
Tue Oct 24, 2017 5:43 am
johnpolasek offline
The fix did work. All plots now back after changing file:/... to file:///...
