Is there a limit to the number of items?
Sun Jul 16, 2017 11:20 am
johnpolasek offline
I have quite a few data items defined in indigo plot, but when I tried to add half a dozen more to monitor the AC performance, I suddenly started getting
    INDIGOplotD --------------------------------------------------------------
    INDIGOplotD bad input, no device selected (2) Line '6158' has error=''40''
when adding new items, whether I was adding a variable or a device... My current list is
    INDIGOplotD command: PrintDeviceData
    INDIGOplotD pending indigoCommands: ['PrintDeviceData']
    DevNo, Name, ID State Measurement offset multipl minValue maxValue ColfilGps resetType --- nickName
    1 BackdoorOpen ok: 1
    # 1 Var-ID: 406228941 value eventCHANGE 0.0 1.0 -2.0 5.0 1 1 0 Var-BackdoorOpen-eventCHANGE
    # 2 value max 0.0 1.0 -2.0 5.0 24 1 0 Var-BackdoorOpen-max
    2 BedroomDoorOpen ok: 1
    # 1 Var-ID: 740235904 value eventCHANGE 0.0 1.0 -2.0 5.0 2 1 0 Var-BedroomDoorOpen-eventCHANGE
    # 2 value max 0.0 1.0 -2.0 5.0 25 1 0 Var-BedroomDoorOpen-max
    3 DrivewayTrip ok: 1
    # 1 Var-ID: 514706119 value eventCHANGE 0.0 1.0 -2.0 5.0 3 1 0 Var-DrivewayTrip-eventCHANGE
    # 2 value max 0.0 1.0 -2.0 5.0 22 1 0 Var-DrivewayTrip-max
    4 iBeacon-Count-Family-Home ok: 1
    # 1 Var-ID: 37858233 value max 0.0 1.0 -200.0 50000.0 4 1 0 Var-iBeacon-Count-Family-Home-max
    5 FreezerTemp ok: 1
    # 1 Var-ID: 987453596 value average 0.0 1.0 -200.0 50000.0 5 1 0 Var-FreezerTemp-average
    6 FrigeTemp ok: 1
    # 1 Var-ID: 186158569 value average 0.0 1.0 -200.0 50000.0 6 1 0 Var-FrigeTemp-average
    7 AtticTemp ok: 1
    # 1 Var-ID: 1144246873 value average 0.0 1.0 -200.0 50000.0 7 1 0 Var-AtticTemp-average
    8 AtticHum ok: 1
    # 1 Var-ID: 1634311583 value average 0.0 1.0 -200.0 50000.0 8 1 0 Var-AtticHum-average
    9 BackTemp ok: 1
    # 1 Var-ID: 722646146 value average 0.0 1.0 -200.0 50000.0 9 1 0 Var-BackTemp-average
    10 GrandTemp ok: 1
    # 1 Var-ID: 347256308 value average 0.0 1.0 -200.0 50000.0 10 1 0 Var-GrandTemp-average
    11 JeffTemp ok: 1
    # 1 Var-ID: 1770840016 value average 0.0 1.0 -200.0 50000.0 11 1 0 Var-JeffTemp-average
    12 MasterTemp ok: 1
    # 1 Var-ID: 1231601518 value average 0.0 1.0 -200.0 50000.0 12 1 0 Var-MasterTemp-average
    13 ReturnAirTemp ok: 1
    # 1 Var-ID: 252899792 value average 0.0 1.0 -200.0 50000.0 13 1 0 Var-ReturnAirTemp-average
    14 ServerTemp ok: 1
    # 1 Var-ID: 902879087 value average 0.0 1.0 -200.0 50000.0 14 1 0 Var-ServerTemp-average
    15 Outdoor Temperature ok: 1
    # 1 Dev-ID: 925894900 temperature average 0.0 1.0 -200.0 50000.0 15 1 0 OutdoorTemperature-value-average
    16 SideDoorOpen ok: 1
    # 1 Var-ID: 955107322 value eventCHANGE 0.0 1.0 -2.0 5.0 16 0 0 Side door CHANGE
    # 2 value max 0.0 1.0 -2.0 5.0 18 0 0 Var-SideDoorOpen-eventDOWN-NFGap
    # 3 value eventUP 0.0 1.0 -2.0 5.0 19 1 0 Side Door Up
    17 FrontDoorOpen ok: 1
    # 1 Var-ID: 1829794252 value eventCHANGE 0.0 1.0 -2.0 5.0 17 0 0 Var-FrontDoorOpen-eventCHANGE
    # 2 value max 0.0 1.0 -200.0 50000.0 23 1 0 Front Door
    18 ShackTemp ok: 1
    # 1 Var-ID: 573602257 value average 0.0 1.0 -200.0 200.0 20 1 0 Shed Temperature
    19 Dakota IO Alert ok: 1
    # 1 Dev-ID: 1230723939 binaryInput1 eventCHANGE 0.0 1.0 -2.0 5.0 21 0 0 DakotaIOAlert-binaryI-eventCHANGE-NFGap
    20 JoelHome ok: 1
    # 1 Var-ID: 988882275 value max 0.0 1.0 -2.0 5.0 26 1 0 Joel Here
    21 PatHome ok: 1
    # 1 Var-ID: 1854760342 value max 0.0 1.0 -2.0 5.0 27 1 0 Var-PatHome-max
    22 JeffHome ok: 1
    # 1 Var-ID: 542628432 value max 0.0 1.0 -2.0 5.0 28 1 0 Jeff Home
    23 JohnHome ok: 1
    # 1 Var-ID: 619390738 value max 0.0 1.0 -2.0 5.0 29 1 0 John Home
    24 DavisWindSpeed ok: 1
    # 1 Var-ID: 747133365 value average 0.0 1.0 -200.0 50000.0 30 1 0 Var-DavisWindSpeed-average
    25 DavisDirection ok: 1
    # 1 Var-ID: 1089124244 value Direction0to360North 0.0 1.0 -200.0 50000.0 31 1 0 Var-DavisDirection-average
    26 PeteHome ok: 1
    # 1 Var-ID: 623808291 value max 0.0 1.0 -200.0 50000.0 32 1 0 Var-PeteHome-max
    27 MarinaHere ok: 1
    # 1 Var-ID: 951936406 value max 0.0 1.0 -200.0 50000.0 33 1 0 Mariana
    28 MomHere ok: 1
    # 1 Var-ID: 271380171 value max 0.0 1.0 -200.0 50000.0 34 1 0 Mom or Katie
    29 Attic Motion ok: 1
    # 1 Dev-ID: 156647710 onOffState eventCHANGE 0.0 0.5 -200.0 50000.0 35 1 0 UtilityWeather-On/Off-eventCHANGE
    30 Living Room motion sensor ok: 1
    # 1 Dev-ID: 469683361 onOffState eventCHANGE 0.0 2.0 -200.0 50000.0 36 1 0 Living Room Motion
    31 Guest Bedroom Sensor ok: 1
    # 1 Dev-ID: 106433916 onOffState eventCHANGE 0.0 1.0 -200.0 50000.0 37 1 0 GuestBedroomSensor-On/Off-eventCHANGE
    32 Utility 6 in 1 ok: 1
    # 1 Dev-ID: 655835162 onOffState eventCHANGE 0.0 0.5 -200.0 50000.0 38 1 0 Utility6in1-On/Off-eventCHANGE
    33 Dakota Feeder ok: 1
    # 1 Dev-ID: 1984528809 INPUT_0 eventUP 0.0 0.4 0.0 5.0 40 0 0 Feeder
    34 Attic Humidity Z ok: 1
    # 1 Dev-ID: 1358811696 sensorValue average 0.0 1.0 0.0 100.0 41 1 0 Attic Humidity Z
    35 Davis WindGust ok: 1
    # 1 Dev-ID: 1916151266 tenMinuteWindGust_mph max 0.0 1.0 0.0 100.0 39 1 0 DavisWindGust-tenMinu-max
    36 Attic Motion ok: 1
    # 1 Dev-ID: 156647710 onOffState max 0.0 1.0 0.0 10.0 42 1 0 AtticMotion-On/Off-max
    37 Server Room Eyeball ok: 1
    # 1 Dev-ID: 1697872060 onOffState eventUP 0.0 1.0 -200.0 50000.0 43 1
    38 central return air ok: 1
    # 1 Dev-ID: 22777023 temperature average 0.0 1.0 -200.0 50000.0 44 1
    39 Central vent ok: 1
    # 1 Dev-ID: 721770164 temperature average 0.0 1.0 -200.0 50000.0 45 1
    INDIGOplotD
    INDIGOplotD Index list for dataColumn to Device#/State#
    INDIGOplotD Column=Dev#/St# Column=Dev#/St# Column=Dev#/St# Column=Dev#/St# Column=Dev#/St#
    INDIGOplotD 1= 1/ 1 2= 2/ 1 3= 3/ 1 4= 4/ 1 5= 5/ 1
    INDIGOplotD 6= 6/ 1 7= 7/ 1 8= 8/ 1 9= 9/ 1 10= 10/ 1
    INDIGOplotD 11= 11/ 1 12= 12/ 1 13= 13/ 1 14= 14/ 1 15= 15/ 1
    INDIGOplotD 16= 16/ 1 17= 17/ 1 18= 16/ 2 19= 16/ 3 20= 18/ 1
    INDIGOplotD 21= 19/ 1 22= 3/ 2 23= 17/ 2 24= 1/ 2 25= 2/ 2
    INDIGOplotD 26= 20/ 1 27= 21/ 1 28= 22/ 1 29= 23/ 1 30= 24/ 1
    INDIGOplotD 31= 25/ 1 32= 26/ 1 33= 27/ 1 34= 28/ 1 35= 29/ 1
    INDIGOplotD 36= 30/ 1 37= 31/ 1 38= 32/ 1 39= 35/ 1 40= 33/ 1
    INDIGOplotD 41= 34/ 1 42= 36/ 1 43= 37/ 1 44= 38/ 1 45= 39/ 1
Sun Jul 16, 2017 2:28 pm
Re: Is there a limit to the number of items?
Will check when I am home.
Sun Jul 16, 2017 5:33 pm
I can not find any limit for # of devices. Only number of lines in a single plot < 100.
could you switch on debug (2) general and do the select data again?
you should see something like this:
...   bla bla bla ....
18:30:06             - redolineDataSource  called from : redoParam
18:30:06             -redolineDataSource: listOfSelectedDataColumnsAndDevPropName[(0, 'None'), (1, u's-9-TP-MB-inside-Temp-average'), (2, u's-9-TP-MB-inside-Pressur-average'), (3, u'youGotMail-On/Off-average'), (4, u's-8-THP-kitchen-Temp-average'), (5, u's-8-THP-kitchen-Humidit-average'), (6, u's-8-THP-kitchen-Pressur-average'), (7, u's-14-bme-->display-Temp-average'), (8, u's-14-bme-->display-Humidit-average'), (9, u's-14-bme-->display-Pressur-average'), (10, u's-5-bmp180-Temp-average'), (11, u's-5-bmp180-Pressur-average'), (12, u'MotionSensorOutsideBack-On/Off-event'), (13, u'Tempattic-Temp-average'), (14, u'Var-alarm_front_door-event'), (15, u'freezer-Temp-average'), (16, u's-2-T-Leo-inside-Temp-average'), (17, u'c-volvo-Presenc-max-NFGap'), (18, u'leo-Temp-average'), (19, u'poolTemp-Temp-average'), (20, u'fridge-Temp-average'), (21, u'poolTemp-broken-Temp-average'), (22, u'MotionSensorLivingRoom-On/Off-event'), (23, u's-11-serverRoom-switch-exaust-Temp-average'), (24, u's-11-serverRoom-mac-Temp-average'), (25, u's-2-Leo-Lum-Window-illumin-average'), (26, u's-2-Leo-Lum-Window-ambient-average'), (27, u's-2-Leo-Lum-Window-IR-average'), (28, u's-11-serverRoom-room-Temp-average'), (29, u's-11-serverRoom-room-Temp-max'), (30, u's-11-serverRoom-room-Temp-min'), (31, u'MeterTotalLeftBox-Power-average'), (32, u'MeterTotalLeftBox-Power-max'), (33, u'MeterTotalLeftBox-Energy-average'), (34, u'MeterTotalLeftBox-Energy-max'), (35, u'blueJacketLeoII-Temp-average'), (36, u'MotionSensorOutsideFront-On/Off-event'), (37, u'windsensor-WindDi-average'), (38, u'windsensor-AvgWin-average'), (39, u'b-radius-1-closest-eventDOWN'), (40, u'b-radius-1-closest-eventAny'), (41, u'b-radius-1-closest-eventCHANGE'), (42, u'MeterTotalLeftBox-Energy-D-NHour'), (43, u'MeterTotalRightBox-Energy-average'), (44, u'MeterTotalRightBox-Power-average'), (45, u'MeterTotalRightBox-Energy-D-NHour'), (46, u'MeterTotalRightBox-Power-D-NHour'), (47, u's-14-bme-->display-Temp-average'), (48, u's-11-serverRoom-GW-Temp-average')] calledfrom :redoParam
18:30:07             - redolineDataSource  called from : cleanData
18:30:07             -redolineDataSource: listOfSelectedDataColumnsAndDevPropName[(0, 'None'), (1, u's-9-TP-MB-inside-Temp-average'), (2, u's-9-TP-MB-inside-Pressur-average'), (3, u'youGotMail-On/Off-average'), (4, u's-8-THP-kitchen-Temp-average'), (5, u's-8-THP-kitchen-Humidit-average'), (6, u's-8-THP-kitchen-Pressur-average'), (7, u's-14-bme-->display-Temp-average'), (8, u's-14-bme-->display-Humidit-average'), (9, u's-14-bme-->display-Pressur-average'), (10, u's-5-bmp180-Temp-average'), (11, u's-5-bmp180-Pressur-average'), (12, u'MotionSensorOutsideBack-On/Off-event'), (13, u'Tempattic-Temp-average'), (14, u'Var-alarm_front_door-event'), (15, u'freezer-Temp-average'), (16, u's-2-T-Leo-inside-Temp-average'), (17, u'c-volvo-Presenc-max-NFGap'), (18, u'leo-Temp-average'), (19, u'poolTemp-Temp-average'), (20, u'fridge-Temp-average'), (21, u'poolTemp-broken-Temp-average'), (22, u'MotionSensorLivingRoom-On/Off-event'), (23, u's-11-serverRoom-switch-exaust-Temp-average'), (24, u's-11-serverRoom-mac-Temp-average'), (25, u's-2-Leo-Lum-Window-illumin-average'), (26, u's-2-Leo-Lum-Window-ambient-average'), (27, u's-2-Leo-Lum-Window-IR-average'), (28, u's-11-serverRoom-room-Temp-average'), (29, u's-11-serverRoom-room-Temp-max'), (30, u's-11-serverRoom-room-Temp-min'), (31, u'MeterTotalLeftBox-Power-average'), (32, u'MeterTotalLeftBox-Power-max'), (33, u'MeterTotalLeftBox-Energy-average'), (34, u'MeterTotalLeftBox-Energy-max'), (35, u'blueJacketLeoII-Temp-average'), (36, u'MotionSensorOutsideFront-On/Off-event'), (37, u'windsensor-WindDi-average'), (38, u'windsensor-AvgWin-average'), (39, u'b-radius-1-closest-eventDOWN'), (40, u'b-radius-1-closest-eventAny'), (41, u'b-radius-1-closest-eventCHANGE'), (42, u'MeterTotalLeftBox-Energy-D-NHour'), (43, u'MeterTotalRightBox-Energy-average'), (44, u'MeterTotalRightBox-Power-average'), (45, u'MeterTotalRightBox-Energy-D-NHour'), (46, u'MeterTotalRightBox-Power-D-NHour'), (47, u's-14-bme-->display-Temp-average'), (48, u's-11-serverRoom-GW-Temp-average')] calledfrom :cleanData
18:30:15             -pickExistingOrNewDeviceCALLBACK    devNo 0 old d2;;  pickExistingOrNewDeviceCALLBACK-vd UiValuesDict : (dict)
     DefineDevices :  (string)
     DefineDevicesAndNew : false (bool)
     DefineDevicesAndOld : false (bool)
     DefineDevicesDummy : true (bool)
     DeleteDevice : false (bool)
     DeleteDeviceEmpty :  (string)
     buttonConfirmDeviceProps :  (string)
     expertONOFF : true (bool)
     fillGaps1 : 1 (string)
     fillGaps2 : 1 (string)
     fillGaps3 : 1 (string)
     fillGaps4 : 1 (string)
     fillGaps5 : 1 (string)
     fillGaps6 : 1 (string)
     fillGaps7 : 1 (string)
     fillGaps8 : 1 (string)
     idbuttonConfirmDevice :  (string)
     la1 :  (string)
     la2 :  (string)
     la3 :  (string)
     la4 :  (string)
     la5 :  (string)
     la6 :  (string)
     la7 :  (string)
     la8 :  (string)
     nickName1 :  (string)
     nickName2 :  (string)
     nickName3 :  (string)
     nickName4 :  (string)
     nickName5 :  (string)
     nickName6 :  (string)
     nickName7 :  (string)
     nickName8 :  (string)
     resetPeriods1 : 0 (string)
     resetPeriods2 : 0 (string)
     resetPeriods3 : 0 (string)
     resetPeriods4 : 0 (string)
     resetPeriods5 : 0 (string)
     resetPeriods6 : 0 (string)
     resetPeriods7 : 0 (string)
     resetPeriods8 : 0 (string)
     resetType1 :  (string)
     resetType2 :  (string)
     resetType3 : %%selectFirstItemVal%% (string)
     resetType4 :  (string)
     resetType5 :  (string)
     resetType6 :  (string)
     resetType7 :  (string)
     resetType8 :  (string)
     s1 :  (string)
     s1-2 :  (string)
     selDeviceStatea1 :  (string)
     selDeviceStatea2 :  (string)
     selDeviceStatea3 :  (string)
     selDeviceStatea4 :  (string)
     selDeviceStatea5 :  (string)
     selDeviceStatea6 :  (string)
     selDeviceStatea7 :  (string)
     selDeviceStatea8 :  (string)
     selDevicemaxValue1 : +50000.0 (string)
     selDevicemaxValue2 : +50000.0 (string)
     selDevicemaxValue3 : +50000.0 (string)
     selDevicemaxValue4 : +50000.0 (string)
     selDevicemaxValue5 : +50000.0 (string)
     selDevicemaxValue6 : +50000.0 (string)
     selDevicemaxValue7 : +50000.0 (string)
     selDevicemaxValue8 : +50000.0 (string)
     selDevicemeasurement1 : average (string)
     selDevicemeasurement2 :  (string)
     selDevicemeasurement3 :  (string)
     selDevicemeasurement4 :  (string)
     selDevicemeasurement5 :  (string)
     selDevicemeasurement6 :  (string)
     selDevicemeasurement7 :  (string)
     selDevicemeasurement8 :  (string)
     selDeviceminValue1 : -200.0 (string)
     selDeviceminValue2 : -200.0 (string)
     selDeviceminValue3 : -200.0 (string)
     selDeviceminValue4 : -200.0 (string)
     selDeviceminValue5 : -200.0 (string)
     selDeviceminValue6 : -200.0 (string)
     selDeviceminValue7 : -200.0 (string)
     selDeviceminValue8 : -200.0 (string)
     selDevicemultiplier1 : 1.0 (string)
     selDevicemultiplier2 : 1.0 (string)
     selDevicemultiplier3 : 1.0 (string)
     selDevicemultiplier4 : 1.0 (string)
     selDevicemultiplier5 : 1.0 (string)
     selDevicemultiplier6 : 1.0 (string)
     selDevicemultiplier7 : 1.0 (string)
     selDevicemultiplier8 : 1.0 (string)
     selDeviceoffset1 : 0.0 (string)
     selDeviceoffset2 : 0.0 (string)
     selDeviceoffset3 : 0.0 (string)
     selDeviceoffset4 : 0.0 (string)
     selDeviceoffset5 : 0.0 (string)
     selDeviceoffset6 : 0.0 (string)
     selDeviceoffset7 : 0.0 (string)
     selDeviceoffset8 : 0.0 (string)
     selectDeviceStatesOK : false (bool)
     selectedDeviceID :  (string)
     selectedExistingOrNewDevice : 0 (string)
     testxx : false (bool)
     text1-1 :   and then confirm ! (string)
     text1-2 :   and then confirm ! (string)
18:30:22             - confirmDevice adding new device,  currentDevNo
<+++++ around here it should crash  +++++>
18:30:22             -29
18:30:22             - confirmDevice adding new device,  selectedDeviceID =375541516  <+++++ around here it should crash
18:30:22             - confirmDevice adding new device,  deviceIdNew =375541516
18:30:22             -confirmDevice 1 device DevOrVarNew Dev-
18:30:22             -preSelectStates   devID: 375541516; deviceDevOrVarNew: Dev- retList: [(u'avgSpeed', 'Avg Wind Speed'), (u'batteryLevel', 'Battery Level [%]'), (u'directionDegrees', 'Wind Direction [Deg]'), (u'display', u'display'), (u'gust', 'Wind Gust'), (u'signalStrength', u'signalStrength'), (u'temperature', 'Temperature'), (u'type', u'type'), (u'windChill', u'windChill')]
karl
Sun Jul 16, 2017 10:31 pm
Mon Jul 17, 2017 5:39 pm
johnpolasek offline
THANKS! That did fix it; now I just need to figure out why one of my acs doesn't have as much delta t across the coil as it should...
