"out of min/max range"
Mon Jan 02, 2017 9:11 am
Different Computers offline
I keep getting this in the event log, and can't figure out how to fix it. Any help?
   INDIGOplotD                     getIndigoData  Current Energy/accumEnergyTimeDelta  out of min/max range: -200.0< 122315.0< 50000.0
Mon Jan 02, 2017 11:53 am
kw123 online
Re: "out of min/max range"
Either the data is bad or the min max is set to low/high. It is set in menu "data / select data sources, needed in Plots"... for each device/state
Ignore if ... LESS than
... if GREATER than
