Labels overlap
Fri Dec 30, 2016 1:58 am
haavarda offline
Labels overlap
Hi Karl.
If you see the image below, you can see that the labels for the right scale is overlapping. Any idea on how to avoid this?
I have done some upgrades, so I ended up starting from scratch, and that is when this came up.
Thanks.
Plott- Garage climate-hour-S2.png (35.53 KiB) Viewed 1919 times
Håvard
Fri Dec 30, 2016 7:52 am
Re: Labels overlap
There is one line type -filled xx I believe .. that is actually not a line but a composed object out of 2 lines the data line and the x axis - that does not have a line key in mat plot . I fake it at a fixed position = place a text manually
It seems to be at the same position as the first label in this size / config. The regular line keys shift around so it is not easy to find a position to put it
Tue Jan 03, 2017 3:02 am
haavarda offline
Re: Labels overlap
Ok. Just so I am sure I understand. In short there is nothing to do about this? If you have two filled lines the label will overlap?
Håvard
Tue Jan 03, 2017 8:45 am
Re: Labels overlap
Yes.
Wait one week will add an
Offset
Fri Jan 06, 2017 7:43 pm
Re: Labels overlap
the new version 4-16-18 should have this fixed.
Sun Jan 08, 2017 10:53 am
haavarda offline
Re: Labels overlap
Thanks for the update. It fixed all my plots. Perfect.
Håvard
