Plotting X and Y from two variables (X = Var1, Y =Var2)
Fri Sep 02, 2016 5:09 am
Gusten offline
Hi
Is there a way to plot both X and Y directly from two different variables. (float)
I know its possible to do from file or from one variable where both X & Y are present in. ?
I have an Automower were i get Longitud and Latitude and i have those in two variables and they updates every 15 sec when the automower is out and Cuts my grass.
So my idé was to have a plot were X = Longitude Y = Latitude and every 15 sec i get an "dot" on the plot, so when i Wake up in the morning i can see if the mower have cut all my lawn.
If this is going to work it should altso bee possible to limit the time of the plot, for example the plots shows only data from 24 hours back.
And of course i will have a map of my garden behind the transperent plot
OR
Is there a easy way to make indigo variables written to a file according to INDIGOplotD standards ?
/Martin
Fri Sep 02, 2016 8:08 am
Re: Plotting X and Y from two variables (X = Var1, Y =Var2)
I believe so yes. Traveling right now.
Will send you a script later.
Need a ; delimited file
First line #xcolumnName;column name
Next lines
X;y
X;y
Then in edit plot device select the file in 1 or second field. ( Need to select data from file. )
The file needs to be in ~/indigoplotd/data directory
Then select in lines the 2 columns
That's it roughly.
Fri Sep 02, 2016 1:30 pm
here the first screen to setup the plot
Screen Shot 2016-09-02 at 3.23.57 PM.png (131.16 KiB) Viewed 4174 times
you need to change filename
and x/y scales set to 0...50
now how to get the data into a file
you could setup a script that runs every 15 minutes and adds the contents of the variables into a file
run every 15 minutes
import subprocess
v1=indigo.variables["vari1 name"].value
v2=indigo.variables["vari2 name"].value
subprocess.Popen("echo '"+v1+";"+v2+"' >> /users/yourID/documents/indigoplotd/data/myFile",shell=True))
before you add the data you need to add the first line, eg at midnight: run a schedule action. it will reset the file
import subprocess
subprocess.Popen("echo '#x;y' > /users/yourID/documents/indigoplotd/data/myFile",shell=True))
setup the line:
Screen Shot 2016-09-02 at 4.26.21 PM.png (110.86 KiB) Viewed 4162 times
this dataset:
#x;y
1;2
2;2.3
2.5;2.5
2.5;3.5
2.;3.3
1;4
1.3;4.5
4.0;4.5
will create this output:
Screen Shot 2016-09-02 at 10.39.09 PM.png (35.48 KiB) Viewed 4143 times
Fri Sep 02, 2016 9:21 pm
updated above example.
Sat Sep 03, 2016 1:46 am
Gusten offline
H
I get an error when trying the script
import subprocess
v1=indigo.variables["Automowerlongitude"].value
v2=indigo.variables["Automowerlatitude"].value
subprocess.Popen("echo '"+v1+";"+v2+"' >> /users/smarthem/documents/indigoplotd/data/automower.rtf",shell=True))
Script Error automowerfileupdate.py: EOL while scanning string literal
Script Error around line 6 - "subprocess.Popen("echo '"+v1+";"+v2+"' >> /users/smarthem/documents/indigoplotd/data/automower.rtf,shell=True))"
I tried to see what i did wrong, but cant find it, any idea?
/Martin
Sat Sep 03, 2016 6:13 am
There is " missing after rtf
Sat Sep 03, 2016 6:14 am
And just one ) at the end
Sun Sep 04, 2016 11:34 pm
Gusten offline
Its working outstanding :-)
Did a test plot overnight., without any "fancy" background images
See the attached image
Thank you Karl for all help :-)
/Martin
GPS Automower-S2.png (68.85 KiB) Viewed 3974 times
Mon Sep 05, 2016 5:09 am
Are you sure? The mower seems quite drunk to me.
Dave
Mon Sep 05, 2016 7:01 am
May I suggest to increase the frequency of dots. if you currently use 15 minutes between dots the mower should cover quit a bit of distance including changing directions (if your property is several km long than thats ok..) :lol:
to better display the coordinates:
if the length of your property is 123m and you would like to to have the coordinates in meters:
import subprocess
v1=str((float(indigo.variables["vari1 name"].value)-12.047)*1000.*123.)
v2=str((float(indigo.variables["vari2 name"].value)-57.573)*1000.*123.)
then x and range: 0:12300 ( you have to figure out the proper scale)
or something like this
is there a lake in the middle?
you should add trees etc to the picture!
let me know if you need help to add images to the plot.
Mon Sep 05, 2016 1:07 pm
Gusten offline
The coordinates updates every 20sec but when i looked at the file i can see that the mower docent update so fast, about every 30-40sec, so i will change it.
I can see why you think its drunk :-)
I attached a new image, where you can see a little more whats its done.
(And no, it did not go in the pool :-)
A have a bit of "dialing in" to do with the coordinates to get it symmetrical and to get it correct.
As for attaching an image to the plot, my plan was to use an transparent plot over an image, but maybe you know a better way?
/Martin
Screen Shot 2016-09-05 at 20.56.13.png (406.82 KiB) Viewed 3910 times
Mon Sep 05, 2016 2:02 pm
Yes that's fine with transparent image. But you could also play around with transparent background and or transparent lines in the plot.
