Change how often plots are generated?
Tue Aug 30, 2016 7:45 am
nataylor offline
Is there a way to change how often plots are generated? It seems to default to every 5 minutes. I'd like to change it to every 30 minutes.
Tue Aug 30, 2016 7:58 am
Re: Change how often plots are generated?
Is there a reason you like to change that?
There an option to do it more often but not less.
Tue Aug 30, 2016 9:20 am
nataylor offline
I generate a number of plots and sync them to other computers via Dropbox. With the plots generating every five minutes, there's a lot getting synced that I just don't need. I'd be fine if they only updated and synced every 30 minutes.
I can work around this by using a separate tool to copy the plots to my Dropbox folder every 30 minutes. But I figured I'd ask to see if there was some obvious setting I was missing for changing how often the plots updated.
Tue Aug 30, 2016 9:39 am
i can look into that, but not in the next 2 weeks
Tue Aug 30, 2016 9:41 am
nataylor offline
Not a problem. Like I said, I just wanted to know if I was missing something obvious. Thanks for making such a useful tool!
