energy consumption plot
Posted: Tue Feb 23, 2016 10:32 pm
Here the steps do do this plot .. hope that helps.
select the data:
but for ENEGRY you must select a reset frequency, otherwise will you will only have a line that goes up continuously and the values might be VERY large >> 100000 as it is the accumulated energy since last reset . You can select a reset once a day(used in this plot) or once a week or every xx days.
use the normal properties (i.e. average) for power(Watts), temperature etc
Setup the energy consumption histogram, here just the engr. histogram
The attached gives the properties used in the program for all lines. The parameters should be understandable they map one to one to the input fields
the energy line is the one with "" -l# 15/Energy Week/4 Color>#000000<; EveryRepeat>1<; Func>None<; LeftRight>Right<; Multiplier>0.25<; NumbersFormat><; Nu..."
the marker points are created (e.g. max: 59) with " EveryRepeat>max<..."
select the data:
- Code: Select all
Feb 23, 2016, 10:14:48 PM
INDIGOplotD pending indigoCommands: ['PrintPlotData:309579619']
PLOT:: EnergyUsage ü deviceID: 309579619
...Background >>#FFFFFF<<
...Border >>1+2+4+8<<
...DeviceNamePlot >>EnergyUsage ü<<
...ExtraText >><<
...ExtraTextColorRGB >>#000000<<
...ExtraTextFrontBack >>front<<
...ExtraTextRotate >>0.0<<
...ExtraTextSize >>10<<
...ExtraTextXPos >>0.0<<
...ExtraTextYPos >>0.0<<
...Grid >>0<<
...LeftLabel >> Power[W]<<
...LeftLog >>linear<<
...LeftScaleDecPoints >>0<<
...LeftScaleRange >>-15000:11500<<
...LeftScaleTics >>0,1000,2000,3000,4000,5000,6000,7000,8000,9000,10000<<
...MHDDays >>[1, 14, 0]<<
...MHDShift >>[0, -11, 0]<<
...NumberIsUsed >>1<<
...PlotFileLastUpdate >>0<<
...PlotFileOrVariName >><<
...PlotType >>dataFromTimeSeries<<
...Raw >><<
...RightLabel >>Energy KWH(*0.1) and KWH*cost<<
...RightLog >>linear<<
...RightScaleDecPoints >>0<<
...RightScaleRange >>0:400<<
...RightScaleTics >>0,50,100,150,200,250<<
...TextColor >>#000000<<
...TextFont >>System-font<<
...TextMATFont >>sans-serif<<
...TextSize >>10<<
...Textscale21 >>1.5<<
...TitleText >>Energy<<
...TransparentBackground >><<
...TransparentBlocks >>1.0<<
...XLabel >>x-axis Text<<
...XLog >>linear<<
...XScaleDecPoints >>0<<
...XScaleFormat >><<
...XScaleRange >><<
...XScaleTics >><<
...XYvPolar >>xy<<
...ampm >>24<<
...compressPNGfile >>False<<
...dataSource >>interactive<<
...drawZeroLine >>false<<
...resxy >>[u'850,600', u'']<<
...variableInText >><<
...variableinPlot >><<
-l# 1/W Color>#4B0082<; EveryRepeat>1<; Func>None<; LeftRight>Left<; Multiplier>1.0<; NumbersFormat><; NumbersOffset><; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>66<; ToColumnIndexB>0<; Type>LineSolid<; Width>2<
-l# 2/Kwh Color>#00FFFF<; EveryRepeat>1<; Func>None<; LeftRight>Right<; Multiplier>1.0<; NumbersFormat><; NumbersOffset><; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>64<; ToColumnIndexB>0<; Type>Histogram<; Width>0<
-l# 3/avL Color>#4B0082<; EveryRepeat>1<; Func>None<; LeftRight>Left<; Multiplier>1.0<; NumbersFormat><; NumbersOffset><; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>66<; ToColumnIndexB>0<; Type>averageLeft<; Width>4<
-l# 4/ Color>#00FFFF<; EveryRepeat>1<; Func>None<; LeftRight>Right<; Multiplier>1.0<; NumbersFormat><; NumbersOffset><; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>64<; ToColumnIndexB>0<; Type>averageRight<; Width>3<
-l# 5/Cost*10 Color>#00A000<; EveryRepeat>1<; Func>None<; LeftRight>Right<; Multiplier>10.0<; NumbersFormat><; NumbersOffset><; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>65<; ToColumnIndexB>0<; Type>LineSolid<; Width>3<
-l# 7/MAX Color>#A00000<; EveryRepeat>max<; Func>None<; LeftRight>Left<; Multiplier>1.0<; NumbersFormat>MAX: %d[W]<; NumbersOffset>1,0.2<; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>66<; ToColumnIndexB>0<; Type>Numbers<; Width>2<
-l# 8/day Color>#00FFFF<; EveryRepeat>day<; Func>None<; LeftRight>Right<; Multiplier>1.0<; NumbersFormat>%d<; NumbersOffset>1,0<; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>64<; ToColumnIndexB>0<; Type>Numbers<; Width>1<
-l# 9/day Color>#00A000<; EveryRepeat>day<; Func>None<; LeftRight>Right<; Multiplier>10.0<; NumbersFormat>%d<; NumbersOffset>-0,0.7<; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>65<; ToColumnIndexB>0<; Type>Numbers<; Width>2<
-l# 10/MIN Color>#FF0000<; EveryRepeat>min<; Func>None<; LeftRight>Left<; Multiplier>1.0<; NumbersFormat>Min: %d[W]<; NumbersOffset>0.7,-0.1<; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>66<; ToColumnIndexB>0<; Type>Numbers<; Width>1<
-l# 13/ Color>#FF0000<; EveryRepeat>min<; Func>None<; LeftRight>Left<; Multiplier>1.0<; NumbersFormat><; NumbersOffset><; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>66<; ToColumnIndexB>0<; Type>DOT*<; Width>1<
-l# 14/ Color>#A00000<; EveryRepeat>max<; Func>None<; LeftRight>Left<; Multiplier>1.0<; NumbersFormat><; NumbersOffset><; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>66<; ToColumnIndexB>0<; Type>DOT*<; Width>1<
-l# 15/Energy Week/4 Color>#000000<; EveryRepeat>1<; Func>None<; LeftRight>Right<; Multiplier>0.25<; NumbersFormat><; NumbersOffset><; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>1<; ToColumnIndexB>0<; Type>LineSolid<; Width>3<
-l# 18/ Color>#000000<; EveryRepeat>lastBin<; Func>None<; LeftRight>Right<; Multiplier>0.25<; NumbersFormat>%3d<; NumbersOffset>-0.2,0.5<; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>1<; ToColumnIndexB>0<; Type>Numbers<; Width>1<
INDIGOplotD
Schedule checkNOAARainStatus
Sent INSTEON "poolHeater" off
