All devices in plots have disappeared.
Sun Nov 29, 2015 9:11 am
aderrington offline
I've just noticed that all the devices/variables that were in 2 of my plots have disappeared. When i go to "Define / select data sources...." there are no existing devices or variables anymore....
Is there any reason these would all disappear?
Andrew
Sat Feb 27, 2021 3:51 am
Hans Kiesewetter offline
Re: All devices in plots have disappeared.
Dear Karl,
I have the same problem: Since 7 Feb, my plots are not upated.
First,
- start/stopped plugin
- start/stopped MacMini
- I updated INDIGOplotD to the latest version.,
all without result
Then I discovered that the SQL databases were not updated, so did an update of this plugin too, but no result
Next step was to look at the plot definitions and then discovered that there were no variables define in INDIGOplotD anymore!
I updated to Indigo 7.5 somewhere in January.
Question: Is it possible to restore data for INDIGOplotD from the old 7.4 folder by copying some files?
Sat Feb 27, 2021 10:15 am
Check config. The path to data, sql, etc. there should be some references to 7.4. Replace w 7.5
