INDIGOplotD -- a plot tool for indigo
Mon Sep 19, 2016 10:57 am
mortenkols offline
Re: INDIGOplotD -- a plot tool for indigo
hehe. it works!!=)
Mon Sep 19, 2016 10:59 am
thanks for testing
Mon Sep 19, 2016 11:20 am
mortenkols offline
draw invisible line at zero only works on some plots. hows that?
Mon Sep 19, 2016 11:21 am
don't know... :oops:
Mon Sep 19, 2016 8:27 pm
draw invisible line at zero only works on some plots. hows that?:
is it enabled in the plot?
Screen Shot 2016-09-19 at 21.25.47.png (24.4 KiB) Viewed 7371 times
Tue Sep 20, 2016 4:40 am
mortenkols offline
yes. it is.
Skjermbilde 2016-09-20 kl. 12.39.31.png (36.48 KiB) Viewed 7471 times
Skjermbilde 2016-09-20 kl. 12.39.18.png (19.5 KiB) Viewed 7471 times
Tue Sep 20, 2016 7:04 am
Coukd you Dropbox the plot defs and gnu files ?
Tue Sep 20, 2016 9:12 am
mortenkols offline
Tue Sep 20, 2016 9:23 am
they all have the line defined in the gnuplot files, eg:
,''   using 1:($2-$2)  with  lines  linetype 0    linewidth 1   linecolor  rgb "#FFFFFF"   title ""  axis x1y1
$2-$2 is zero -- it uses the x coordinate and y=0
why do you think it is not there? it should be invisible. , that might not work. but if it is invisible you should not see it .
it purpose is not to draw a line, to force gnuplot to show the whole range selected.
sometimes when there is no data left or right, gnuplot does not show that part.
thats why it was added to plot a "fake" line at the x axis from left to right.
Tue Sep 20, 2016 9:59 am
if you wan to add a VISIBLE line at y=0: add a special line , then set its color etc.
Screen Shot 2016-09-20 at 10.58.11.png (24.25 KiB) Viewed 7384 times
Tue Sep 20, 2016 10:14 am
mortenkols offline
ah okey :D i will try it
Wed Sep 21, 2016 10:07 am
working ok "EVENT PLOTTING":
currently indigoplotD plots averages (or min/max ..) in certain time bins (5 min/1hour/1day)
planned:
get data from SQLlogger, and plot (time,Yvalues) for each event. This can be used for eg. Door was opened or light went on or alarm triggered .. plots = short events that will not show up in averages.
or just any data as it comes in eg electricity consumption, any variable changed etc ..
you can do this manually now:
- in utilities create a report (separator=";"),
- create plot device
- select "data from file"
- set range and time format
- define the line and configure it
then run utilities every x minutes (can be done in a script)
a little bit cumbersome...
anyone interested?
Fri Sep 23, 2016 4:15 pm
Sharek326 offline
Hello
Recently I seemed to have finally got INDIGOplotD setup and working correctly for Power and Energy in my house everyday since I started it the Energy plot worked correctly until today. Below is a picture. The day that clipped past 60 read correctly as 32 all month until today. What caused that?
Fri Sep 23, 2016 4:20 pm
please try:
1. menu/indigoplotd/import sql (all records)
2. use utilities to print a report on that data: use # of records ~ 500, from the beginning (not the last records)
3. send (dropbox) the file device#-state (eg:/Users/yourid/Documents/INDIGOplotD/sql/185536022-status) for that device/state
Fri Sep 23, 2016 4:30 pm
Sharek326 offline
The Import step lost me which menu...the Plugin menu? I don't see an import all
