INDIGOplotD -- a plot tool for indigo
Sat Sep 17, 2016 11:24 am
mortenkols offline
Re: INDIGOplotD -- a plot tool for indigo
Gonna test it later Thanks. I am impressed by the support you give
Sat Sep 17, 2016 11:38 am
My pleasure
Sat Sep 17, 2016 12:47 pm
mortenkols offline
it works. THANKS :)
Sun Sep 18, 2016 3:19 am
mortenkols offline
I have a HOUR plot for 61 days. but the day/month in the bottom of the plot does not change. Its only stands THU.
Im also getting a new error message every 5 min, but its not from the same plot
18. sep. 2016, 11.37.01
INDIGOplotD plotting GNUPLOT error/warning for /Users/mortenolsen/Documents/INDIGOplotD/gnu/Statestikk temperatur inne-day-S2
INDIGOplotD "/Users/mortenolsen/Documents/INDIGOplotD/gnu/Statestikk temperatur inne-day-S2.gnu", line 47: warning: Cannot find or open file "/Users/mortenolsen/Documents/INDIGOplotD/data/Statestikk temperatur inne-Day-5.dat"
"/Users/mortenolsen/Documents/INDIGOplotD/gnu/Statestikk temperatur inne-day-S2.gnu", line 47: warning: Cannot find or open file "/Users/mortenolsen/Documents/INDIGOplotD/data/Statestikk temperatur inne-Day-6.dat"
Skjermbilde 2016-09-18 kl. 11.14.20.png (89.07 KiB) Viewed 7046 times
Sun Sep 18, 2016 6:40 am
Could you post the plot definition of that plot? Gnu plot complains that min or max file was not created.
As for the Thursday only, I need to look into the code.
Sun Sep 18, 2016 6:48 am
mortenkols offline
This you want?
I have changed the name of the plot
18. sep. 2016, 14.46.18
INDIGOplotD pending indigoCommands: ['PrintPlotData:960272743']
PLOT:: IndigoPlotD - Statestikk temperatur inne deviceID: 960272743
...Background >>#FFFFFF<<
...Border >>1+2+4+8<<
...DeviceNamePlot >>IndigoPlotD - Statestikk temperatur inne<<
...ExtraText >><<
...ExtraTextColorRGB >>#000000<<
...ExtraTextFrontBack >>front<<
...ExtraTextRotate >>0.0<<
...ExtraTextSize >>10<<
...ExtraTextXPos >>0.0<<
...ExtraTextYPos >>0.0<<
...Grid >>2onlyx<<
...LeftLabel >>Temperatur C<<
...LeftLog >>linear<<
...LeftScaleDecPoints >>0<<
...LeftScaleRange >>12:35<<
...LeftScaleTics >>12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35<<
...MHDDays >>[1, 7, 31]<<
...MHDShift >>[-1, -10, -20]<<
...NumberIsUsed >>1<<
...PlotFileLastUpdate >>0<<
...PlotFileOrVariName >><<
...PlotType >>dataFromTimeSeries<<
...Raw >><<
...RightLabel >>Temperatur C<<
...RightLog >>linear<<
...RightScaleDecPoints >>0<<
...RightScaleRange >>-34:34<<
...RightScaleTics >>-34,-32,-30,-28,-26,-24,-22,-20,-18,-16,-14,-12,-10,-8,-6,-4,-2,0,2,4,6,8,10,12,14,16,18,20,22,24,26,28,30,32,34<<
...TextColor >>#000000<<
...TextFont >>0<<
...TextMATFont >>sans-serif<<
...TextSize >>10<<
...Textscale21 >>1.5<<
...TitleText >>Temperatur inne <<
...TransparentBackground >>1.0<<
...TransparentBlocks >>0.1<<
...XLabel >>x-axis Text<<
...XLog >>linear<<
...XScaleDecPoints >>0<<
...XScaleFormat >><<
...XScaleRange >><<
...XScaleTics >><<
...XYvPolar >>xy<<
...ampm >>24<<
...compressPNGfile >>False<<
...dataSource >>interactive<<
...drawZeroLine >>false<<
...resxy >>['', u'1024,768']<<
...variableInText >>yes<<
...variableinPlot >><<
-l# 1/Stue Color>#FF0000<; EveryRepeat>1<; FromTo><; Func>None<; LeftRight>Left<; Multiplier>1.0<; NumbersFormat><; NumbersOffset><; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>3<; ToColumnIndexB>0<; Type>FilledCurves<; Width>1<
-l# 2/Gang 1. etg Color>#A0A000<; EveryRepeat>1<; FromTo><; Func>None<; LeftRight>Left<; Multiplier>1.0<; NumbersFormat><; NumbersOffset><; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>5<; ToColumnIndexB>0<; Type>FilledCurves<; Width>1<
-l# 3/Kjellerstue Color>#383838<; EveryRepeat>1<; FromTo><; Func>None<; LeftRight>Left<; Multiplier>1.0<; NumbersFormat><; NumbersOffset><; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>4<; ToColumnIndexB>0<; Type>FilledCurves<; Width>1<
-l# 4/Ute Color>#000000<; EveryRepeat>2<; FromTo><; Func>None<; LeftRight>Right<; Multiplier>1.0<; NumbersFormat><; NumbersOffset><; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>6<; ToColumnIndexB>0<; Type>LineDashed<; Width>1<
-l# 5/ Color>#00A000<; EveryRepeat>maxDay<; FromTo><; Func>None<; LeftRight>Right<; Multiplier>1.0<; NumbersFormat>%3.1f<; NumbersOffset>0,1<; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>14<; ToColumnIndexB>0<; Type>Numbers<; Width>1<
-l# 6/ Color>#A00000<; EveryRepeat>minDay<; FromTo><; Func>None<; LeftRight>Right<; Multiplier>1.0<; NumbersFormat>%3.1f<; NumbersOffset>0,1<; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>15<; ToColumnIndexB>0<; Type>Numbers<; Width>1<
-l# 7/ Color>#000000<; EveryRepeat>maxMonth<; FromTo><; Func>None<; LeftRight>Right<; Multiplier>1.0<; NumbersFormat>%3.1f<; NumbersOffset>0,1<; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>14<; ToColumnIndexB>0<; Type>Numbers<; Width>1<
-l# 8/ Color>#000000<; EveryRepeat>minMonth<; FromTo><; Func>None<; LeftRight>Right<; Multiplier>1.0<; NumbersFormat>%3.1f<; NumbersOffset>0,1<; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>15<; ToColumnIndexB>0<; Type>Numbers<; Width>1<
-l# 11/TempStue gjennomsnitt strek Color>#000000<; EveryRepeat>1<; FromTo><; Func>None<; LeftRight>Left<; Multiplier>1.0<; NumbersFormat><; NumbersOffset><; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>3<; ToColumnIndexB>0<; Type>averageLeft<; Width>1<
-l# 12/Bad Color>#00FFFF<; EveryRepeat>1<; FromTo><; Func>None<; LeftRight>Left<; Multiplier>1.0<; NumbersFormat><; NumbersOffset><; Offset>0.0<; Shift>0<; Smooth>None<; ToColumnIndexA>18<; ToColumnIndexB>0<; Type>FilledCurves<; Width>1<
INDIGOplotD
Sun Sep 18, 2016 6:51 am
Yes. Will look at it after bf
Sun Sep 18, 2016 7:07 am
And I would need also the file day.dat.formatted. It is a bit longer. Could lost it in dropbox and mail me a link?
Sun Sep 18, 2016 7:17 am
mortenkols offline
Sun Sep 18, 2016 7:30 am
also need the hour.dat.fomatted and the xxx.gnu file.
dropbox would be ok.
Sun Sep 18, 2016 7:34 am
mortenkols offline
Sun Sep 18, 2016 7:41 am
which of these files exist?
,'/Users/mortenolsen/Documents/INDIGOplotD/data/IndigoPlotD - Statestikk temperatur inne-Day-5.dat'
,'/Users/mortenolsen/Documents/INDIGOplotD/data/IndigoPlotD - Statestikk temperatur inne-Day-6.dat'
,'/Users/mortenolsen/Documents/INDIGOplotD/data/IndigoPlotD - Statestikk temperatur inne-Day-7.dat'
,'/Users/mortenolsen/Documents/INDIGOplotD/data/IndigoPlotD - Statestikk temperatur inne-Day-8.dat'
This is a data problem. It plotD does not find a min or max value (*) and then the file with the min/max coordinated does not get created, THEN gnuplot issues a warning that there is no data.
(*) don't understand why, might be negative numbers ... will take some digging .
Sun Sep 18, 2016 7:47 am
just saw you are using time shifted plots. know where I have to look... but first BF and Kaffee
Sun Sep 18, 2016 10:12 am
what is your shift setup? could you send a screen copy of the plot config (step2)
