Newbie error? Can't see my first plot?!
Wed Jun 13, 2018 5:23 pm
Re: Newbie error? Can't see my first plot?!
For simple plot you don’t need the define data sources. It does it also.
The regular way is to
1. Define data sources
2. Create plots ( indigoplotd device ) and use up to 100 data sources ( as lines histograms ...) in one plot
The simple one does only one line and you can’t set a lot of colors etc
But once defined you then can switch to regular plot edit and can set everything
Simple is meant to do a quick plot. Should take less than a minute to show the plot.
But data only is there if you use sqlloggger
If no sqllogger it will start collecting data once the data source is defined.
Ps you can overlay things, use extra text use variables in all text fields eg y scale, axis descriptions, keys etc with %%v:variname%% or vari is
Also set axis descriptions to text eg instead of 0/1 show low / high or on off on eg the right scale
