INDIGOplotD -- a plot tool for indigo -- program download
Wed Jan 18, 2017 12:21 pm
Re: INDIGOplotD -- a plot tool for indigo -- program downlo
posted v 4-16-19 in downloads http://forums.indigodomo.com/viewtopic.php?f=165&t=15884&p=113648#p113648
fixed:
...."colVaru" not ... for polar plots in gnuplot (the "u" should have not been there)
will check the other things later
Wed Jan 18, 2017 10:09 pm
posted v-4-16-20http://forums.indigodomo.com/viewtopic.php?f=165&t=15884
fixed some other things (variables not dome right) with polar plot in gnuplot .. should work again.. sorry for the mess.
Thu Feb 09, 2017 10:21 am
posted v 4-16-21 http://forums.indigodomo.com/viewtopic.php?f=165&t=15884
added:
now supports text values in devices/states or variables (any upper / lower case) - Text ==> converted to Number -1/0/1:
TRUE, T, ON, HOME, YES, UP, CLEAR, ENABLe, ARRIVe ====> 1
FALSE, T, AWAY, OFF, NO, DOWN, FAULTED, FAULT, EXPIRED, STOP ====> 0
LEAVe, LEAVing, LEFT, UNKnown ====> -1
(UNKnow = if UNK are the first 3 lettesr LEAVing if LEAV are the first 4 letters ... )
The new values LEAVE LEAVING, LEFT STOP, ARRIVed are used in CARs device types in the pibeacon plugin.
With this you can plot events when your car arrives, leaves has left , motor is on/off.
Sun Jul 16, 2017 10:30 pm
posted v 4-16-22
fixed:
adding 2 device/ states in a row did not work .. was a basic python error
(a=b, change b then a changes too)
Mon Oct 23, 2017 10:38 pm
posted v 4.16.25 http://forums.indigodomo.com/viewtopic.php?f=165&t=15884&p=113648#p113648
fixed:
== added the 3."/" in http:///filename in the log file output when you save the plot device.. Indigo 7.1 wants the 3. "/" in the URL
== fixed an issue: if you define a device data source , click save then not click on new device a variable did not get properly incremented (it comes from the fact that indigo does not execute filter methods in a predictable way. you need to click on a button to make that happen) . Now you have to click on the select field in order to continue. = the error should not happen anymore
improved:
== added "where state is not NULL" to the sql select statement to import data. that makes it a factor of 2 faster - in my case. Especially for devices that have a lot of states and if you use the indigo 7 improved sql logger way of storing changes.
== some better sorting in a menu when you select devices
Tue Jan 09, 2018 12:33 pm
posted v 4.16.28 on GitHub @ https://www.indigodomo.com/pluginstore/71/
mostly bug fixes for external ";" delimited data, ie if you want to plot data that is not in indigo.
ps.
Thanks to Adam for helping to debug this
Tue Feb 13, 2018 4:39 pm
posted v 4.16.29 @https://www.indigodomo.com/pluginstore/71/
en raison de la demande populaire:
added OUI / NON to be recognized as 1/0 (also oUi/nOn Oui/Non, .. etc)
Tue Feb 13, 2018 8:45 pm
posted v 4.16.30 @https://www.indigodomo.com/pluginstore/71/
To make it more complex, added german, spanish, hungarian*) ..yes / no open / close to recognized as 1/0
val is upper() case
                if (  val== u"TRUE"            or
                      val== u"T"               or
                      val== u"ON"              or
                      val== u"HOME"            or
                      val== u"YES"             or
                      val== u"SI"              or
                      val== u"JA"              or
                      val== u"IGEN"            or
                      val== u"OUI"             or
                      val== u"UP"              or
                      val== u"OPEN"            or
                      val== u"CLEAR"
                                          ):  return 1.0
               elif ( val== u"FALSE"         or
                       val== u"F"               or
                       val== u"AWAY"            or
                       val== u"OFF"             or
                       val== u"NO"              or
                       val== u"NEIN"            or
                       val== u"NEM"             or
                       val== u"NON"             or
                       val== u"DOWN"            or
                       val== u"CLOSED"         or
                       val== u"FAULTED"         or
                       val== u"FAULT"           or
                       val== u"EXPIRED"
                                           ): return 0.0
for our large Hungarian user group
Fri Feb 16, 2018 12:40 pm
DomoPat offline
Merci beaucoup !
Fri Feb 16, 2018 12:50 pm
vous êtes les bienvenus
Sat Feb 17, 2018 6:56 am
posted v 4.17.30 at https://www.indigodomo.com/pluginstore/71/
added event count type measurement -- only for matplot , not for gnu plot.
its a quick add-on, not well tested, but seems to work
Sun Feb 18, 2018 4:11 am
DomoPat offline
It works, but the graphs are difficult to update with version 4.17.30: when you do changes to the parameters, they are not reflected when you push the 'update' button, and even if you wait the changes are not taken into account. Sometimes they are, and most of the times they are not, I could not find what makes it happen...
Mon Feb 19, 2018 11:11 am
in device edit?
did you confirm changes? after that click update then wait 5 secs then press show
you can check if it runs matplot updates in the matplot directory log file ~/indigo/indigoplotd/matplot/.xx.log
down recall the exit names of the directory
Ps can we move this to the discussion thread ?
Mon Jul 23, 2018 11:16 am
posted new release: 4.18.47
fixed SQL import bugs
see plugin store and GitHub.com/kw123
Wed Nov 07, 2018 9:59 pm
released 7.18.54
- added option to track cpu usage of methods and functions This is beneficial in case plugin hangs (ie menu/ config does not open)
ps from now on all MY updated plugins will required Indigo 7.x.. it gets to difficult to maintain work arounds for options that do not work under 6.x
