a little python learning
Tue Sep 19, 2023 4:40 pm
def xxx(data):
   ## has a thread method  with a queue  that gets data that does
   time.sleep(1)
   print "{}".format(data)
data={"abc":"123"}
xxx(data)
data["def"] = "fgh"
will print: {"abc":"123", "def":"fgh"}
xxx gets a pointer to data, then the main program overwrites data, since xxx has a delay of 1 sec xxx will print the additional item "def"
:o
Wed Sep 20, 2023 10:11 am
ryanbuckner offline
Re: a little python learning
/usr/local/bin/python3.10 /Users/ryanbuckner/Library/Application Support/JetBrains/PyCharmCE2023.1/scratches/scratch_3.py
{'abc': '123'}
Process finished with exit code 0
Fri Sep 22, 2023 4:03 am
If it is a linear execution it works fine . Ie when xxx is finished before the main program resumes
But when xxx has an internal thread that runs independent of the main pgm and has a delay then it happens
In my real application xxx is feeding a queue that a thread reads very 0.5 secs and then sends an http message with the dict. There the additional item appeared as the main pgm adds an item to the dict immediately and writes it to a file for further local processing.
The underlying issue is that xxx gets a pointer to the dict not a copy.
So I am now always using xxx( copy.deepcopy(thedict) )
Fri Sep 22, 2023 10:51 am
Python is a pass-by-reference language (as opposed to pass by value). Passing an object around across threads can be tricky in any language and is what you noticed.
Technically, it's pass references to objects by value, but pass by reference is the closer model.
