HELP: mac looses system settings window
Fri Jul 14, 2023 7:05 am
after 1-2 days after re-starting my mac mini m1 2020, 16GB, ventura 13.4.1 I loose the system settings window.
Starting system setting shows it is active but does not display any window. After I restarting the mac everything is back to normal
I tried apple help, but that was useless (check for viruses and reinstall ) - which I did, no change.
It does not happen immediately after restart, but somewhere within 48 hours.
Only indigo runs on the mac (with many plugins.).
any suggestions?
Fri Jul 14, 2023 10:47 am
Re: HELP: mac looses system settings window
Monitor attached or not?
Sat Jul 15, 2023 2:59 pm
No Monitor. Only a dongle that simulates a monitor
Sat Jul 15, 2023 3:12 pm
And you're using screen sharing to access the Mac? Try changing the screen resolution next time it happens. I think the Window Manager is getting confused about the size of the screen and it's putting that window outside the visible screen.
Sun Jul 16, 2023 3:32 am
I have attached a physical monitor. And will check if thy changes any thing
Changing screen res does not work when system settings does not open
Sun Jul 16, 2023 9:50 am
ryanbuckner offline
It seems like this is a reported problem with Ventura and the people that resolved the issue did a factory reset back to an older MacOS
Mon Jul 17, 2023 3:10 am
I can confirm that using a physical monitor does not solve the problem.
The systems setting is broken again after 2 days
I guess
either:
- full backup (twice) .. full factory reset to 2020 (when I bought the mini-m1) .. upgrade to current os ... reinstall backup.. that is likely a better part of a day.
or:
- wait for the next MAC OS to fix it, and restart mac in the mean time if I need to access systems settings
Mon Jul 17, 2023 10:24 am
rehafer offline
For what it’s worth, I haven’t seen that problem while using VNC.
Users browsing this forum: No registered users and 17 guests
