how to use iPhone to share internet on my lan?
Sat Aug 20, 2022 3:50 pm
my modem went bust, have to wait until Monday to get a replacement.
Here the setup i like to try
- connect iPhone to mac, with usb cable
- on mac use usb for internet , works
- also connect ethernet to mac, delete the router info on the ethernet connection
==> then i can browse the internet and connect to other devices on LAN with THAT mac
What I can not do is: connect to internet on other LAN devices.
I can connect to the MAC from other devices, but routing to the internet does not work..
I tried the MAC as roter and the IP number of the iPhone, both do not work
Any idea, hint I could try?
Sat Aug 20, 2022 4:30 pm
Re: how to use iPhone to share internet on my lan?
Your Mac IP as router/gateway on your other devices is the correct networking concept.
Possibly same for DNS on your other devices if they’re currently pointing at your dead router; if they’re pointing publicly then not necessary.
I don’t know the Mac side of it, whether you need to allow sharing or suchlike.
Sat Aug 20, 2022 7:15 pm
System Preferences --> Sharing --> Internet Sharing
This doesn't work?
Sat Aug 20, 2022 11:23 pm
No
I need to set the router info on the other devices.
