indigo utilities download
Thu Oct 08, 2015 2:00 pm
version1.18.14 now on GitHub.com/kw123 and indigo store
This utility allows to:
1. print all states of all devices and variables into the log file in a nice format with current values. This is useful to get a quick overview of your setup
2. print device.Name and device.ID (and variables) to the log file. ==> if you have the device.ID but not the device.name
3. print # of records stored for each device and variable. Useful to find "offenders" i.e. devices that create a lot of entries and might explode your database
4. query device/ states from sqlite/postgres and print result to file or indigo logfile and indigo variables (the first record of the selection is copied to an indigo variable) - can also be done from an ACTION. Can be used to understand patterns of up/donw states and also to e.g. get the seconds last entry, i.e. what was it before the current entry though an easy python call
5. make a backup of indigo_history_sqlite. It can be called from the MENU or through an ACTION. After the copy is finished a test query is done.
--- If ok: rename backup db to indigo_history-1.sqlite and the last one to -2.sqlite
--- if not ok you get a message in the log file
--- anyone that had a bad SQLite DB will appreciate this function
--- it takes ~ 10 seconds for a 6.5 Gbyte database on a mac pro 3,1 (2008)
==> this is useful to (a) make a consistent backup at lets say 2 am for the last 2 days and (b) make sure it is not corrupt, or if it is you will get a message in your log file (this should be expanded to a email). You can also start the backup also from an action group or schedule (select "utilities Action" / "create and test backup of ..")
6. try to fix a broken indigo_history.sqlite :
--- make a copy, create a dump file,sort records to date-stamp, remove duplicates, reimport the dump file into new db and run a test query against it. This has been tested with 2 separate incidences with different issues.
--- it takes ~ 1hour minutes for a 8 Gbyte database on a mac-mini2014 16GByte Ram, 2TB fusion i7 )
--- at the end of the process you need to shut down the indigo server, rename the existing sqlite database and rename the just created database to indigo_history.sqlite, then restart the server and in many cases you will have a working data base again. You will lose ~ 30 minutes of data from the time the process started, until the new database is installed
7. print all wave devices with their neighbors. Useful if you want to debug your z-wave system and create .dot file for graphing zwave connections and if graphviz is installed it will also create a .zsv file ( ==> contributed by Frank Nicholas, see discussion @ http://forums.indigodomo.com/viewtopic.php?f=84&t=15251&p=108467&hilit=frank#p108467)
9. print Trigger info. lists available info about triggers, name,id, what triggered, and trigger parameters, no info is available on conditions, and actions
not yet implemented: prune/ compress the data base selectively i.e. records that are in the db twice and or prune all variable entries older than date xx. this will reduce your database size by ~ 20-50% depending on your sensors and settings.
10. trigger event when backup failed This is useful in case you have a corrupt DB you can set a trigger that will notify you
More detailed logging can be found in /Users/YourID/documents/indigoUtilities/backup.log
11. ping device you can enter deny ip number of dns name for a device to be pinged, result is shown in the log file
12.print Plugin names & IDs including daughter processes and consumed CPU time to log file. This is useful if you have many plugin running and would like to know which one is which as the all have the same name. The info is composed from "ps -ef" output in a terminal session.
13.print versions # of all installed active plugin and version available on the indigo store. this is throttled to 1 query /1.5sec and can only be run once a day.
14.[b]delete duplicate records in sql data base
This option will go through your indigo SQL database and remove records with the same time stamp- keep only last one. there are several modes:
== test- will create the SQL statements in a file in the indigo utilities directory,
== execute - will execute these sql statements and and print progress in logfile
== execute quiet - will execute the SQL statement , but will not show progress in the log file
+++ you can do this through the menu or through an action (execute and execute quite)
+++ this can take a long time depending on the size of your database.
++ if you use SQLITE, please stop sqllogger before executing. when finished reenable sqllogger. POSTERS seems to be better for multi user / access environments.
For sqlite to actually shrink the database open a terminal and executed: :
sqlite3 '/Library/Application Support/Perceptive Automation/Indigo 6/Logs/indigo_history.sqlite' .dump > dump  ; sqlite3 smaller < dump  .dump > dump  ; sqlite3 smaller < dump
then rename the old to keep a backup copy:
mv '/Library/Application Support/Perceptive Automation/Indigo 6/Logs/indigo_history.sqlite'  '/Library/Application Support/Perceptive Automation/Indigo 6/Logs/indigo_history.sqlite.copy'
Then copy the result
cp smaller '/Library/Application Support/Perceptive Automation/Indigo 6/Logs/indigo_history.sqlite'
You now can delete the files : smaller and dump.
ALL THIS HAS TO BE DONE WHILE SQL-LOGGER IS OFF IN INDIGO when you use SQLITE.
14.make a backup of important indigo files i.e. config database and preferences This option can be invoked through a menu, action or python script. I am using it to make a a copy of these directories every 2 hours . This will make sure that you always have a valid backup of you r INDIGO configs (devices, variables, actions, plugin configs etc). -- I added this after I lost almost everything as my backup did not work properly.
This took
- 2 hours for the deletes
-35 minutes for a database dump and recreate of new db
starting with a 50Gbyte sqlite db ending with a 20Gbyte db
on a mac mini 2014 i7 16GB with a 2 TB fusion drive
this will retire 2 other plugins, their functionality is included in this one.
- print SQL data in log file
- Print all States of all Variables and Devices to log file
the main menu
Screen Shot 2015-11-09 at 11.52.10 AM.png (154.5 KiB) Viewed 15126 times
select device states etc to be retrieved from the sql db
Screen Shot 2015-10-08 at 4.19.42 PM.png (82.43 KiB) Viewed 15273 times
output into the indigo variables
Screen Shot 2015-10-08 at 4.19.58 PM.png (13.59 KiB) Viewed 15273 times
output of sql very to log file
Screen Shot 2015-10-08 at 4.20.52 PM.png (18.59 KiB) Viewed 15273 times
example output of #1 print devices/states ..
                 ============== Print variables and devices to logfile =============
  Variable ID                       -----------------------------variables:  Value
  1235558255                                                           abc:  0
  200232878                                                  alarmVariable:  false
  657358351                                                      alarm_any:  1
  52939690                                                   alarm_BackW_1:  0
  1948752398                                         alarm_BackW_1_changed:  0
  1279900999                                                 alarm_BackW_2:  0
  827282794                                          alarm_BackW_2_changed:  0
  1140522547                       alarm_control_arduino_reboot_email_send:  0
  Device ID                         ---------------------------device Name:  State(Value), State(Value), ...
  145294727                                                  Alarm-arduino:  MACNumber("DE:AD:BE:EF:FE:EE"), WiFi(""), deviceInfo(""), hardwareVendor(""), ipNumber("192.168.1.152"),
        :  nickName("Alarm-arduino"), noOfChanges("661"), status("up"), statusDisplay("up         2015-01-1"), timeOfLastChange("2015-01-13 04:42:32"),
        :  usePing(""),
  1759240170                                                  apple-Leo-xx:  MACNumber("7C:6D:62:8F:A3:DE"), WiFi(""), deviceInfo("leo-wachs"), hardwareVendor("Apple"), ipNumber("192.168.1.240"),
        :  nickName("apple-Leo-xx"), noOfChanges("7"), status("expired"), statusDisplay("expired 2015-01-01 0"), timeOfLastChange("2015-01-01 00:19:57"),
        :  usePing(""),
  857475942                                                        appleTV:  MACNumber("58:55:CA:11:46:E9"), WiFi(""), deviceInfo(""), hardwareVendor("Apple"), ipNumber("192.168.1.212"),
        :  nickName("appleTV"), noOfChanges("829"), status("expired"), statusDisplay("expired 2014-10-20 1"), timeOfLastChange("2014-10-20 19:38:52"),
        :  usePing(""),
  767493990                                                     AsusRouter:  MACNumber("D8:50:E6:CF:B4:E0"), WiFi(""), deviceInfo("router.asus.com"), hardwareVendor(""), ipNumber("192.168.1.6"),
        :  nickName("AsusRouter"), noOfChanges("1121"), status("up"), statusDisplay("up         2015-01-1"), timeOfLastChange("2015-01-13 04:43:41"),
        :  usePing(""),
  273552650                                              backWindowSensor1:  onOffState("False"),
  1043783476                                             backWindowSensor2:  onOffState("False"),
  1452111289                                                        bigMac:  MACNumber("00:1F:5B:30:E9:20"), WiFi(""), deviceInfo("dad"), hardwareVendor("Apple"), ipNumber("192.168.1.52"),
        :  nickName("bigMac"), noOfChanges("101"), status("expired"), statusDisplay("expired 2014-11-25 2"), timeOfLastChange("2014-11-25 23:55:25"),
        :  usePing(""),
  82928661                                                           Cam-1:  MACNumber("F0:7D:68:06:F6:87"), WiFi("2GHz"), deviceInfo(""), hardwareVendor("D-Link"), ipNumber("192.168.1.71"),
        :  nickName("Cam-1"), noOfChanges("520"), status("up"), statusDisplay("up         2015-01-1"), timeOfLastChange("2015-01-17 14:55:29"),
        :  usePing("Sig[dBm]:-44,ave:-46"),
  1009180251                                                         Cam-2:  MACNumber("00:22:B0:E5:D4:C8"), WiFi(""), deviceInfo(""), hardwareVendor("D-Link"), ipNumber("192.168.1.72"),
        :  nickName("Cam-2"), noOfChanges("388"), status("up"), statusDisplay("up         2015-01-1"), timeOfLastChange("2015-01-13 04:42:32"),
        :  usePing(""),
  107339729                                                          Cam-4:  MACNumber("F0:7D:68:08:5F:D0"), WiFi("2GHz"), deviceInfo(""), hardwareVendor("D-Link"), ipNumber("192.168.1.74"),
example python action code:
plug = indigo.server.getPlugin("com.karlwachs.utilities")
if not plug.isEnabled(): return
## print variable
plug.executeAction("printSQLaction" , props ={
      "printFile":       ""            ##/users/karlwachs/documents/sql"      ## eeither "" -> to logfile or  print ot file --> /users/yourid/documents/filename
    , "header":       "yes"           ## either "yes" or "no"
    , "separator":       ";"           ## either "" or  ";" or "\t" for tab or "tab"
    , "devOrVar":       "var"         ## dev or var
    , "variable":       "EnergyToday2"    ##variable  name or variable-id
    , "id":             "0"          ## first id to print
    , "numberOfRecords":"2"
## print device/states
      "printFile":       "sqlOutput"      ## either "" -> to logfile or  print ot file --> /users/yourid/documents/   >>filename<<<
    , "separator":       ""
    , "devOrVar":       "dev"         ## dev or var
    , "device":       "volvo"       ## device name or device-id
    , "id":             ""             ## first id to print, if "": print the last numberOfRecords records, if =0: print first numberOfRecords
    , "numberOfRecords":"10"          ## # of records to be printed
    , "state0":       "Signal"       ## can be name of state or *
    , "state0Condition":"eq"          ## can be "eq" or  "ne" or "any" or ""
    , "state0Value"      :"-55"          ## can be any string but not ""
    , "state1":        "Temperature"    ## name of 2. state or ""
    , "state2":        "Presence"       ## ...
    , "state3":        "MotherAssociated"
    , "state4":        ""
## delete devices states before #of days with:
plug.executeAction("pruneDevsandVarsAction" , props ={
      "devOrVar":              "dev"             # dev or var
    , "device":                "1312758245"      # dev indigo id or name
    , "deleteBeforeThisDays":  "55"              # # of days to be kept  == keeps 55 days
    , "device":                "Karl FAN"        # dev indigo id or name
    , "deleteBeforeThisDays":  "2"               # # of days to be kept  == keeps 2 days
      "devOrVar":              "var"             # dev or var
    , "variable":              "EnergyDay_7"     #var indigo id or name
##squeeze duplicate records with
plug.executeAction("actionDatabaseSqueeze" , props ={ })
##squeeze duplicate records (quietly)  with
plug.executeAction("actionDatabaseSqueezeQuiet" , props ={ })
## create a postgres dump /users/documents/yourhomeDirectory/indigouUtilities/postgresBackup.dump
plug.executeAction("executeBACKUPpostgresAction" , props ={ })
## make a backup of all important indigo files copied to  /users/documents/yourhomeDirectory/indigouUtilities/....
plug.executeAction("IndigoBackup" , props ={ })
for #2 example output for # of records in sql data base:
 utilities                       # of records           devId /  Name             for DEVICES
  utilities                                     0     36863338 / Z-Wave Repeater living room
  utilities                                     0     56627415 / 014-Clamp 3
  utilities                                     0     60819802 / example
  utilities                                     0    146980745 / scatter1
  utilities                                     0    193085791 / yyy
  utilities                                     0    309074716 / wifiSignalTest
  utilities                                     0    309579619 / EnergyUsage ü
  utilities                                     0    310156472 / 006 - Clamp 3
  utilities                                     0    368213950 / temp
  utilities                                     0    396470314 / remote_8_button
  utilities                                     0    397373477 / Z-Wave Repeater Kons
  utilities                                595278    325253257 / konstantin
  utilities                                600520    533133990 / master Bed
  utilities                                615598     46489666 / TempOutside
  utilities                                636725    374645596 / MeterTotalLeftBox
  utilities                                643801   1130448881 / Meter-RightBoxClamp1
  utilities                                643889    720397021 / Meter-RightBoxClamp2
  utilities                                712322    776367642 / MeterTotalRightBox
  utilities                                748960   1954322276 / blueJacket Leo II
  utilities                                878928   1431469100 / kitchen
  utilities                               5748292    375541516 / wind sensor
  utilities                       # of records           varId /  Name             for VARIABLES
  utilities                                     8   1079519644 / huzzahh
  utilities                                     8   1449882585 / alarm_control_script_new_data
  utilities                                    10    469180806 / huzzah
  utilities                                    12    258515116 / ESP5
  utilities                                 82019    152675605 / alarm_control_script_data_count
  utilities                                152125   1861388192 / alarm_motion_detection
  utilities                                152643    970221212 / alarm_motion_detection_changed
  utilities                                174077    687297433 / averageWiFiSignal-5GHz
  utilities                                248202   1717323797 / averageWiFiSignal-2GHz
  utilities                                262512    535852682 / Irrigationcaddy_action
  utilities                                601942   1929581894 / Irrigationcaddy_Zone_SecLeft
  utilities                                601944   1749698837 / Irrigationcaddy_Prog_Seconds_Left
example to z-wave info print out
               ============== Print zwave info of devices to logfile =============
  Device ID                         ---------------------device Name -addr:  neighbors
  1332829462                                        ThermostatGameRoom-  2:  1, 3, 4, 5, 7, 9, 12, 13, 15, 16, 17, 20
  1623295497                                    ThermostatExerciseRoom-  3:  1, 2, 6, 7, 12, 13, 16, 17, 20
  55209657                                        ThermostatDownstairs-  4:  1, 2, 5, 14, 15, 16, 17, 19, 20, 22, 23, 24, 25, 27, 28, 29
  768183209                                         ThermostatUpstairs-  5:  1, 4, 15, 17, 19, 22, 23, 24, 25, 26, 27, 28, 29
  776367642                                         MeterTotalRightBox-  6:  1, 3, 7, 12, 13, 16, 17, 20
  374645596                                          MeterTotalLeftBox-  7:  1, 2, 3, 4, 5, 6, 9, 10, 11, 12, 13, 14, 15, 16, 17, 19, 20, 29
  1223893079                                                   Key Fob-  8:  - none -
  1215370021                               outsideMosquito switch tree-  9:  1, 2, 12, 13, 20
  282154644                              downstairsHallwayoutletMiddle- 11:  1, 2, 3, 4, 5, 10, 15
  115635811                                        Game Room TV switch- 12:  1, 2, 3, 6, 7, 9, 10, 11, 13, 14, 15, 16, 17
  662003093                                   Excercise room TV switch- 13:  1, 2, 3, 4, 6, 7, 9, 12, 15, 16, 17, 20, 29
  1766870014                                          poolEnergy total- 14:  1, 4, 15, 17
  113937113                                           attic squirrel 2- 15:  1, 2, 4, 5, 7, 13, 14, 16, 17, 19, 20, 22, 23, 26, 27, 28, 29
  1275294478                         Z-Wave Repeater garage work bench- 16:  1, 2, 3, 4, 6, 7, 10, 12, 13, 14, 15, 17, 20, 28, 29
  1769189912                                 Z-Wave Repeater game room- 17:  1, 2, 3, 4, 5, 6, 7, 12, 13, 14, 15, 16, 19, 20, 27, 29
  397373477                                       Z-Wave Repeater Kons- 19:  1, 4, 5, 15, 17, 22, 24, 25, 26, 28, 29
  524220718                              Z-Wave Repeater exercise room- 20:  1, 2, 3, 6, 7, 9, 10, 12, 13, 15, 16, 17
  36863338                                 Z-Wave Repeater living room- 21:  1, 4, 5, 11, 14, 15, 17, 19, 20, 22, 23, 24
  652241576                                       outsideBalkonyLights- 22:  1, 4, 5, 15, 19, 23, 24, 25, 26, 27
  1288667224                             downstrairsHallwayOutletFront- 23:  1, 4, 5, 11, 14, 15, 20, 21, 22
  24596767                                                 studyOutlet- 24:  1, 4, 5, 11, 15, 19, 21, 23
  1469978670                                  livingRoom camera switch- 25:  1, 4, 5, 11, 15, 19, 20, 22, 24, 26
  1875535582                                  frontBalkonyCameraSwitch- 26:  1, 4, 11, 17, 19, 22, 23, 24, 25, 27
  1392012060                            outsideMosquito switch Balkony- 27:  1, 4, 5, 17, 19, 22, 23, 25, 26
  719674580                                   switch for insteon modem- 28:  1, 4, 5, 15, 19, 24, 27, 29
  1017625793                                            coffeeMachineü- 29:  1, 4, 5, 7, 15, 16, 23, 24, 28
example of output for print trigger info
                 ============== Print for each Trigger  devices/variables that trigger them      =============
  Trigger Name                    Trig.ID      Trig.SourceType Dev/Var/Plugin-ID           Source-D/V/P-Name         Other info
  Alarm_excercise                 121520365    device          1413551529                  exerciseWindow            state: onOffState-- changeType: Changes-- compareTo:
  DoorsUnlock with key-fob        141240424    plugin          tomation.indigoplugin.zwave zwaveCommand              z-wave "Key Fob" button 2 pressed received
  Garage_Door                     820257178    device          396470314                   remote_8_button           cmd: On-- button/Group: 5
  IP number changed               395786349    plugin          com.karlwachs.fingscan      IPNumberChanged
  PoolTargetTempChanged           1298946066   variable        1183316306                  poolTargetTemp            chgType: Changes-- compareTo:
  alarm off  home Key fob         1011481739   plugin          tomation.indigoplugin.zwave zwaveCommand              z-wave "Key Fob" button 4 pressed received
  alarm reset                     25391179     variable        15846349                    alarm_reset               chgType: BecomesTrue-- compareTo:
  alleyWayDoorOpenClose           1829600407   device          1352702133                  alleyWayOpen-close        cmd: AnyCommand-- button/Group: 1
  alleywayDoorChanged2            310854818    device          542224739                   outsideAlleyWayDoor       state: binaryInputsAll-- changeType: Changes-- compareTo:
  backW1                          607786589    device          273552650                   backWindowSensor1         state: onOffState-- changeType: BecomesTrue-- compareTo:
  bad wifi                        138456350    plugin          com.karlwachs.fingscan      badWiFi
  brightness                      503061623    variable        136862429                   setbrightness100          chgType: BecomesEqual-- compareTo: 10000
  cat fight terminator            91094848     plugin          tomation.indigoplugin.zwave zwaveCommand              z-wave "Key Fob" button 1 pressed received
  eTrack - ThermostatUpstairs He  27200589     device          768183209                   ThermostatUpstairs        state: hvacHeaterIsOn-- changeType: Changes-- compareTo:
  email_away                      304840394    emailIncoming   MatchEmailFields            from:                     Subj: away
  enoughRain                      220969120    device          57636140                    RainSensor                state: raintotal-- changeType: Changes-- compareTo:
  enoughRainNOT                   322193216    device          57636140                    RainSensor                state: rainrate-- changeType: Changes-- compareTo:
  excWoff                         1149326979   device          1413551529                  exerciseWindow            state: onOffState-- changeType: BecomesFalse-- compareTo:
  excWon                          1918014925   device          1413551529                  exerciseWindow            state: onOffState-- changeType: BecomesTrue-- compareTo:
  gallonCounter                   1432400102   device          273552650                   backWindowSensor1         state: onOffState-- changeType: BecomesTrue-- compareTo:
  garageDoorChanged1              662065461    device          849429887                   outsideGarageDoorOpen     state: onOffState-- changeType: Changes-- compareTo:
  garageDoorChanged2              471251233    device          1982763902                  outsideGarageDoorOpener   state: binaryInputsAll-- changeType: Changes-- compareTo:
  home away fingscan all          172238082    plugin          com.karlwachs.fingscan      EVENT-1-allAway
  home away fingscan one          674235408    plugin          com.karlwachs.fingscan      EVENT-1-oneAway
  home iphone                     1074720508   plugin          com.karlwachs.fingscan      EVENT-1-oneHome
  home open fingscan all          10719099     plugin          com.karlwachs.fingscan      EVENT-1-allHome
  leo off                         1739688393   device          503851504                   Leo6Switch                cmd: Off-- button/Group: 1
  light living room ceiling       685848916    variable        136862429                   setbrightness100          chgType: BecomesEqual-- compareTo: 100000
  power failure email             762821978    interface       All
  smo
how to setup trigger for failed sql backup:
Screen Shot 2015-11-16 at 4.12.47 PM.png (17.2 KiB) Viewed 15095 times
ping a device:
Screen Shot 2016-01-18 at 12.33.19 PM.png (53.57 KiB) Viewed 14657 times
print plugin names and ids (and daughter processes to log file:
  utilities                       ---------------------pluginName------------         ID        CPU
  utilities                       .Action Collection                                1624    0:36.47
  utilities                       Group-Trigger                                     1625    0:34.63
  utilities                       INDIGOplotD                                       1626    2:36.35
  utilities                        |- indigoMPplot.py                               1640    9:27.17
  utilities                       miniPLOT                                          1627    0:35.20
  utilities                       Plugin Developer Documenter-3                     1629    0:35.76
  utilities                       SQL Logger                                        1630    0:37.31
  utilities                       Virtual Devices                                   1631    0:36.03
  utilities                       piBeacon                                          5395    0:00.78
  utilities                       utilities                                         5558    0:00.24
old versions of plugins:
https://www.dropbox.com/s/zvqkcunjg2z5rbn/utilities-v-1.12.5.zip?dl=1
https://www.dropbox.com/s/zxf6aizlir6sg3z/utilities-v-1.12.3.zip?dl=1
https://www.dropbox.com/s/ly4xscieniw8a4b/utilities-v-1-12-1.zip?dl=1
https://www.dropbox.com/s/v94kpkythhu5x0r/utilities-v-1-11-3.zip?dl=1
https://www.dropbox.com/s/0w8aqqje0i811ok/utilities-v-1-11-2.zip?dl=0
https://www.dropbox.com/s/xermrjdxa1tgvdb/utilities-v-1-11-1.zip?dl=1
https://www.dropbox.com/s/gzsirpvo6qhe8y6/utilities-v-1-10-1.zip?dl=1
https://www.dropbox.com/s/1ajiug7x0gt0sge/utilities-v-1-9-5.zip?dl=1
https://www.dropbox.com/s/xz9umt0bmvdo1de/utilities-v-1-9-4.zip?dl=1
https://www.dropbox.com/s/9rb8md9rhiid9h5/utilities-v-1-8-1.zip?dl=1
https://www.dropbox.com/s/01ym7m2br9o7a4n/utilities-v-1-7-4.zip?dl=1
https://www.dropbox.com/s/4e1cwma20h4b6y9/utilities-v-1-7-3.zip?dl=1
https://www.dropbox.com/s/fkd15iujv2j0ffh/utilities.indigoPlugin-v-1-6-1.zip?dl=1
Screen Shot 2015-10-08 at 4.18.49 PM.png (22.54 KiB) Viewed 15273 times
Screen Shot 2015-10-08 at 4.18.27 PM.png (93.08 KiB) Viewed 15273 times
Tue Oct 10, 2017 3:56 pm
Re: indigo utilities download
posted v 1.12.5
Added memory consumption of plugins in menu "print plugin IDs and names"
    ID    CPU-total  Mem-% -Virt -Real  version       pluginName ------------------------
  14666      0:49.21    0.1  2529    26  2.0.4        .Action Collection
  14667      0:48.34    0.1  2525    25  2.0.10       .INSTEON Commands
  14668      3:21.68    0.1  2544    35  2.0.97       .Z-Wave
  14669      2:24.49    0.1  2526    24  1.0.0        alarmtoindigo
  14670     24:50.12    0.1  2530    32  7.9.8        arduino
  14672      0:48.34    0.1  2524    24  2.0          Global Property Manager
  14673     32:02.71    0.2  2574    85  4.16.24      INDIGOplotD
  95551      0:00.00    0.2  2574    85                |- (sh)
  95552      0:00.00    0.2  2574    85                |- (sh)
  95554      0:00.00    0.2  2574    85                |- (sh)
  95558      0:00.00    0.2  2574    85                |- (sh)
  95564      0:00.00    0.2  2574    85                |- (sh)
  95566      0:00.00    0.2  2574    85                |- (sh)
  95567      0:00.00    0.2  2574    85                |- (sh)
  14674      1:09.39    0.1  2527    31  7.5.2        minMax
  14675      8:19.56    0.1  2528    32  7.4.5        mother
  94250      0:00.58    0.1  2528    32                |- /System/Library/Frameworks/Python.framework/Versions/2.7/Resources/Python.app/Contents/....
  14677      0:43.99    0.1  2528    28  2.0.1        NOAA Weather
  14678      0:53.69    0.1  2528    28  0.0.7        Online Sensor
  14682      1:07.63    0.1  2526    25  0.0.1        sprinkler
  14683     43:47.24    0.1  2547    47  2.0.7        SQL Logger
  14684      0:46.20    0.1  2526    27  2.21         survey2
  14685      0:50.22    0.1  2525    25  2.0.2        Timers and Pesters
  14687     11:15.91    0.8  2753   313  1.12.5       utilities
  14688      0:43.03    0.1  2528    25  2.0.4        Virtual Devices
  42128      1:24.47    0.1  2524    26  2.1.0        RFXCOM
  83254     12:31.00    0.2  2560    66  7.68.155     piBeacon
  87710      0:07.18    0.3  2609   111  1.1.17       NOAA Weather Plus
  93980      1:28.45    0.1  2576    42  7.6.52       uniFiAP
  94035      0:00.04    0.1  2576    42                |- /usr/bin/expect /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP.i
  94052      0:00.19    0.1  2576    42                |- /usr/bin/expect /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP.indigoPlugin..
  94069      0:00.04    0.1  2576    42                |- /usr/bin/expect /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP.indigoPlugin/Cont..
  94085      0:00.20    0.1  2576    42                |- /usr/bin/expect /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP.indigoPlugin/Conten..
  94097      0:00.04    0.1  2576    42                |- /usr/bin/expect /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP.i..
  94108      0:00.20    0.1  2576    42                |- /usr/bin/expect /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP.indig..
  94120      0:00.31    0.1  2576    42                |- /usr/bin/expect /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP.indigoPl..
  94132      0:00.18    0.1  2576    42                |- /usr/bin/expect /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP.indigoPl..
  94147      0:00.18    0.1  2576    42                |- /usr/bin/expect /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP.indigoPlugi..
  94168      0:02.01    0.1  2576    42                |- /usr/bin/expect /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP.indigoPlugi..
  95474      0:00.04    0.1  2576    42                |- /usr/bin/expect /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/uniFiAP.indigoPlug..in/Contents/Server Plugin/execLog.exp karlwachs 457654aA.unifi 192.168.1.1 @GW: /usr/bin/tail -f /var/log/auth.log
  94800      0:13.16    0.1  2534    45  7.22.11      fingscan
  95862      0:00.00    0.1  2534    45                |- (sh)
Wed Mar 30, 2022 1:07 am
Added features / changes in v2.19.32@ 2022-03-30
prep for indigo 2022 and os 12.3
Can run under MAC OS 12.3.. AFTER indigo 2022 is released
!!! do not upgrade to MAC OS12.3 (Monterey) yet !!!,
But this release should work fine with indigo 2021 and 2022 and older versions
I would appreciate if someone could test this with the current indigo releases ie 2021 and older.
It was tested under indigo 2022 Mac OS 12.3 and Indigo 2021 and MAC OS 12.2, but naturally not all functions.
The older versions of this plugin (< 2.19.32 will NOT run under MAC OS 12.3 (even with indigo 2022 )
Wed Mar 30, 2022 9:43 am
Korey offline
Thanks for the update Karl,
getting this error on Indigo 2021.2.0 / OSX 10.14.6 when selecting: print MAC cpu and fan temperatures to log
   utilities Error                 Error in plugin execution MenuAction:
  File "plugin.py", line 454, in printMACtemperatures
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc2 in position 5: ordinal not in range(128)
Korey
Wed Mar 30, 2022 4:03 pm
norcoscia offline
When I tried print MAC cpu and fan temperatures to log I don’t get the error Korey gets but I don’t see anything at all in the log when I run it. Let me know if you need any other info and thanks for the update…
Update - I was running that from a mac that was not the server, when I switched to the mac running my indigo server and tried to run it I got the error below, mac indigo server details on the other screenshot. Not sure how to fix it?
Oh yeah, Forgot to mention the plug-in did update and is running - tried a bunch of stuff and it worked but when I did the fan and temp thing I got the error below - gotta love apple :-)
Screen Shot Indigo server version.png (114.15 KiB) Viewed 5504 times
Screen Shot 2022-03-30 at 3.06.57 PM.png (166.85 KiB) Viewed 5504 times
_______
Norm
Fri Apr 01, 2022 5:31 am
for the unicode error I have a fix,
but: it seems that the temperature utility does not result in any useful info on an M1 mac
I am checking other solutions
Sat Apr 02, 2022 11:46 am
Added features / changes in v2.19.38 @ 2022-4-02
1. fixed unicode issue
2. added option to print powermetrics info
3. clean up menu list
Mon Jun 20, 2022 9:08 am
last bug fix for py2, next version will only run under py3
Added features / changes in v2.19.39 @ 2022-06-20
fixed @line 2209: 'lines = steps.strip("\n").split("\n")'
Mon Jun 20, 2022 11:38 am
Added features / changes in v2022.19.40 @ 2022-06-20
switched everything to py3
made backup work under py3.
now only py3 supported ie indigo 2022
Thu Mar 09, 2023 4:23 am
Added features / changes in v2022.20.40 @ 2023-03-09
added menu options to print info to log for selected device, trigger, schedule, actionGroup
in menu: print stuff to log..
