Issues connecting to new Plex Server
Posted: Mon Dec 21, 2020 9:11 am
The Plex Plugin stopped working some rime agar when I moved the Plex Library to its own iMac.
Now Christmas is upon us time to get back into Indigo and fix up all the things that have fallen over while I have been swamped for the last 12 months.
But unfortunately cannot get Indigo to connect to either the OLD Plex or the new Plex.
The Old one has almost nothing left on it. But is up and running.
In trying both Old and New - I have Copied and Pasted IP Addresses from Plex settings and username and password from my password vault and confirmed the username/password is correct.
But cannot get the Plex Plugin to connect at all
Anyone any idea why it is failing - or is a compatibility issue with Plex Version 1.21.1.3830
It would be nice to get this working again
- Code: Select all
2020-12-21 15:05:13.777 THREADDEBUG Plugin.concurrentCommandProcessingThread Command queue has 4 command(s) waiting
2020-12-21 15:05:13.862 ERROR Plugin.concurrentCommandProcessingThread Exception in background processing
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkRESTfulDevice.py", line 375, in concurrentCommandProcessingThread
self.handleUnmanagedCommandInQueue(deviceHTTPAddress, command)
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/plexMediaServerDevices.py", line 352, in handleUnmanagedCommandInQueue
self.retrieveSecurityToken()
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/plexMediaServerDevices.py", line 438, in retrieveSecurityToken
responseObj = requests.post(u'https://plex.tv/users/sign_in.xml', headers=plexHeaders, auth=(self.indigoDevice.pluginProps.get(u'plexUsername', u''), self.indigoDevice.pluginProps.get(u'plexPassword', u'')))
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/api.py", line 111, in post
return request('post', url, data=data, json=json, **kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/api.py", line 57, in request
return session.request(method=method, url=url, **kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/sessions.py", line 477, in request
resp = self.send(prep, **send_kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/sessions.py", line 587, in send
r = adapter.send(request, **kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/adapters.py", line 467, in send
raise ConnectionError(err, request=request)
ConnectionError: ('Connection aborted.', error(54, 'Connection reset by peer'))
2020-12-21 15:05:13.864 DEBUG Plugin.concurrentCommandProcessingThread Command thread ending processing
