Basic Questions
Sun Apr 15, 2018 10:48 pm
RogueProeliator offline
Re: Basic Questions
I did some checking this weekend just to be sure, and verified that there is no genre fields returned from the PMS when requesting the currently playing item... HOWEVER, it seems like you probably can pull this back via a (separate) request for the metadata of the item. I say probably because the example metadata query I have here is for video, but it lists the genre(s) for it. I'm assuming that would pull back music genres as well.
I'll do a little experimentation and see if it is something worth adding to the plugin directly or, if not, I may be able to add a helper or event or something that would allow you to pull it back via a script.
Adam
Mon Apr 16, 2018 1:15 am
Busta999 offline
Re: Basic Questions
I’ll start checking genres and rationalising them in anticipation ;-)
Thu Jul 05, 2018 10:50 pm
Re: Basic Questions
So this is a few months old, but genre information is now included as a state in the latest version. One note - on movies the genre is pulled directly/immediately. On TV shows and Music you will see it blank out and then update to the value (it requires a separate call to Plex).
Fri Jul 06, 2018 12:49 am
Busta999 offline
Re: Basic Questions
EXCELLENT!
Will give a go this weekend.
Mike
