Cannot update device state
Sat Oct 27, 2018 5:29 am
wormhole offline
Re: Cannot update device state
Any update? :)
Sun Oct 28, 2018 9:39 pm
RogueProeliator offline
Any update? :)
I haven't had time to fully test this release to my satisfaction, though there are no known issues in it...
If you feel like trying it out:
https://github.com/RogueProeliator/Indi ... tag/v2.3.0
Adam
Mon Oct 29, 2018 4:35 am
wormhole offline
sure, installed and immediately got this...
Started plugin "Plex Media Server Manager 2.3.0"
Error cannot update device state for key clientConnectionStatus to value stopped (invalid enumeration value)
Oct 29, 2018 at 6:34:23 AM
Error
Mon Oct 29, 2018 7:35 am
That value is definitely in that enumeration now... just double checked to be sure I hadn't forgotten to check something in to GitHub. It is in both the named and "slot" client device types. Would you mind turning the debug up to high, letting it hit that error, then pasting in the log? Looking for the XML returned that is throwing the error - I haven't noticed an error in my system but, as I mentioned, this isn't very tested as I don't seem to show that status (at least that I have noticed... this may be specific to the client/types that are you using). Maybe with your XML I can run it through the plugin hard-coded to see what is going on.
Adam
Wed Oct 31, 2018 4:00 pm
wormhole offline
here's after turning on debugging - how else can i help?
plexapp-android', 'local': '1', 'platformVersion': '8.0.0'}
Plex Media Server Manager Debug Identified as Slot 16
Plex Media Server Manager Debug Found 1 clients to update
Plex Media Server Manager Debug Found client device to update for machineID: 73d75b2654562c76-com-plexapp-android
Plex Media Server Manager Debug Found unknown client: 73d75b2654562c76-com-plexapp-android
Plex Media Server Manager Debug MediaContainer Media Information: {'videoFrameRate': '24p', 'videoCodec': 'h264', 'container': 'mkv', 'videoResolution': '720', 'height': '720', 'width': '1280', 'audioChannels': '6', 'duration': '2728393', 'videoProfile': 'high', 'aspectRatio': '1.78', 'bitrate': '5504', 'id': '2383118', 'audioCodec': 'ac3'}
Plex Media Server Manager Debug MediaContainer Player Information: {'profile': 'Roku-7.x', 'product': 'Plex for Roku', 'vendor': 'Roku', 'title': 'Roku 2 XS - 13A180167775', 'remotePublicAddress': '69.127.209.130', 'userID': '20154', 'platform': 'Roku', 'state': 'stopped', 'version': '5.3.10.5048-c61db7547-Plex', 'address': '69.127.209.130', 'device': 'Roku 2 XS', 'model': '3100X', 'machineIdentifier': '762876e964688406a4219af962d4c2e7', 'local': '0', 'platformVersion': '8.x'}
Wed Oct 31, 2018 10:15 pm
I just checked again, and that enum / state is there... could you edit the device and save it to see if it picks up some change on the XML?
Sun Nov 04, 2018 6:46 am
wormhole offline
Thanks. I removed all the clients as well as the server and re-added. No errors now although the device states are pretty slow to update. I'll keep you posted. If there is anything in particular i can do to further troubleshoot let me know. This plugin is particularly useful for me (so appreciated) because i have multiple scenes set for our theater based on this plugin (fade out lights when movie starts, bring up lights 50% when paused, etc). Thanks again.
Sun Nov 04, 2018 11:06 am
You probably checked, but the first thing to check is the polling interval on the Plex Server Device... During re-creation, it may have gone back to a default value higher than what you had previously set.
