Plex install problem: updateStatusPollerActionId and more
Posted: Sun Oct 08, 2017 9:27 am
I am trying to get the Plex plugin to work. Plex runs on the same Mac mini as Indigo. I have set up a server device but no clients yet. I'm using https, and I told the plugin that the Plex server is on localhost with the standard port number.
When I reload the plugin, I get the following error, no idea what this means. Did I configure something wrong?
- Code: Select all
Plex Media Server Manager Debug Setting address of 1550923470 to localhost:32400
Plex Media Server Manager Debug Entering deviceStopComm for PLEX Server @Indigo; ID=1550923470
Plex Media Server Manager Debug Returning default GUIConfigValue for plexMediaServer:deviceIsChildDevice
Plex Media Server Manager Debug Initiating shutdown of communications with PLEX Server @Indigo
Plex Media Server Manager Debug Shutdown of communications with PLEX Server @Indigo complete
Plex Media Server Manager Debug Exiting deviceStopComm for PLEX Server @Indigo
Plex Media Server Manager Debug Entering deviceStartComm for PLEX Server @Indigo; ID=1550923470
Plex Media Server Manager Debug Concurrent Processing Thread started for device 1550923470
Plex Media Server Manager Debug Returning default GUIConfigValue for plexMediaServer:emptyQueueReducedWaitCycles
Plex Media Server Manager Debug Returning default GUIConfigValue for plexMediaServer:databaseConnectionEnabled
Plex Media Server Manager Debug Database access enabled:
Plex Media Server Manager Debug Database access has been disabled, skipping connection
Plex Media Server Manager Debug Command queue has 1 command(s) waiting
Plex Media Server Manager Debug Create connection command de-queued
Plex Media Server Manager Debug Returning default GUIConfigValue for plexMediaServer:updateStatusPollerStartupDelay
Plex Media Server Manager Debug Command queue has 2 command(s) waiting
Plex Media Server Manager Debug Initiating sleep of 3.0 seconds from command.
Plex Media Server Manager Debug Exiting deviceStartComm for PLEX Server @Indigo
Plex Media Server Manager Debug Executing full status update request...
Plex Media Server Manager Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkRESTfulDevice.py", line 185, in concurrentCommandProcessingThread
self.hostPlugin.executeAction(None, indigoActionId=updateStatusPollerActionId, indigoDeviceId=self.indigoDevice.id, paramValues=None)
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkPlugin.py", line 1146, in executeAction
self.indigoActions[indigoActionId].generateActionCommands(self, self.managedDevices[indigoDeviceId], paramValues)
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkIndigoAction.py", line 154, in generateActionCommands
for i in range(0,executeTimes):
TypeError: range() integer end argument expected, got float.
Plex Media Server Manager Debug Command thread ending processing
