Plex install problem: updateStatusPollerActionId and more
Sun Oct 08, 2017 9:27 am
Stoutjesdijk offline
I am trying to get the Plex plugin to work. Plex runs on the same Mac mini as Indigo. I have set up a server device but no clients yet. I'm using https, and I told the plugin that the Plex server is on localhost with the standard port number.
When I reload the plugin, I get the following error, no idea what this means. Did I configure something wrong?
   Plex Media Server Manager Debug Setting address of 1550923470 to localhost:32400
   Plex Media Server Manager Debug Entering deviceStopComm for PLEX Server @Indigo; ID=1550923470
   Plex Media Server Manager Debug Returning default GUIConfigValue for plexMediaServer:deviceIsChildDevice
   Plex Media Server Manager Debug Initiating shutdown of communications with PLEX Server @Indigo
   Plex Media Server Manager Debug Shutdown of communications with PLEX Server @Indigo complete
   Plex Media Server Manager Debug Exiting deviceStopComm for PLEX Server @Indigo
   Plex Media Server Manager Debug Entering deviceStartComm for PLEX Server @Indigo; ID=1550923470
   Plex Media Server Manager Debug Concurrent Processing Thread started for device 1550923470
   Plex Media Server Manager Debug Returning default GUIConfigValue for plexMediaServer:emptyQueueReducedWaitCycles
   Plex Media Server Manager Debug Returning default GUIConfigValue for plexMediaServer:databaseConnectionEnabled
   Plex Media Server Manager Debug Database access enabled:
   Plex Media Server Manager Debug Database access has been disabled, skipping connection
   Plex Media Server Manager Debug Command queue has 1 command(s) waiting
   Plex Media Server Manager Debug Create connection command de-queued
   Plex Media Server Manager Debug Returning default GUIConfigValue for plexMediaServer:updateStatusPollerStartupDelay
   Plex Media Server Manager Debug Command queue has 2 command(s) waiting
   Plex Media Server Manager Debug Initiating sleep of 3.0 seconds from command.
   Plex Media Server Manager Debug Exiting deviceStartComm for PLEX Server @Indigo
   Plex Media Server Manager Debug Executing full status update request...
   Plex Media Server Manager Error Error in plugin execution:
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkRESTfulDevice.py", line 185, in concurrentCommandProcessingThread
    self.hostPlugin.executeAction(None, indigoActionId=updateStatusPollerActionId, indigoDeviceId=self.indigoDevice.id, paramValues=None)
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkPlugin.py", line 1146, in executeAction
    self.indigoActions[indigoActionId].generateActionCommands(self, self.managedDevices[indigoDeviceId], paramValues)
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkIndigoAction.py", line 154, in generateActionCommands
    for i in range(0,executeTimes):
TypeError: range() integer end argument expected, got float.
   Plex Media Server Manager Debug Command thread ending processing
Best regards,
Mark
Trying to tie it all together...
| Indigo | Plex | NAD M33 | Unifi | LG WebOS | Tado | Sonos | SolarEdge | HUE |
Mon Oct 09, 2017 10:31 pm
RogueProeliator offline
Re: Plex install problem: updateStatusPollerActionId and mor
Hi Mark... Is that with the debug set to full? If not, please turn it up and rerun.
Can you try it without the SSL just as a test? I don't BELIEVE that to be the issue, but let's just eliminate that right off the bat.
Adam
Sun Oct 29, 2017 4:58 am
Hi Adam,
Sorry it's been a while, very busy with the daytime job...
I noticed that there was an updated version of the PLEX server, and after installing, the error message had disappeared. :oops:
Mark
Best regards,
Mark
