Plex Server Version 1.1.0.2611 Breaks Plugin
Posted: Tue Aug 23, 2016 8:32 pm
Yesterday I downloaded Plex Server Version 1.1.0.2611 from Plex Pass. I noticed that I began getting errors triggering my Plex triggers when dimming my lights. I rolled it back to the July release and everything was ok. Here are some of the event logs below:
Plex Media Server Manager Error An error occurred executing the GET/PUT request (Device: 1620963269): ('Connection aborted.', error(61, 'Connection refused'))
Plex Media Server Manager Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkRESTfulDevice.py", line 248, in concurrentCommandProcessingThread
responseObj = requests.get(fullGetUrl, auth=authenticationParam, headers=customHeaders, verify=False)
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/requests/api.py", line 69, in get
return request('get', url, params=params, **kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/requests/api.py", line 50, in request
response = session.request(method=method, url=url, **kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/requests/sessions.py", line 469, in request
resp = self.send(prep, **send_kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/requests/sessions.py", line 577, in send
r = adapter.send(request, **kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/requests/adapters.py", line 413, in send
raise ConnectionError(err, request=request)
ConnectionError: ('Connection aborted.', error(61, 'Connection refused'))
On a side not after I rolled it back and everything we back to normal I also noticed this error any ideas why? It doesn't prevent anything from working just shows up now and then
Plex Media Server Manager Error Error executing effect for device id 1620963269
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkDeviceResponse.py", line 187, in executeEffects
eval(u'rpDevice.' + effect.updateParam + u'(responseObj, rpCommand)')
File "<string>", line 1, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Plex Media Server Manager.indigoPlugin/Contents/Server Plugin/plexMediaServerDevices.py", line 171, in handlePlexMediaContainerResult
clientDevice.indigoDevice.updateStateOnServer(key=u'currentlyPlayingContentPercentComplete', value=percentComplete, uiValue='{0:d}%'.format(percentComplete))
ValueError: Unknown format code 'd' for object of type 'float'
